water pump replacement on 94 T100
Old Mar 11, 2014 | 01:03 PM
Heather123's Avatar
is there a schematic or diagram for the proper installation anywhere online? I assume u have to pull everything by looking? was quoted 1100 by repair shop, can i do this myself easily?
Old Mar 11, 2014 | 01:55 PM
Sturmcrow's Avatar
Assuming it is the 3VZE (V6), look for protocols on changing the timing belt. Typically you will want to change water pump and timing belt at the same time, since both are in the same place and a huge PITA to get to.
Nothing about the job is hard, except maybe getting the crank bolt off. It is very time consuming, hence the huge labor charge.
Old Mar 11, 2014 | 02:00 PM
scope103's Avatar
http://personal.utulsa.edu/~nathan-b...09waterpum.pdf
http://personal.utulsa.edu/~nathan-b...67timingbe.pdf
Old Mar 11, 2014 | 02:08 PM
Heather123's Avatar
THANKS! I got it figured out now, hubbys off getting new parts, guessing it wont be ready for work tomorrow... pics help a lot!
Old Mar 14, 2014 | 10:45 AM
Turbo_4runner's Avatar
@ scope103 Thank you for the links....I'll be breaking down my 94 4runner next week hopefully!
Old Mar 14, 2014 | 01:57 PM
vital22re's Avatar
totally a bro
To do this properly, you should replace the idler pulley and the tensioner pulley as well as the cam and crank seals.
bigjstang
Jun 2, 2025 03:56 PM
mskalmus
May 28, 2017 07:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
