oil pump drive sleeve
Old Mar 6, 2007 | 01:48 PM
toomster's Avatar
This is my second time getting under the timing cover in the past few months. The first time I did not remove the oil pan, this time I did and found about a cup of small plastic chunks from previous timing chain guides. That was obviously taking up surface area on my pick up screen and giving me low oil pressure. Hence me opening up the engine again. The low oil pressure was not allowing my tensor to work properly, so this time I am taking off the timing cover just to make sure nothing else is hooped. In the process though I really want to replace my crank shaft timing gear, and I am having a bear of a time getting that thing off. Has anyone ever developed a sort of trick to getting that gear and the oil pump drive sleave off of the crank shaft?
Old Mar 6, 2007 | 02:51 PM
dcg9381's Avatar
I've never had problems.. just light tapping around the gear.. make sure you do it on opposite sides.
Old Mar 6, 2007 | 03:13 PM
TNRabbit's Avatar
gear/pulley puller? Sears has 'em pretty cheap.
Old Mar 7, 2007 | 02:04 PM
toomster's Avatar
Thanks Rabbit
The gear puller did it finally, that thing was stuck on there pretty good though. Appreciate the help.
Old Mar 7, 2007 | 04:02 PM
TNRabbit's Avatar
Pullers are worth their weight in gold!! Especially when you reach the point of busting knuckles & cussing 'til your out of breath...ask me how I know!!
Old Mar 7, 2007 | 04:22 PM
SoCal4Running's Avatar
Yea that shouldn't be a press fit, I can see if it hasnt been removed in a long time that it might stick a little.
bigjstang
Jun 2, 2025 03:56 PM
Yota.Jay
Jul 23, 2015 08:08 PM
Jnkml
Jul 6, 2015 01:20 PM
toyoda8488
Jul 5, 2015 10:18 PM
HRDC0R19
Jul 5, 2015 06:43 PM
