Knock sensor issue
Old Apr 8, 2012 | 06:58 AM
GRINDER32's Avatar
Knock sensor issue
I just rebuilt the motor in my 88 22re from oil pan to valve cover, everything new, including a knock sensor. But now a month or so later my knock sensor engine code is up on my dash. I also have a really high idle when I pull up to a stop sign for example unless I bump the throttle pretty good then it idles down. I'm just very confused on why my idle would be doing this and secondly my knock sensor. I don't want to spend another 200 on a new knock sensor to find that the sensor itself wasn't bad. Are there other things in relation to the sensor that throw a code 52?
Old Apr 8, 2012 | 07:09 AM
rworegon's Avatar
Did you replace the knock sensor wire at the same time?
Old Apr 8, 2012 | 07:34 AM
GRINDER32's Avatar
No I did not, only the sensor. Are the sensor wires readily available?
Old Apr 8, 2012 | 07:53 AM
spinyard's Avatar
it's the wire they go bad all the time
Old Apr 8, 2012 | 08:01 AM
rworegon's Avatar
Dealer only item, special order. Probably less than $15-20. The sensors hardly ever go bad. Wires get killed by heat.
Old Apr 8, 2012 | 08:27 AM
GRINDER32's Avatar
Ok awesome! 15 is much better than 200! I'll order that so I can do it while my injectors are being rebuilt
Old Apr 8, 2012 | 08:36 AM
rworegon's Avatar
Check with your dealer for the correct part number on the wire. They did change right about '88.
Old Apr 8, 2012 | 08:48 AM
volfsar's Avatar
go to the dealer with your wire, so they get the right one for sure, they always order the wrong one
Old Apr 8, 2012 | 09:43 AM
drew303's Avatar
$200 for a knock sensor!? Jesus lol I just gave one away for free last week
Old Apr 8, 2012 | 02:40 PM
GRINDER32's Avatar
Knock sensors are very pricey, at least to me lol. Gotta love a high school budget! But I will run up to my dealer and get them to order me the correct wire. It is just odd to me because the light comes on randomly and only after driving about 15-20 miles.
Old Apr 8, 2012 | 02:59 PM
swerks's Avatar
let us know if the wire does the trick
Old Apr 9, 2012 | 08:17 AM
drew303's Avatar
Next time just go to the junkyard and get one
Old Apr 9, 2012 | 08:31 AM
scope103's Avatar
The knock-sensor pigtail fails all the time from age. You'd put an "old" wire in to save $10? I don't think I'd do that even if it was easy to get to, and the knock sensor wire is anything-but.
montanatruck
Feb 26, 2017 07:07 AM
nonstop
Jul 24, 2015 06:29 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
keithporter83
Jul 18, 2015 12:37 PM
smiley52
Jul 11, 2015 05:16 AM
