22re sluggish at lower RPMs solved
Old Mar 4, 2014 | 08:20 AM
Sandman's Avatar
I'm just posting this in case it helps someone else.
symptoms: sluggish power below 2500 rpm, low idle rpm
no check engine light
tried: replaced wires, plugs, cleaned throttle body, checked tps, AFM
unplugged the O2 sensor and it ran much better (open loop)
Replaced the O2 sensor and it solved the power problem. Runs like a champ now.
Old Mar 4, 2014 | 08:37 AM
FGZ's Avatar
FGZ
I had similar symptoms, but it ended up being loose band clamps between the air box and throttle body. Just FYI for others with sluggishness. Glad you got yours worked out!
montanatruck
Feb 26, 2017 07:07 AM
PlayAwhile
Jul 20, 2015 11:36 AM
ty1er
Jul 19, 2015 06:42 PM
Jeffreynmandy
Jul 18, 2015 08:26 AM
redghost.308
California SoCal
Jul 16, 2015 07:46 AM
