89 runner running horrible
Old Mar 22, 2009 | 05:39 PM
91FREERUNNER's Avatar
So the other day im driving home when my runner back fires and poped the colecter gasket and the CEL came on... I figured it was due to the exhaust not being read by the O2 sensor.... It began to missfire after the light came on.... exhaust is fixed but there is no muffler it rotted out after the cat... My plugs all look black as if it is rich or burning oil.... what could cause this injectors?
Old Mar 22, 2009 | 05:48 PM
abecedarian's Avatar
Cold start injector spraying when it shouldn't?
But anyhow... the CEL came on. What code(s) do you have?
Old Mar 22, 2009 | 06:01 PM
DeathCougar's Avatar
If the O2 sensor was not reading and your truck was running rich, you may have melted the cat, which can cause the backfire and popped gasket. Be sure to check that before you go further.
Old Mar 22, 2009 | 07:56 PM
how do you scan this truck is it obd1 if so wheres the port i looked and couldnt find it.....thanks for the help its appreciated..once i run the codes ill let you know where im at hopefully tommorow
Old Mar 22, 2009 | 08:10 PM
toyota4x4907's Avatar
Take a paperclip, unfold it so its straight. Bend it in half. Look under the hood on the passenger side of the engine bay. Locate the "diagnosis" box next to the fuse box. Open the diagnosis box. Put one end of the paperclip in "TE" and the other in "E". Go turn the key to the accessory position "ACC". The CEL will flash. Count the flashes and you will get the code(s). If you don't have a repair manual, post up the code(s) and we will help you
Old Mar 22, 2009 | 08:12 PM
and to be technically correct-
if the pop came from the exhaust it's an 'afterfire'
if the pop came through the intake it's a 'backfire'
so what is(are) the code(s)?
Old Mar 22, 2009 | 08:13 PM
behind the battery, on the side of the fuse block, is the diagnostic check plug
use the paperclip to short the TE1 and E1 terminals (there's a diagram on the inside of the cover), then turn the igntion switch on.
Old Mar 22, 2009 | 08:17 PM
'88's were TE and E
Old Mar 22, 2009 | 08:28 PM
Just went and pic'd my 88....
It's T and E1
Old Mar 22, 2009 | 08:32 PM
Originally Posted by toyota4x4907
'88's were TE and E
It's T and E1
LOL. /me fail.
Old Mar 22, 2009 | 08:36 PM
RMA's Avatar
RMA
Title says 89' are they the same as 88'.
Old Mar 22, 2009 | 10:17 PM
LOL. /me fail.
You'll find that Abe always has to be right
Yes, 88 and 89 use the same type of OBDI port
Old Mar 22, 2009 | 10:29 PM
thook's Avatar
Well.........he WUZ right, wuzn't he?
Is this a V6 or 4cyl?
Old Mar 23, 2009 | 07:11 AM
well i just ran the codes and pulled a 31 and a 51
Old Mar 23, 2009 | 07:08 PM
anyone got any ideas???
Old Mar 24, 2009 | 05:13 PM
Im going to say its the tps but need some more input here...
Team420
Jan 12, 2021 04:57 PM
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
WI Girl
Jun 25, 2015 03:45 AM
saphirekosmos
Jun 22, 2015 10:26 AM
JaredL
Jun 16, 2015 04:47 PM
