PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 [65] 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. mass airlow sensor mistake
  2. 91 SR5 doesnt like to go up hill in D
  3. 3vze help! Electrical issues?
  4. 95 3VZ Auto to Manual Swap.
  5. Factory Rear Bumper Question
  6. 91 4runner back window
  7. Steering/Suspension woes
  8. Anyone run a dash cam on their 1st gen?
  9. 22r-22re conversion (84-88)
  10. Brake and running light problem; very strange
  11. interchange between a 1990 T100 and a 1999 tocoma
  12. Can't get manual Runner in any gear! Help me out...
  13. Opinions needed
  14. Installing Marlin's W-56B Short Shifter
  15. 86 Toyota 4x4 radio diagram
  16. 92 4wd clicks twice doesn't engage
  17. Engine replacement, What else should I look for?
  18. U shaped bypass coolant hose on back of 3VZE
  19. 1990 4Runner No Power
  20. 94 Runner 3.0 idle issue and poor fuel mileage
  21. 22re fuel issue???
  22. Manual trans. Fluid change
  23. 2 4runners, Identical transmission troubles -_- No drive / reverse
  24. 4.10 gears on 31s?
  25. Québec law on lifted trucks
  26. 1988 22re: Hoses connected to NOTHING!
  27. Wheel Bearing Check
  28. Rancho 4" lift kit for IFS?
  29. Timing Belt and Valve Cover Replacement Project
  30. 94 Toyota oil pump pickup screen
  31. 3VZE Won't run: Fuel Delivery?
  32. Throttle Position Sensor - Connector
  33. Toyota 22re Head Gasket kit Part#?
  34. 22re timing chain swap - rtv/gasket?
  35. Engine light not throwin codes
  36. 91 yota pickup v6 coolant leaking
  37. 3.4 mt 2wd into a 3.0 mt 4x4 is it possible?
  38. 92 22RE Hard to Start After Rebuild
  39. Starter Trying to Engage without key......
  40. Changing for a 12.5 to a 10.5 Tire
  41. Help figuring out what goes on the left side of my 91 22re block
  42. 88 taillights???
  43. Transmission Drive Shaft Seal
  44. Cross bars/roof rack help!
  45. Tool box size??
  46. OBD 1 Diag port reader
  47. no lights, no clicking, no anything truck won't start
  48. 22RE timing chain guide broken: How can I buy some time?
  49. Help 93 4runner 3.0 stumbles at idle and jerks while driving
  50. Compression Specs on 90 4Runner??
  51. 89 Pickup 7MGE engine Bad oil leak
  52. wth is wrong with my trans?! (video)
  53. Did I buy a bunk engine? BHG?
  54. New to Toyota, Need advice!
  55. Need advice on U-joints for '88 4Runner
  56. 87 4x4 pickup 22r
  57. 89 pickup 4wd shift .
  58. Coolant boiled after drive up mountain with 3VZE
  59. Power steering gear too big?
  60. marlin crawler flywheels
  61. vaccum lines on a 91 22re
  62. Wiring for fuses wrong
  63. Steering clunk noise advice
  64. Tip for hardware replacement: JIS vs. ASTM
  65. leaking front dif fluid
  66. Inspection plate removal.
  67. 3vze top end rebuild...now wont start!! Code 14
  68. TPS setting wacky!!!
  69. transmission swap
  70. Connector identification / What is this connector for?
  71. Gas tank identification
  72. is this the correct TPS settings
  73. Speedometer fix suggestions?
  74. Green pushbutton / factory kill switch??
  75. Egr delete help!!
  76. 1992 toyota pickup 22re wont run
  77. Iacv
  78. *solved* No CEL, cranks but won't start 1986 22re *Solved*
  79. 4Runner Quarter Panel Rust
  80. 4Runner Rust!!! Please Help!!!
  81. 89' 3VZE Runs rough on hot restart, then smooths out, any common causes?
  82. Rear Window Partial operation?!
  83. 1990 4runner 3vze high idle
  84. 91 22re rebuild just froze up
  85. toyota 3.0 oil pump question
  86. Idle drop when brakes applied
  87. Exhaust leak under load?
  88. cruiser coils shocks?
  89. Cyl no.3 misfire
  90. Grinding/vibration noise at certain RPM.
  91. Coolant leak help
  92. Re manufactured vs. Rebuilt 22re
  93. Fuel rail/ injector leak
  94. Massive Fluid Dump
  95. 2''-3'' lift??
  96. 95 runner 3.0 overheat hg questions...
  97. 3vze no compression at all on drivers side bank?
  98. water pump replacement on 94 T100
  99. fuel pressure regulator hose replace/fix?
  100. aluminum sr5 wheels
  101. Source for interior parts
  102. E-brake
  103. What kind of altimeter
  104. 3VZE miss/stumble at idle and off idle
  105. New projects
  106. U bolt size Help!!
  107. turbo cluster in 88 p/u
  108. tb gasket
  109. 89 pickup 3.0 4wd. stuck in 4wd only hi and low
  110. Fuel pump/VAFM relation?
  111. 1989 4Runner Holley Projection, MSD, clicky starter
  112. 3.4 swap cost?
  113. 89-95 Air ride suspension help
  114. Radiator Leak and Front End Vibration
  115. A/C & Heat Panel Lights??
  116. 91 22re 4runner 4x4 5 speed
  117. Wouldn't Be Prudent At This Juncture
  118. Shocks replacement
  119. Shackles to go with an OME kit?
  120. Fuel pressure deops when accelerating
  121. Ticking noise consistent with rpm's
  122. 4.3 swap....timing cover
  123. 3.0 Exhaust/Header question
  124. Grinding & rubbing noise at 40mph+
  125. Hesitation/stumbling upon shifting, loose/low power feeling; inconsistent; 22RE
  126. Intake manifold removal
  127. 3VZE hesitation/stumble
  128. Starts for a second and dies
  129. Very high cold start idle
  130. 1st gen sunroof and cover storage.
