My 3.0 is no longer slow! (throttle cable)
Old Feb 17, 2014 | 02:42 PM
DannyD's Avatar
When I bought my 4runner a few weeks ago it was not running, so I never got to test drive it. After fixing the timing belt and getting it running I was incredibly disappointed in how slow it was. I know they are called 3.slows but it was much worse than I expected.
After doing fuel filter, plugs etc I was seeing no improvement. Today I had my son floor the gas pedal (while it was off) and I noticed the throttle was not opening all the way when he did this. I looked at where the pedal attaches to the cable and found the rubber spacer was split and the was a lot of slack in the cable. I zip tied it back in place and its a HUGE difference. I guess my throttle was only opening 50-75%.
I'll have to see if this holds up. I might need a new throttle cable.
Attached Thumbnails My 3.0 is no longer slow! (throttle cable)-20140217_153908.jpg   My 3.0 is no longer slow! (throttle cable)-20140217_162421.jpg
Old Feb 18, 2014 | 10:55 AM
Sturmcrow's Avatar
My spacer was split like that when I bought it too. I just wrapped electrical tape around it and it has held for 1.5 years now. I imagine your cable ties will last forever!
I did not notice that mine was any slower due to the split spacer, but I did notice that I had to push really hard on the pedal and it was hard to let the clutch out smoothly (due to the pedal return spring being so wound up before the throttle actually opened).
Old Feb 18, 2014 | 01:50 PM
RJR's Avatar
RJR
I had the same problem. Seems to be designed to fail after 20 years and 150,000 miles:-)
I think I made a new spacer out of some heavy duty rubber hose and fastened it on with zip ties. That was 4 years and 40,000 miles ago.
Old Feb 18, 2014 | 02:47 PM
DannyD's Avatar
Sounds like mine should hold up then. Nice to find an easy fix for once.
Old Feb 21, 2014 | 06:12 AM
BioHazard050's Avatar
Hmm, where is this connection located? Up under the dashboard or is it in the engine bay? Cant tell from the pics
Old Feb 21, 2014 | 06:29 AM
DannyD's Avatar
This is at the top of the gas pedal. It kinda tucks up under the dash
Old Feb 21, 2014 | 07:52 AM
Thanks,ill take a look at mine.
Old Feb 21, 2014 | 08:39 AM
81 Toyo's Avatar
Yeah I need to check mine, its nice when the fix is that easy! Thanks for the tip.
Old Feb 21, 2014 | 12:59 PM
99SR5's Avatar
well looks like i have to check mine now....
Old Feb 22, 2014 | 03:39 PM
reallifedog's Avatar
Awesome thanks for posting this, I honestly didn't even consider this to be the culprit
Old Feb 28, 2014 | 06:01 PM
Troy Davis's Avatar
kazuya2416
Apr 5, 2024 02:17 AM
Jun 1, 2021 01:51 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
rbh261
Jul 13, 2015 12:04 PM
