engine light........??
Old Apr 9, 2012 | 12:29 AM
oldirtydirt's Avatar
i am trying to get my truck back to smog legal and one of the things on the list is the engine light needs to come on for a second or so when you first turn the key on to start the truck but it does not.......i was wondering if anyone has had this problem with any luck in fixing the problem i tried a couple of search words with no luck as of yet i will keep trying but would really like some help if any is out there...thanx p iii
Old Apr 9, 2012 | 12:30 AM
ps........the truck is in cali and runs fine just having that one problem, once again thank you for any help
Old Apr 9, 2012 | 01:15 AM
Utah4Runner86's Avatar
Probably a burnt out bulb. Any auto parts store has replacements.
Old Apr 9, 2012 | 07:18 AM
thanks for the quick reply but that was the first thing i tried and no luck........p iii
Old Apr 9, 2012 | 07:51 AM
Bassmastry101's Avatar
Is it EFI or carb? Does a carb truck even have a check engine light?
Old Apr 9, 2012 | 08:10 AM
scope103's Avatar
Yes, telling us a little about WHICH Toyota truck you have might help.
The engine light is more commonly called the CEL (or Check Engine Light). Its signal is available on the W connector in the diagnostic connector, so check it there and you'll bypass the wiring to the panel. Then, if necessary, trace it back to the ECM using the schematic. http://www.ncttora.com/fsm/1990-1995...emci/eng3r.pdf
Be prepared for some codes, though. Even though your truck runs "fine," there is probably a reason your predecessor tried to hide the CEL.
Old Apr 9, 2012 | 08:02 PM
sorry guys it is a 1986 toyota 4wd it was a turbo truck but the motor was blown so the po put a 22re in it and yes it did have a check engine light but it stopped working.......ps i have checked the bulb thank you guys for the quick responses i will keep trying to figure it out
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
