rebuilding a 22re.... Ideas/help/vendors?
Old Mar 23, 2009 | 04:41 PM
fnr121's Avatar
I need to rebuild a knocking 22re...Who is a good vendor for a master rebuild kit? Also, while I have it apart, are there any 'must-do' add-ons for some power and/or reliability?
Old Mar 23, 2009 | 05:06 PM
olharleyman's Avatar
engnbldr.com
Old Mar 23, 2009 | 05:33 PM
abecedarian's Avatar
oversized valves, cam, maybe bump the compression to 9.5-9.7:1 (but be prepared for the expensive gas if the engine doesn't like it) and if you do bump the compression you should get an adjustable cam gear so you can dial the cam in... well the adjustable gear is probably an easy way to get a bit more power anyways without the compression bump...
avoid over-boring if you can (sometimes, it's a necessity) and if you can't avoid it, bore only as much as necessary.
Dale Johnston
11
Oct 31, 2015 10:22 PM
the_supernerd
Oct 1, 2015 09:20 PM
ktm192k
Oct 1, 2015 08:47 AM
tylermx71
Sep 29, 2015 08:49 PM
voiddweller
Sep 28, 2015 11:21 PM
