Exhaust Advice
Old Mar 25, 2012 | 06:06 PM
Fireguy's Avatar
Exhaust Advice
I am getting ready to have a new (remanufactured) 3.0 installed in my 93 4x4 DLX and I am thinking that I will have Doug Thorley headers installed also. I know that many would do the 3.4 swap, but I need to stay on a reasonable budget, so I am sticking with the 3.0. I am looking for anyone with information on what I should use from the headers to the tip. I am not a mechanic, so I am going to have to depend on an installer for this work. Any advice on what I should use would be great.
Old Mar 25, 2012 | 06:12 PM
wii_tarded's Avatar
2.5 inch to the back, nice hi-flow muffler (Borla, Flowmaster, Magnaflow) and no cat if you can get away with it.
Old Mar 25, 2012 | 06:30 PM
drmix's Avatar
Just get a high flow cat instead of ditching it. Theres no point in polluting the air even more just for a little extra power that you wont even notice.
Old Mar 25, 2012 | 06:41 PM
wii_tarded's Avatar
Not so much worried about that as the cost of buying one.
Old Mar 25, 2012 | 08:41 PM
bob200587's Avatar
It's just a couple hundred bucks.
Old Mar 25, 2012 | 09:00 PM
blakefogt's Avatar
No cat ftw!
Old Mar 25, 2012 | 09:33 PM
250000_yota's Avatar
I would definitely put a cat in. I had a set of the Downey headers on my old 3.0 and ran a hollowed out cat and a Doug Thorey cat back. It was EXTREMELY loud, and, after I wrecked the truck and got something new, I realized it was way too high flowing for that old motor. Having a exhaust that flows too freely is tantamount to burning up valves. The headers will really open that pup up, but keep a little back pressure in there. I'd recommend a stock replacement cat, a good 2.25 cat back, capped off with a good turbo style muffler. It will give it a good tone, flow well, and not be too loud.
Old Mar 26, 2012 | 08:36 AM
Woody's Avatar
Do you have smog rules in your county?
Old Mar 26, 2012 | 08:48 AM
5runner's Avatar
250000 yota is right no cat not enuf back presser i had not cat on mine it was really loud and way to free flowing lose some low end power and the 3.0 dos not have much power to spare! so i redid mine and put a hi flow and a cheery bomb stly on mine i like it sounds great not too obnoxious and i did like my turbo stly muffle i had on too!
heres mine
i put a turn down on the end so it would not blown right in my back window
Old Nov 15, 2012 | 05:24 PM
Fireguy's Avatar
Thanks for all of the advice. It has been a while in deciding to spend the money on my truck, but I made the decision this evening and I should have the processs started in about a week. Remanufactured engine, new clutch, radiator and exhaust. After having the truck for the last 19 years, I guess it will be worth it to have it back on the road.
Old Nov 15, 2012 | 05:54 PM
NickMiller's Avatar
Also, to keep back pressure I suggest going with 2.25in pipe (vs 2.5in)... 2.25 is the biggest you can go without noticing the loss of back pressure (from what I've read).
39 Thieves
Jan 6, 2017 01:08 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
ManzDaKlown24
Aug 22, 2015 10:25 PM
accuracy
Aug 4, 2015 08:05 PM
Sidherish
Aug 2, 2015 01:42 PM
