- New noise, 89 22re, sloshing/whisking?
- Mystery oil leaking????????????
- Exhaust and other questions
- 87 4Runner Auto hubs issue
- 95 runner that needed a new CV boot- they lied on me!
- Alarming noise coming from squeeling belts?
- Replacing OEM fuel filter with spectre filter
- Busted Side Mirror (just one)
- 93 toyota 4x4 lift question
- 1986 Front brake upgrade ?'s
- 5.0 wiring
- 1990 4runner skid plate Bolts
- Gear swap Front Diffirential
- I dont have a horn
- BACK of carb diagram
- 92 Toyota Pickup 22re acting gutless. PLEASE HELP!!!
- Looking at a new Toy tonight
- Waterproofing
- 1987 axle $150
- 89-95 22RE Fuel Pump...How long till fail?
- 22re swap questions
- 94 4Runner 3VZE Running Weird, help!
- 89 reg cab shortbed with rotted frame, can I swap with an extended cab frame?
- Oil Leak - Need Advice
- husky liners 1st gen runner
- this is a noob question. do you have to prefill a fuel filter when installing.
- Lift Kit Help: Will this fit my Toyota?
- hanger placement 3" trail gear - set back???
- Rear heat/AC installation?
- Where to put / how to wire speakers...
- mounting KC's to stock bumper
- Truck shakes
- Will this fit my front
- 3vze cylinder head removal question ???
- Cutting rear fenders on first gen 4runner
- negative affects of exhaust leaks
- 22RE burning lots of oil
- facelift(paint time)
- truck speedo problem
- V-6 RPM's Question
- Pop-in limited slip for front?
- Replaced my steering stabilizer. Big help comes in small packages!
- What is it doing in my oil pan?
- Flashing engine light codes?
- O2 sensor wiring....HELP
- IFS Steering Stabilizer
- Frustrated vibes!! last chance for the 4runner
- Just did timing chain. Help me get it running again
- What is this spot for in my dash?
- Water Temp Gauge?
- Front Drive Shaft problem
- I need Timing Chain Help
- 85 22r SA needs new head gasket. A little help?
- 22RE rebuilding ?
- Rear bumper, 91 Runner
- Driveshaft won't go in far enough
- A free 1993 4x4 PickUp? I'll take it.
- newbie timing chain replacement
- STILL trying to deal with my idle issue...
- 4wd light doesnt go on
- It died.. Now i must fix it
- will this work??
- new exhaust causing rattle at low speeds
- started smoking yesterday!
- Snorkel for 89 22re. Where?
- 1994 22RE problems
- Driveshaft Lengths
- Why won't my truck start?
- ratcheting sound after 4.7 gear install
- can I block of the EGR to eliminate a CEL code?
- modded the MC rear for the runner, not too bad.
- Hood Louvers / vents
- U-joints and Temporary FWD 4Runner
- 7.5" R&P question, guru needed
- Is this a good lift kit?
- one last question
- Broken key in ignition need advice
- 1991 4Runner v6 Engine makes thumping noise
- Northwest Off-Road Specialties Lift Kits
- Will 3rd gen parts fit a 2nd gen Runner?
- !994 V6 Truck Valve covers???
- Little birdie sounds
- timing cover removal
- who needs a toyota tape player?
- Won't turn over - help asap?
- Help me pick my tires
- Got my new grille!
- Wacky fuel guage.
- Leaking Cam seal after replacement HELP
- Flywheel broke off
- balljoint lift spacers?
- Just got my truck weighed.... does this sound right?
- Help me pick a short block.
- Need help diagnosing whistling noise...possible transmission problems
- o2 sensor wire
- what gear ratio is stock
- Speedometer Replacement Questions
- I swear im not a ricer!
- Front speaker enclosure boxes
- Exhausts
- Vacuum Lines
- Intake Manifold pics
- Should I invest in a transmission oil cooler? Which one?
- Flushing auto transmission. Does disconnecting cooler lines hurt anything?
- loud clunking mid-frame
- oxygen sensor bracket rewelding?
- another 3 slow HG saga
- exploding clutch
- SR5 rear belts swap into Non-SR5 Runner?
- New seat belts
- What you need for 22re Intake Mods / Installation
- 91 v6 fouling plugs
- Oil pressure guage question
- So i have a new noise in my 22re
- truck will sputter and die
- 87 22R exhaust leak?
- Head Problems!!
- pretty good deal??
- lower ball joint removal question
- Weird Brake pedal & Steering Issues
- YoYoMa's rebuild thread.
- Customer Bumper pics!
