Rear 4runner seats flip forward?
Old Mar 4, 2007 | 12:28 PM
Kiff's Avatar
So i can see a hinge on the front of the rear seats, but I have no clue how to flip the seats up. My truck didnt come with the owners manual, so I have no clue how to flip the seat up.
Old Mar 4, 2007 | 12:35 PM
4runnerx3's Avatar
There should be a loop, like seatbelt material in the center of each side, pull it to unlock the bottom. You might have to stick your hand between the seat back and bottom to find it.
95 4Runner's Avatar
There should be a loop in between the split backrest and the bottom. If you cant find it then dig around a little. Pull on the loop and the seat will flip up.
Old Mar 4, 2007 | 12:39 PM
waskillywabbit's Avatar
That is only correct for some rear seats as they did not all come with a loop, nor do they all lock. The ones in my 87 simply flip up down, no loop, no lock.
Old Mar 4, 2007 | 12:56 PM
95 4Runner's Avatar
I had the same problem when I first got my 4Runner and that is the answer I got so sorry for relaying information that was given to me previously
Old Mar 4, 2007 | 01:09 PM
4runnerx3's Avatar
Just going by what I have, 86, with 89 seats, 88 and 98 all have loops.
Old Mar 4, 2007 | 01:11 PM
SpeedyJ's Avatar
I have an 86 with loops. They sometimes fall all the way under the seat in which case you need to unbolt the hinges from the cab in order to undo the latch that the loops connect to.
Old Mar 4, 2007 | 01:38 PM
DeathCougar's Avatar
What?? You do not need to unbolt them. Just get your hand down in between the seats, and fish around until you find that strap.
Some runners did not have that strap, but those are non-factory seats. (and by factory, I mean MADE by Toyota, and installed AT the factory). Those were added at the port/dealership when the trucks came in by a company called Kustom Fit in most cases.
Old Mar 4, 2007 | 02:08 PM
90RunnerRed's Avatar
Man, you're on it, I thought I knew a lot about Toys.
Old Mar 4, 2007 | 02:48 PM
SwampThing's Avatar
Hah... It's been a year or more since I remembered that the 1st gen runner's seats will fold down, and I still haven't been able to find my strap. Just haven't gotten around to unbolting the seat yet. And no, I've even dug in there with a 14" screwdriver, and still haven't been able to find that damn loop...
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