  131. Where do these go(gasket set)
  132. Bolt snapped! HELP!
  133. 22re code 71 HELP
  134. Side steps
  135. 1st gen steering wheel
  136. Bio makes new mudflaps! (Ongoing build)
  137. VSV valve help
  138. Fuel pressure/delivery issue - 92 pickup 22RE - what's this sound like?
  139. timing, steering clunk and tcase slop?
  140. Just bought a 94 4x4!
  141. 22r
  142. No Power to Fuel Pump Please help!
  143. Irregular Idle
  144. '86 22r Pickup Clamp on fuel line?
  145. Update on Rebuilt 3.0 from last year 2013
  146. battery cca how much do you need
  147. New project
  148. Headlights dim for fraction of a second
  149. Fuel mileage improvements on the 3vze
  150. 01-03 Tacoma grill on 95 4runner possible?!
  151. First gen 4Runner tops all the same??
  152. 3.GO 190HP Raptor engine install
  153. 1990 Toyota 4Runner New Sound System
  154. Are my ears going to bleed?
  155. Aftermarket front bumper with a body lift
  156. Pinging annoyance!
  157. How much would a Doublecab, Diesel, manual, SFA 4x4 Hilux fetch in Midwest USA
  158. quad spring zuk mod?
  159. Rocker Arms:
  160. 91 pickup 3.0 weird shift into 3rd?
  161. Rear diff rebuild
  162. Shifter Extension
  163. Anything else I should do while I have the intake removed?
  164. 3VZE tick... not valves....
  165. Need Help , what did i break
  166. Ignition coil resistance
  167. Wheel compatibility?
  168. Lostmenoggins 4runner Journal/Diary
  169. Engine Starts, but stalls after two seconds.
  170. What is the deal with OEM thermostat temps?
  171. Can you get a leveling kit for an 89 pickup?
  172. [22re] What's this vacuum connector on the vavle cover?
  173. New 86 4Runner
  174. Clutch Woes
  175. Help! 94 4runner SR5 gets warm/hot after 20-30min of driving
  176. 3vze air idle screw?
  177. change timing chain now high rpm at start up and gas smell from the exhaust
  178. 4 cly into 6 cyl swap
  179. Please help diagnose an engine noise
  180. Cheap aftermarket bumper ideas
  181. Can't get my 87 4runner running... Please help
  182. Reverse Speed Too Fast?
  183. Speedometer not working all the time.
  184. [22re] Erratic knock every few seconds.
  185. Need to source a slightly longer lower radiator hose.
  186. 3rd Gen flatbed build
  187. Surf Diesel Glow Plugs
  188. truck keeps over heating
  189. 89 3.0 pickup hand brake adjustment
  190. 1988 Toyota Truck window channel run Replacement
  191. Speed sensor interchange/ 92 4r
  192. Bought a rust free box
  193. RPM drop very low after/during startup
  194. 22re sluggish at lower RPMs solved
  195. Overheating 22re and no heat through vents.
  196. Carburetor
  197. Is it legal?
  198. How come there are so many rebuilt 22re's?
  199. Help with rear axle noise ( Videos with noise included)
  200. Fuel pump
  201. Thumping front passenger side
  202. igniter problem 1990 yota
  203. 22RE Coolant in oil after overhaul please help
  204. Spongy brake pedal nightmare.
  205. Toytec 2 inch lift kit.
  206. 1993 4Runner 3VZE: Sudden engine drop, then catching.
  207. Engine swap issues....
  208. Touch up Paint - Paint Code 179
  209. Tires are rubbing
  210. Simplifying the 22re
  211. Need help with extra wire on my '87 engine harness
  212. Slim's Free '87 Pickup 22R revival/ 22RE to 22R conversion
  213. Front brake rotors -- recommendations?
  214. SOS 92 pickup 4wd
  215. SR5 instrument cluster question
  216. Headlight spacer part number.
  217. 3.0 Will not restart after starting
  218. the unstoppable oil leak
  219. front brake swap
  220. ball joint question
  221. RN64? It's a mystery.
  222. 1991 2wd Toyota Hilux, 2.4lt RN85 Clutch Issue
  223. alternator regulator?
  224. 1986 4x4 VS 1989 4x4
  225. Odd vibration
  226. What does this rpm adjustment do?
  227. Replaced H/G and Cam...looks like Ill be buying a new head..HELP!!
  228. Error Code14…Bad idle…Missing.Help please
  229. hi i have a 88 4runner
  230. 94 22re slight missfire
  231. 93 XtraCab - 22RE efi - rpm drop in gear
  232. 92 toyota with the 3.0l?
  233. Vacuum diagram for a 1986 toyota 4x4 22r
  234. Help diagnosing backfire
  235. Gas Mileage Drop!! Help
  236. 92 Pickup 5spd refresh
  237. 3vze Valve lash
  238. Truck won't start after heavy rain
  239. jrrtt09's build up of Clay
  240. Gasoline line
  241. drive shaft problems
  242. Rear lights problem, need help asap
  243. 3.0 wont start
  244. Toyota 3vz Headgasket Recall Predicament
  245. Idling problem after driving
  246. 93 4runner differential
  247. Idle screw tension
  248. 93 4runner trans
  249. 95 4 runner V6 3.0 Manual- just bought need help!
  250. Trany issues, clutch slipping??
