PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 [236] 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Gap between 1800-2300 rpm........TPS problem ?
  2. I got a recall
  3. Warm starting problems
  4. towing question
  5. Sea Foam treatment
  6. Chain tensor innards?
  7. Need a repair opinion...diff cover
  8. Conversion.
  9. Truck lost power and died (89 3.0)
  10. Welding ?
  11. 3VZE Woes Revisited
  12. PLEASE Post a Sticky for These!!
  13. bumpers??
  14. Starting Issue :(
  15. 94 and 95 4runner doors...same?
  16. New body panels or just **** it, Herculiner it?
  17. Front and Rear Bumper ideas
  18. Engine probs/questions with '87 22RE
  19. Regear: Power vs. Gas milage
  20. Big Bass for regular cabs!!!
  21. What happened to my oil pump?
  22. Put my Hella 500s on!!
  23. Do i really need regear?
  24. Steering rod relay recall
  25. Fuel gage issues
  26. Oil Pressure Gauge
  27. Need pic of rear wiper thats correct
  28. Price check for '89 SR5 gauge cluster
  29. rear wiper/washer problem
  30. Time for a new shifter seat!
  31. Question on 4wd light
  32. 3.0 EGR Question
  33. turbo runner questions
  34. Spare tire mounting system ?s
  35. cooling system help 3vze
  36. 4wd issue!
  37. Rear window Down wire
  38. 92 4runner 22RE slow idle.
  39. I need help find water hose part number 22re
  40. Mods
  41. Spare Tire Carriers
  42. 1986 Toyota 4Runner SR5
  43. stock radio?
  44. NewB 94 4runner owner
  45. Junkyard butt-sag fix?
  46. 94 22re 4x4 pickup weird idle
  47. 3.0 running Problems (longish)
  48. Main Cap Torque?
  49. wire connector
  50. Morse Code Diagnostic Check?
  51. Seat Covers
  52. 22RE Rotor and Distributor Cap
  53. Graphics
  54. Cost of a "new" 3.0 3vze
  55. Idle hangs after new engine install
  56. Tempeture Gauge Problems
  57. Body Parts
  58. 4cyl, 2wd, stock body, finished exhuast inatake, any ideas?
  59. Diff Installation time/cost
  60. Bay Area lift install
  61. Power Mirrors
  62. Tranny Gurus: A340H 4th gear change?
  63. crazy 2nd gen 4runner truck on ebay...
  64. Anyone in here have a turbo on a 22RE
  65. Can cold weather kill your AC?
  66. ifs cv studs?
  67. Lift help
  68. what vaccum hoses and valves can i remove from my 22re?
  69. Drivetrain hard disengage upon throttle release.
  70. Alternator maybe? or battery? or something else
  71. 94 4Runner with Manual Gearbox problem?
  72. 83 Pickup W/Cummins 4BT
  73. Original 14" wheels - any good for spare?
  74. Is this slop in the front diff normal? (vid)
  75. Window Roller
  76. Lost a Part: Clutch Throw out brng clip
  77. Uh-oh.. What did I screw up? A/C electrical problem.
  78. oil pump drive sleeve
  79. Ball Joint Spacr Install Direction
  80. Tire Rotation
  81. 22RE Motor noise
  82. 3VZ-E rich idle, poor mileage
  83. any tricks for heater core removal?
  84. The little bulb behind the HVAC controls
  85. Want you Yotas interior clean and stench free? use PINE SOL
  86. sliders for 89
  87. Compression Test
  88. mysterious leak (3vze 1992 4runner)
  89. Doors don't lock when key is turned...
  90. Looking for upper Air intake hose for 3.0
  91. 22RE Intake cleaning.
  92. Block heater leak
  93. Mushy brake pedal - NOT air in the lines
  94. Weekend Installs Part II
  95. Problems in low IDLE RPM (4Runner V6)
  96. Stolen Catalytic Converter - Please Help
  97. Broke My E-Brake------HELP!!!
  98. O2 Sensor Wiring - PLEASE HELP!
  99. Vacuum lines and cruise control
  100. headers install
  101. Anyone know the thread size for our shift knobs? (searched)
  102. in need of some serious help( yes i have searched :) )
  103. 89 22re rough idle
  104. Source for Pwr Window Switches (88) ?
  105. Need some help deciding what to do.
  106. a340h rebuild cost?
  107. auto trans fluid level
  108. 1st Gen 4Runner Video Clips
  109. how many like your 3.0
  110. Need lift and tire opinions
  111. Quick CD/radio question
  112. digital clock
  113. Tapping noise....
  114. To rebuild, or to buy rebuilt...
  115. 2 is better than 1
  116. 5 speed popping out of fifth. Question
  117. Air Flow Meter Question
  118. Alternate 1G 4Rnr Bodies?
  119. wont go in gear we engine warms up
  120. 1992 4 runner roof rack install on a 1990 4runner non roof rack model
  121. Sounds like a diesel!!
  122. Engine light on - no codes!!!
  123. pix of knock sensor
  124. R150F bellhousing to G52???
  125. tranny noises ?
