Mass Air Meter Problems 1994 22RE
Old Apr 2, 2012 | 06:09 PM
fast copperhead's Avatar
Have replaced the mass air meter 4 times wirh a Cardone Reman unit. It runs great for a couple of months then just dies. It appears the the air meter is cutting fuel pump off. Do I need to replace with a new unit instead of reman unit? This is getting very frustrating. Any ideas from the gurus here?
Old Apr 2, 2012 | 06:32 PM
MudHippy's Avatar
If you've replaced the part 4 times and the problem still persists, then the part you replaced 4 times trying to fix it most likely isn't the real cause of the problem(and it probably wasn't broke to begin with). Replacing it 2 times was enough to figure that out. Don't take a guru to tell you that...
Old Apr 3, 2012 | 02:42 AM
It appears that something is happening to the replacement units. A check with ohm meter before installation checks in spec and after the the problem the air meter checks bad. Two of the four I received checked bad prior to installation. I am wondering if the reman units are the problem.
Charecter1
Nov 6, 2023 10:08 AM
MO transplant
Apr 23, 2023 11:58 AM
Road Bull
Oct 10, 2015 04:55 PM
Avenged
Jul 9, 2015 07:55 AM
karbin
Jul 5, 2015 11:37 PM
