1990 4Runner No Power
Old Mar 19, 2014 | 05:16 AM
Rockta's Avatar
90 4Runner V6. Has almost no power starting from stop. Transmission rebuilt and engine tuned. Ideas?
Old Mar 19, 2014 | 11:23 AM
DannyD's Avatar
Any misfire or hesitation? If not, i had a similar issue due to the throttle cable. Check out this post https://www.yotatech.com/forums/f116...08/?styleid=41
Old Mar 19, 2014 | 02:11 PM
spaceman's Avatar
welcome to owning a 2nd gen 4runner.
just kidding, are you getting any codes? What do you mean engine tuned? What did you do to it?
Old Mar 20, 2014 | 04:55 AM
Rockta's Avatar
To DannyD
Dead on answer - thanks. Rubber spacer was split. Put a tube around the cable and zip tied it. 100% improvement.
Old Mar 20, 2014 | 04:57 AM
Rockta's Avatar
Codes
How do you read the codes on this thing? Check engine light is on but the standard ODB reader doesn't fit connector. Without going to a Toyota dealer how do I read the codes?
Old Mar 20, 2014 | 05:44 AM
DannyD's Avatar
Awesome, I knew I couldn't be the only one with this issue. As far as the Odb port, do you have a ODBII scanner? If so it wont work. That wasnt standard till '96. You will have to use the diagnostic port
Old Mar 20, 2014 | 06:01 AM
Rockta's Avatar
codes
Understand that. So where is diagnostic port and how do I read it? Is there a device or connector? Tx
Old Mar 20, 2014 | 06:15 AM
DannyD's Avatar
Its under the hood behind the battery. I'm doing this from memory, but you turn the car off, jump E1 and T E1 with a paper clip and turn the key . Count the flashes to get the code number. Do a search to find what the codes mean. I think its also in the user manual that came with the truck if you have it.
Jun 1, 2021 01:51 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
skoti89
Jul 8, 2015 12:05 AM
ptb12
Jul 5, 2015 01:49 PM
