PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 [96] 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. difference in toyota efi?
  2. Rocker panel replacement
  3. Need opinions on my topper
  4. 88 pickup shortbed, bed weight
  5. Front Locker Help
  6. What 22re header is this?
  7. Cleaning intake manifold
  8. Truck briefly dies while driving then runs again...
  9. 1991 3vz 3.0 idles rough sometimes when warm
  10. Warm start causes bad idle/runs rough
  11. What to do..(Sell or continue to repair)
  12. torsion bar torque
  13. Snapped a leaf spring in a pothole
  14. Fuel filter Installation
  15. Bosal exhaust-anyone else have this problem?
  16. Where to get switched 12V for heated O2 sensor
  17. ZUK mod question for 91 pickup
  18. 93 4runner factory alarm help
  19. ANOTHER 22re misfire...help!
  20. Coolant leak above oil filter
  21. Engnbldr earning business!
  22. Brake pedal hard to push
  23. Another 22re low/rough idle problem
  24. 1988 Wiring Harness Connector Identification
  25. 7mgte swap 94 2wd pickup info
  26. clutch bracket
  27. turn signal relay
  28. 88 Pickup with strange fuel issue.
  29. Fuel tank bulge, overpressure issue resolved...
  30. 3.0 hig rev leanout
  31. Transmission Troubles
  32. Gas mileage and EGR valve
  33. Need help with '94 measurements
  34. 2nd gen 4runner starting/ shiftlock issues
  35. no idle up when a/c is turned on
  36. Diagnosis test = 14 and 25
  37. rebuilding the 4R
  38. engine light........??
  39. New manifold! Out with 15 year old headers...
  40. just picked up a 93 4runner
  41. New member new ride 95 4runner
  42. no start has me stumped
  43. coolant leak at exhaust manifold
  44. Gotta smog... CA questions.
  45. Has Anyone Seen This Before?
  46. How to go about fixing this leak
  47. How to get max power out of 3.0?
  48. new clutch issues
  49. 8" rear differential search
  50. '91 pickup no heat
  51. RPM, H2O sensor,4wd indicator not working.
  52. Knock sensor issue
  53. Fuel Problem?
  54. Left turn signal activates hazards!
  55. Does anyone know where to get bolts for the rear spring hanger for '86?
  56. Reseal Clutch MC Reservoir?
  57. Any suggestions for truck cap 1989 sr5?
  58. Need help fixing coolant leak
  59. 1990 3vze Code 51 Under Load
  60. 2nd gen tranny in a 1st gen??
  61. 1st Gen 4Runner: How to remove pass side dash pad
  62. 1994 4Runner 3VZE hard to start and jumps idle
  63. Code 4 won't clear? Any ideas?
  64. 22RE test connector-make it yourself
  65. Upper Ball Joint Question!!??
  66. Changing Rear Brake Shoes: The "easier" way
  67. 4Runner HG Replacement: Is My Block Clean Enough? Pics Included
  68. Acess cover for tailgate on 1987
  69. Lc coils on your 4runner?!?
  70. How do you diagnose a timing chain problem?
  71. How much will 83 stock pick up leafs lift my SAS 4runner if i put them on the front?
  72. power steering gear box
  73. 87 22re power loss, 30mph max, eye burning richness, codes 21, 42, 51
  74. Finding the Factory Amp 1990 4Runner
  75. No-Cut ZUK Mod...our turn
  76. 3.0 v6 battery issues
  77. Is it simple to change 02 sensor
  78. 90 4x4 automatic trk 3.0 v6 problems takin off
  79. w56 transmission grinding Help!!!
  80. 1989 4runner SR5 Auto Transmission Question
  81. LSPV replaced... rear brakes sticking?
  82. what is this part and what does it do?
  83. RPM drops to around 400 when coming to a stop and stepping on the brakes
  84. replace motor or head gasket?
  85. Can't keep Horsepower.
  86. 22re timing chain done or not?