  126. Best Valve Cover Gasket Seal?
  127. 90 3vze fuel pump replacement ?????
  128. Rear window
  129. Rear window weatherstrip clips
  130. Auto Temp warning light and water pump not turning
  131. red hot manifold
  132. Door Alignment
  133. Rear 4runner seats flip forward?
  134. Is there a way to change oil without making a mess 22ret
  135. Wing window ?
  136. 88 Toyota 22RE - metallic 'ringing' sound at rpm/load
  137. 87 yota 22r speedo off cuz of tires
  138. Engine revs uphill, clutch?
  139. Stolen
  140. Any pics of a marlincrawler bumnper on a 91 runner?
  141. Repair sleeve tool
  142. quick question
  143. 4 door, 4 cylinder engine owner's check in!
  144. Rough idle, white smoke, clean oil, losing water, and gas like smell from radiator???
  145. Downey Header bolts question
  146. Re-Engineered 3.0 intake (pics)
  147. new cepo runner got some probs???
  148. 91 4 runner endgate value
  149. 90 or 91 4runner Q
  150. adding on to a suspension lift?
  151. cleaning injectors
  152. will a 22r flywheel work on a 22re ?
  153. wierd noise, electric problems
  154. 2wd Frame vs 4wd Frame?
  155. Stock tires??
  156. Rear bumper hanging?
  157. Cab and floorbaord question
  158. how much power from an engnbldr head?
  159. replacement exhaust, second O2 sensor?
  160. 4x4 clunk and jerk after engine is shut off.
  161. New Truck - 91 4runner
  162. motor
  163. Exhaust Manfold / Exhaust gasket?
  164. Dual Trutracs and Yukon Gears Review
  165. 95 cruise control
  166. Thai Fender Flares
  167. 33INCH Tires
  168. DS Vibrasion even louder after U-joint rep
  169. Auto Tranny -electrical problem
  170. LSVP question
  171. leaky fluids under wheel well?
  172. Strange suspension/trans issue
  173. removing a/c
  174. What bends first in IFS?
  175. anyone ever tilted the engine to remove the oilpan?
  176. Head Gasket Time !!
  177. Pinging
  178. Manual Hubs question...I think mine may be broken
  179. Giving up on Aussie, now a Lockrite or No-Slip and why?
  180. Dave'z Offroad Question
  181. First Post, New 4runner =)
  182. Strange fuel system issue
  183. Driveshaft Noise?
  184. Simple timing question
  185. 22re timing set at +15 degrees?
  186. driveshaft hitting gas tank.
  187. 22RE Troubleshooting?
  188. looking for cromoly axles on my i.f.s
  189. No Power No Crank On Engine Nothing
  190. Stock ignition wiresets
  191. i need an engine guys
  192. locker on daily driver?
  193. brake light coming on
  194. Crower Cams vs Weasy Cams? 3vze
  195. Engine just quit after replacement...
  196. turbo computer
  197. 4:88's and locker on craigslist
  198. OBD2 Scan tool Recomendations
  199. no lift and 33's
  200. guage clusters
  201. thinking of rebilding 22RE...
  202. Injector Cleaning in Cumming, GA
  203. Speakers Make No Sense!
  204. vibration Woows :(
  205. I'm like a kid waiting for christmas
  206. 4Runner rear window
  207. Need Fluid Recommendations for 3.4 swap
  208. Roadtrip possibly?
  209. Swaping an auto for manual
  210. Rear Recovery Points without aftermarket bumper
  211. HG and TIming Chain replace thread
  212. Truck won't start...
  213. Who has turbocharged a 3VZ-E??
  214. Do I have Lockers?
  215. tailgate
  216. Need advice on my totaled 89-4Runner!
  217. How do the new 4Runners hold up
  218. Emmisions issues
  219. Need Fuel Filter Help NOW!!!
  220. Parting out a 1987 2dr 4runner
  221. Rear end slipping LSD?????
  222. sensors help
  223. 22r, Vaccum advance not working?????what will it do???
  224. help me help my runner
  225. gas tank size?
  226. stupid belts!!!
  227. Rear U-Joint Replacement
  228. Low Oil Pressure
  229. body lift?????
  230. BJ Spacer\Coil Spacer with same shocks?
  231. 95 runner losing power big time
  232. stock gears ?
  233. Bleeding LSVP...calling all pros!
  234. I Am A Newb! With A Few Lift Q's
  235. My 87 is stalling
  236. What kind of off-road lights??
  237. IFS ring and pinion replacement
  238. Heater Bezel - Discontinued??
  239. v6 and 4cyl rear axle assembly questions
  240. 2wd vs. 4wd 3.0 radiators
  241. Downey Spring Question
  242. anyone lowered the front diff on their 22re 4 runner?
  243. Thinking about getting in on the cam group buy
  244. center console fit ?
  245. 22re Rocker Arm Mod
  246. Radiator Removal Question
  247. '92 truck with a thud
  248. 3" BL and Sliders???
  249. oil pump
  250. A/C Condensor upgrade for 2nd gen pickups