- sheared off a bolt in my intake manifold
- 3vze coolant drain plugs
- Intermittent oil light problem
- can I put a lock washer under a brass nut?
- Trevor goes wheeling...
- swaping 88 1/2 ton rear axel with 86 1 ton rear is this possible
- Head reinstall, valve train question
- DIY Brake job! What pads?
- 89 Pickup Weird Electrical issue
- leak around slave cylinder boot?
- adjusting bump stops
- 86 Clutch Take 2!
- gauge cluster compatible?
- regearing question
- Will a 87 22re work with 91 parts
- 3VZE Oil Leak, HELP!
- What size tire?
- 4runner rear seatbelt tensioners locked!
- Vapor canister, 88 4runner??
- Tps promblem
- Problems with front sway bar
- red led next to dimmer knob
- New sound - 3vze
- Need measurements on SR5 alluminum alloy wheels
- horrible metalic noise, code 5, loss of power
- spare tire rack
- A word of advice on header installs
- Are they not making Dexron III anymore? What should I use?
- 4runner supra mod, finally done
- keyless entry?
- messed with distrubutor...2 new problems
- Dash/running lights and Horn not working
- timeing?
- SAS- smallest lift possible?
- going through oil and antifreeze
- seatbelt replacement?
- How many Rattle Cans did it take to paint your truck?
- 87 4runner Glass
- cold start problem
- Help with ripped upholstery
- Help with a ripped window seal
- 33's Rubbing on Sway Bar
- Need some help with plugs and hoses
- Need tips for a bed bob
- Replaced my distributor and now it sounds awful
- I am having a brake problem
- 90 & 92 transmission swap
- 4.3l MPG???
- Mystery Sound Persists
- creeper gusset & shock hoop mounting - trail gear
- anyone interested in seeing a paint how-to on my 87?
- Will jeep axles work?
- 92 Runner, turn signal relay
- Can i change my camshaft without replacing the head gasket again?
- tranny recomendations for an 86 4wd auto to manual swap
- Universal Seat Sliders - 1st Gen 4runner
- Welded Frame Section OK???
- Extra set of hands for t-case setup?
- 94 4runner can't lower rear window
- Linkage problem?? Bad noise when S.W. is 360' rotated
- refill gear oil through shifter?
- Traded a minivan for a 93 4runner!!
- odometer speedometer problem
- Combination switch prop(head light switch)
- running engine with no valve cover?
- Looking at 89 3.0 5spd 4x4
- Permatex on Exhaust Manifold
- Skys E-brake kit
- Lost my A/C idle screw!
- Help 92 axle went bad .. need advice
- tachometer adjustment screw?
- Gears: differences and recommendations?
- leaf springs
- rear disk setup off a hardbody??
- 1991 staright axle conversion???
- man i wish i was better with paint
- Engine problems
- My LSPV IS LEAKING!
- Coolant Hose Identification
- transmission or clutch problems
- rebuilding a 22re.... Ideas/help/vendors?
- Crossover exaust pipe removal 3.0
- Timing Idler water out let pulley #2
- Coolant in throttle body???
- LSPV plumbing diagram
- jb weld knuckle ball - pitted knuckle ball
- Stuck bolts BOLTS! Need advice
- bad vibs with hubs locked in
- trans. shifting problem
- Torque Converter Lockup (Need Experts)
- how HP gains work
- level of importance
- Stereo question
- Stuck valve cover!
- 90 4runner v6
- water over the hood 'tick tick tick"
- Rebuild question. 22re
- 22re idle video
- truck almost stalling. Getting worse by the week
- 23 yr old wiring harness
- Question on the items needed to repack wheel bearings.
- Glad I never wheel alone(rescued by a jeep)..Story and pics from today
- 1990 Toyota pickup Headlight issues
- 94 3.0 VZE 4 runner problems - need some help
- Good place to order new suspension components in Canada?
- can I paint my leaf springs???
- Forward shift to top shift
- Pulled another Jeep out today
- Engine dead after tune-up!?
- 22RE Coolant Drain - Where??
- Exhaust write up: Flowmaster 50
- 89 runner running horrible
- 30-80LE on my 86 4x4. Other options?
- o2 sencor Qs
- This thing is sick
- Pretty bad camber on lift
- New Tunage in the 91!
- Rear Axle Gearing--Stumped
- 89 22re resonator air requirements
- runner vs pickup. The locker unlocks!!!
- Alarming noise in video and I can't locate it
- Grille fitment question...
- Experience with ingition control module
- Damn p.o!!!!
- For your entertainment... fuel problem solved
- v6 losing water
- o2 sencor question any input welcome
- Axle mount bushings?
