22re starter solenoid connector issue
Old Apr 3, 2012 | 09:46 AM
floridanative82's Avatar
Hello, I have been a member for a few years but don't post very often. I have a question about the starter solenoid and cannot find the answer to it.
My buddy and I recently replaced the starter on my 4 cylinder 1988 2wd Pickup, and we noticed a possible problem. We noticed the piece that snaps onto the solenoid appeared to be corroded and worn out. We took a picture of it, although it is blurry, hopefully one of you guys can recognize what it is and how/if we can fix it.
Before we replaced the starter, it could be slow to start sometimes. 5-8 times I would turn the key over and absolutely nothing would happen. I would then get under the engine with a rubber mallet, tap on the starter, try again, and she would start up.
Any thoughts on this? Do I need to replacement? Where can I get one?
Thanks guys.
Attached Thumbnails 22re starter solenoid connector issue-starter-solenoid-connector.jpg
Old Apr 6, 2012 | 04:08 PM
Anyone out there with some info? A little help, please!
Old Apr 6, 2012 | 04:25 PM
RAD4Runner's Avatar
Thanks guys.
It's a plain spade connector. The thing on the wire is the female side. It looks like this. The one on the solenoid is the male side. Any good electrical, auto store or Radioshack will have it. Just find one that fits the male part and the terminal housing.
If you decide to replace, I'd recommend you solder it on, instead of crimping it. Soldering will make it resist corrosion and keep dirt and oil out of the connection.
Old Apr 6, 2012 | 09:16 PM
Turd Furgeson's Avatar
I'd also double check the power wire from the battery to the under hood fuse box. I was having starter issues on my old truck (clicking,get out bang on starter with hammer,and have it start sometimes). Replaced the contacts inside the starter,thought I had it fixed and it still did it. Then noticed frayed,green,corroded,jimmy rigged main power wire from the battery the fuse box. Fixed that and it never gave me anymore problems,cranked better too.
Old Apr 6, 2012 | 10:20 PM
RAD4Runner's Avatar
Originally Posted by Turd Furgeson
... (clicking,get out bang on starter with hammer,and have it start sometimes)...
Best to consult the FSM in order to analyze the problem properly (see my sig for link to FSM's). We gotta be careful with the "clicking" sound when troubleshooting. Be certain what click you're hearing when you turn ign. sw. to "Start":
  1. Circuit opening relay? This powers the fuel pump. This clicks as soon as you put ignition switch in "Start position", Even if clutch safety switch is open AND safety cancel switch is OFF.
  2. OR Starter Relay. This will only energize IF clutch safety switch is closed OR safety cancel switch is turned on. You may not hear this because it is in engine compartment.
See this post for relay locations.
Old Apr 7, 2012 | 08:13 PM
Rad, I will get the appropriate sized female spade connector. Thanks for the direction.
Turd, I will check out that wire and clean/replace if necessary. I will update with info once i get it done.
Thanks for the help, guys.
Old Apr 8, 2012 | 11:24 AM
Egar's Avatar
@ floridanatice 82, im dealing with a ignition switch bypass on my 4runner and i cant seem to figure out where that wire with connector is coming from(the one in the picture, wire u are holding.) when u follow it, is it coming from the black tubing? do u have a picture showing where is coming from? it would really help me out. i checked FSM but dont see anything specific . thanks!
Old Apr 8, 2012 | 11:32 AM
Utah4Runner86's Avatar
Mine comes out of the harness near the oil filter. edit to add - specifically, out of the harness from under the intake plenum, aft of the oil filter.
Old Apr 8, 2012 | 08:50 PM
Egar's Avatar
just looked, cant seem to find wire..??? this may have been modified and i may have no way of tracking it down..???? pictures ...any one have a pictures??? i know sux to be me...but i just cant figure this out, all i see is the wire that goes straight to the starter from the battery, thicker gauge wire....
Old Apr 8, 2012 | 10:16 PM
Pics won't help, it's there or it's not. I'd say screw it and just run a new crank wire from your ignition.
Old Apr 8, 2012 | 11:58 PM
wyoming9's Avatar
Red face
If your bypassing the start position on the key switch .
You want to make sure you energize the cold start time switch.
The wire to the starter solenoid comes via the starter relay if you have a manual trans.:jessica:
Old Apr 9, 2012 | 12:27 AM
RAD4Runner's Avatar
Most welcome, floridanative82.
The wire providing power to energize starter solenoid comes from the starter relay here:
Schematic here:
Unplug the cylinder-shaped connector from starter relay check resistance to all pins from the female spade connector that floridanative82 is holding. Whichever has close to 0 ohms, that's the other end of that wire.
Old Apr 10, 2012 | 01:42 PM
Egar's Avatar
ok i will try to work from starter relay. the wire that floridanative is holding is completely missing from my truck. i will try to back track from starter relay. thank you.
Old Jul 31, 2017 | 12:45 PM
Ed ke6bnl's Avatar
I have a question, my solenoid is not being activated. I put 12volt to the small disconnect terminal and the solenoid is not doing anything. I WANT TO CHECK THE STARTER SOLENOID FOR CONTINUITY the quick disconnect terminal in the 12 volt plus and is the other side of the solenoid coil go to ground?? I am getting a low resistance from the 12 v small disconnect on the starter and the ground.
Old Aug 1, 2017 | 12:34 AM
RAD4Runner's Avatar
Yes, the other side of the coil goes to ground. I believe internally there are 2 coils. The other one may be bad on yours OR the starter and solenoid are not getting ground.
Both the solenoid and starter motor get ground from the one on the block connected to battery negative:
Solenoid contact gets its positive from here. Sends it to motor when contact closes,
Old Aug 1, 2017 | 05:23 AM
Ed ke6bnl's Avatar
thanks for your post. I may have a one bad coil I can get the solenoid to pull in IF I get the plunger very close to its travel but not when it is in place with the cover over the plunger, I will stop by the alt. and starter rebuilder.
Sleaker
Aug 26, 2020 06:03 AM
steve miller
Oct 10, 2015 01:40 AM
ZONAYODA
Jul 13, 2015 07:17 PM
mengquis
Jul 13, 2015 10:39 AM
colinmil
Jul 6, 2015 04:03 PM
