Strange suspension/trans issue
Old Mar 2, 2007 | 02:02 PM
madmaxx's Avatar
I've got a weird issue on my 86 5spd 4x4. I keep popping out of gear while at the same time, getting a huge driveline shock (BANG!). It almost feels like the rear end is shifting. Now, it only occurs when the wheels are nearly at lock, like trying to back out of a parking spot (reverse out, then turn the wheels to lock and start moving forward) or pulling in slowly to certain spots. It has never given me any trouble when moving forward from a dead stop or at speed.
Any ideas? I've carved out this weekend to change the gear oils, bleed the clutch and some other general maint.
Thanks!
James
Old Mar 2, 2007 | 10:44 PM
motoriderbc's Avatar
Remove your shifter and replace the plastic bushing (ball at end) The banging noise is common when it pops out of gear.
Old Mar 3, 2007 | 05:12 AM
madmaxx's Avatar
Is it normal to only occur at near-lock?
I've got 5" of total lift (3" suspension, 2" body) on 33" tires if that makes any difference.
Old Mar 3, 2007 | 06:48 AM
TNRabbit's Avatar
I had this exact problem for over 100,000 miles; it IS the shifter bushing and only costs a few bucks (get the MarlinCrawler one instead of the OEM, much more robust), but ended up costing me 1st gear & $1200 in transmission fix. You may have already broken off pieces of first gear.
There are numerous threads about replacing the shifter bushing; it's very easy.
Old Mar 4, 2007 | 07:45 AM
madmaxx's Avatar
Thanks -- I'm ordering the new bushing tomorrow I've been meaning to drain the fluids (got stuck working a bit this weekend) so I'll do it all in one shot next week hopefully.
James
Old Mar 4, 2007 | 08:08 AM
TNRabbit's Avatar
http://www.marlincrawler.com/docs/sh...eat/index.html
I'm trying to dig up another thread on exactly how you get to it...
Got it; here you go: http://toyota.off-road.com/toyota/ar....jsp?id=186539
Old Mar 5, 2007 | 08:05 AM
madmaxx's Avatar
Thanks man! I ordered the new bushing from marlin, should have it this week.
James
ghostmoney
Jan 28, 2018 11:42 AM
theking11863
Mar 19, 2016 09:36 PM
Dennisx2
Aug 10, 2015 06:48 AM
TURBOrunnerNM
Jul 20, 2015 08:31 AM
ryerye13
Jul 14, 2015 08:27 AM