  87. Distributor cap retainer screw
  88. 94 runner 3.0 cranks but no start
  89. 1987 turbo 4runner brake issues
  90. Needing leaf spring bushing help
  91. 22R-E LCE master rebuild kit
  92. 91 22R-E turbo.
  93. New TOB sings
  94. Were the 1993 Toyota frames made by Dana Corp? What can I do?
  95. 91 tranny swap ?
  96. new tires and wheels..all smilles 4 me
  97. 1990 4runner...what to do...
  98. Brake Booster Removal
  99. Engine noise: care to take a listen/stab?
  100. Loaded up 1600 lbs of logs yesterday....
  101. 3.slow syndrome debunked
  102. Key gets stuck in ignition when wire is plug in
  103. Have you checked ur timming?
  104. Fresh rebuild, Burrnt wire?
  105. 22re starter solenoid connector issue
  106. 81 sas into a 89 runner
  107. 86 22R loosing coolant and some unusual pressure being held in coolant system
  108. 1st Gen 4Runner Canopy Headliner Replacement how to
  109. 86 T4R Over heating issue...
  110. torsion bar removal question 86 4runner
  111. First drive with an A340H
  112. Mass Air Meter Problems 1994 22RE
  113. weber 38mm throttle linkage on 22r help
  114. Mystery Bracket
  115. 3VZE Timing Belt Cover Gaskets
  116. Bushwacker Fender Flare pics. Trying to decide for my 89
  117. Odd Brake problem
  118. will the oil pressure switch cut fuel?
  119. fuel unit problems?
  120. ZUK mod... gonna try it!
  121. Sparkly Front Diff Oil
  122. Lack of compression #2 - Stuck Valve or Bad Spring
  123. Idling issue
  124. 3vze valve cover change
  125. Skyjacker shocks after 2000 miles??
  126. What is source and correct value of STA signal at ECU
  127. Speedometer Cable is fine, gear in t- case?
  128. What inputs are necessary for the Cold start injector to fire?
  129. What inputs cause ECU to send injector ground
  130. 1992 3.0vze with dead cylinder?
  131. Oil Pump alignment on crank shaft
  132. 4runner nightmare 30 psi comp on 1,3,5
  133. freshly rebuilt 22re turbo dry starting?
  134. Advice on fixing this rust??
  135. Tilt Column Swap: Steering Wheel Locks in Run
  136. getting annoyed with the yota, encouragment?
  137. 95 4runner front end issues when 4x4...
  138. Two Inch lift
  139. Son tried to jumpstart my rig--fail!
  140. LC Engineering 22RE header exhaust install questions
  141. how to remove dented tailgate if window wont go down?
  142. transmission help?
  143. 1990 4runner won't shift when running.
  144. 92 4Runner rear axle removal
  145. 93 toy 4x4 GRINDING HUMMM help.
  146. afm to map sensor?
  147. New 3.0 with rough idle when warm, stalls
  148. Bad clutch release cylinder?
  149. Check engine lights
  150. 1991 pickup brake lines
  151. Mounting a Motorcycle Carrier on a '94
  152. Metal found in rear end gear oil change
  153. Issues with Warn Premium locking hubs
  154. My son's first Yota
  155. 7.5 third member question
  156. 22R Dies at Idle When Warm,relay clicks
  157. 97 Taco tranny on a 3.0?
  158. 1990/1993 3vze 4Runner low idle/stalling, new to Yotas...
  159. 1st Gen 4Runner: Power Steering Reservoir to Pump Hose Obsolete???
  160. So...my tailpipe fell off today...
  161. Too much ZUK?
  162. Clutch master Cylinder: Rebuild or Replace? Known Good Brand?
  163. Whats up with the heat???
  164. 22re idling rough about 1/3 of the time?
  165. New clutch for the 3.slow
  166. Does the VSS affect 5 speed driveability?
  167. transmission/tras case woes...
