5 speed popping out of fifth. Question
Old Mar 4, 2007 | 09:35 PM
GMJK86SR5's Avatar
going downhill, coasting, the shifter moves out of 5th gear. Is this going to lead to a problem?
Mike
Old Mar 5, 2007 | 04:15 AM
MonsterMaxx's Avatar
Do you have a body lift or has the truck ever been wrecked hard enough to move the cab? If so, check the clearance around the shifter.
Old Mar 5, 2007 | 10:40 AM
Nic's Avatar
Nic
Your shifter bushing and seat may be worn causing this. A simple fix.
Do a search for some info here.
Here's a quick link:
http://www.brian894x4.com/Shifter.html
Old Mar 5, 2007 | 01:26 PM
snap-on's Avatar
+1 for both answers
Old Mar 5, 2007 | 01:39 PM
paxil4x4's Avatar
Drama Queen/Banned
I have seen broken motor and trans mounts cause gears to pop out
Old Mar 5, 2007 | 02:33 PM
Robrt32's Avatar
I have an old 77 f-100 4 speed it jumped out of 3 every since my dad bought it in 99 it still does it, its no worse than it ever was . just frustrating
Old Mar 5, 2007 | 07:17 PM
norcalsvx's Avatar
shift fork might be bent
Old Mar 6, 2007 | 02:54 AM
TNRabbit's Avatar
Shifter bushing as previously mentioned is an easy check/fix. MarlinCrawler.com has a great replacement that you won't have to keep replacing all the time (OEM ones suck @$$ for longevity).
Old Mar 6, 2007 | 09:05 AM
geoff's Avatar
This is an interesting thread! My '88 pickup hasn't had any transmission work ever done, so I can only assume from this that my original shifter bushing is long gone, even though everything shifts OK. How hard are these to replace for a mechanical dunce, and how long does it take? It sounds like the hard part is getting the shifter on and off? Is this whole job a 15 minute affair, or the better part of a day? Anything I should know about potential to majorly screw up my transmission (4 speed - W46 transmission)?
Old Mar 6, 2007 | 09:26 AM
TNRabbit's Avatar
Here's a link; it's one of the easiest things you can do on your truck! Maybe take half and hour for a newb...
http://toyota.off-road.com/toyota/ar....jsp?id=186539
Old Mar 6, 2007 | 09:37 AM
geoff's Avatar
Thanks for the link - I hadn't seen this one before. Sounds like I need to order the parts and tackle this one of these upcoming weekends.
Old Mar 6, 2007 | 12:34 PM
ayoung101's Avatar
mine pops out of 1st gear if i don't hold it in. doesn't affect normal driving too much cuz it's only 1st gear. but since i don't have power steering at the moment (long story, my fault, haven't fixed it yet), it SUCKS when driving in parking lots!
mskalmus
May 28, 2017 07:51 AM
mdev126
Oct 4, 2015 04:48 AM
coffey50
Jul 28, 2015 10:55 AM
kyletbert
Jul 17, 2015 11:39 AM
wilbertd
Jul 6, 2015 07:39 AM
