timeing?
Old Mar 25, 2009 | 02:21 PM
yoterr's Avatar
timeing?
i searched and couldent really find anything, but here goes, the motor was rebuilt like 10,000 miles ago, and when idleing cold or warm its misfires, and only runs ok when fully advanced? and stumbles when you give it a little gas.. this is an 86 carbed 22R all the vac likes were replaced recently as well as the cap and rotor and plugs...and sombody goobered up the crankshaft pulley so i cant tell when the motor is at TDC unless i pull the valve cover and look at the cam gear...
diff question but when you hit the brakes is the truck supposed to idle up? or is it a sign of a bad booster??? thanks alot
Old Mar 25, 2009 | 03:36 PM
yoterr's Avatar
nobody?
Old Mar 25, 2009 | 03:39 PM
sinneDBTB's Avatar
firing order?
Old Mar 25, 2009 | 04:13 PM
yoterr's Avatar
as in its incorrect? runs fine after the initial stumble, and it has intermittent misfiring sorry bout the confusion
Old Mar 25, 2009 | 04:29 PM
Justinlhc's Avatar
I haven't seen a 22R distributor rotor in a long time, but is it possible to be off a bit? Did it run the same before you replaced the cap and rotor and plugs? Were the plugs gapped correctly?
I had a misfire/stumble at lower rpm and it ended up being a burnt valve. Not saying you have a burnt valve, but a compression test will tell you.
Old Mar 25, 2009 | 06:07 PM
yoterr's Avatar
well im assuming the plugs/wires/rotor/cap n button were changed when the motor got rebuilt but ya never know, ill get all those changed out again before i post again, but i remember some one els on here had a stumble and it ran good when fully advanced, but not good for the valves, so i wanna try n figure this deal out b4 i start driving it everyday
Old Mar 25, 2009 | 07:12 PM
sinneDBTB's Avatar
sounds electrical to me. have a good look at all you wiring from your igniter to the plugs. and double check your firing order. i dont know what it is for the 22re but i am sure you can find it on here somewhere.
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
smiley52
Jul 11, 2015 05:16 AM