  168. Wiring Harness Help 88 3.0
  169. '90 4runner with burnt valve, need advice
  170. cooling fan bracket what years fit
  171. Video: Does this seem like fuel starvation?
  172. Clutch Pedal Assembly
  173. how to align pitman arm/ steering linkage
  174. Timing belt question
  175. 3.0 vacumm hose path for VSV
  176. flywheel help
  177. 91 Toy P/U taillights
  178. Wire on rear axle on '93 pickup
  179. Motocrossaddict's complete auto to manual swap
  180. Fresh Paint Job and Front Axle Rebuild!
  181. 22re street truck build idea/opinion
  182. Fuel Sending Unit Part #?
  183. Oxygen sensor help needed!
  184. Throttle body coolant bypass question
  185. the new Toy (Unmolested 88' 4runner)
  186. Clutch wont engage
  187. speedo gear question
  188. 91 4runner starter wire plug
  189. Changed Tranny gear oil - now its notchy?
  190. 1988 Free Stuff & Elbow Grease
  191. Not geting any oil preasure Please help.
  192. brake line leak
  193. Bypassed Neutral safety switch... but what's the red wire?
  194. Rattle/jangle in the rear; am I going crazy?
  195. 95 22re Low Idle: Creeping Idle Screw?
  196. 86 wiring
  197. 95 4Runner- Is 3.4 swap reliable option for family vehicle?
  198. 1991 4Runner Cruise Control not working...
  199. Blinkers, High Light!!!!!!!
  200. Cracked head or head gasket leak?
  201. New member, in middle of removing 3" body lift, confused by steering column...
  202. 1st Gen 4Runner: Removing Headlight?
  203. How do I fix THIS leak on W56 Transmission?
  204. The New Dude
  205. w56-e trans wont go into gear
  206. Exhaust Advice
  207. 91 truck rpms drop when you use brakes
  208. '94 Pickup Idle Speed
  209. Fuel injectors & CSI not firing, crank only / no start
  210. Opinions wanted! '94 pickup 4.7 t-case gears or dual t-cases?
  211. remove ignition switch bypass
  212. Water pump shaft play
  213. clutch master cylinder, is it broken?
  214. 89 SAS power steering no power
  215. Single "Clunk" when braking
  216. Side/bed mount spare tire carrier for pickup?
  217. Any Way To Fix "Stuck Accelerator? Help a beginner please!
  218. Here we go again!! Got another Yota!!!
  219. intake manifold help!!
  220. 88 22RE gallops like horse
  221. 22RE Clutch and Ignitor Questions
  222. 94 3vze hard/no start/fuel issues
  223. racing seats in 91 toyota pickup anyone have some in there toyo
  224. 4runner rear wiper hangs down??
  225. post pic's of your 91 toyota's 4x4
  226. 86 hub install ?
  227. 22re smokin
  228. Silla All Aluminum 3vz radiator into 22r Truck
  229. 1988 4runner Heater Core removal
  230. 22re: What is this sensor/switch? (Checked FSM and searched)
  231. welding 2 frames together
  232. emissions test fail
  233. Mobil 1 75W90 GL-4/5 Gear Oil vs. Red Line MT-90 75W90 GL-4 Gear Oil
  234. Stripped steering shaft bolt, need some advice
  235. Trouble with 3VZE not starting
  236. switching a 22re engine for a 20r engine
  237. 2nd gen 4runner door lock module
  238. distributor bearing
  239. New 3.0: Lack of Power
  240. fuel sender resistance digital display
  241. 1st Gen 4Runner: How to remove plastic inner fenderwell
  242. Fel-Pro PermaTorque Head Gasket
  243. No high beams
  244. Slow Starting 94 3vze
  245. Throttle plate setting at idle, 1994 pickup 22RE
  246. 1989 22RE Pickup Relay Clicking and Stalling
  247. Transmission Issues, Lose of Power
  248. Part or Part Number Needed - Aisin IFS Hub Part
  249. 88 4Runner 1kd-ftv swap (NEW) w/pics
  250. 2nd gen, OME vs. LC coils
