PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. ISO: A340H ECT computer
  2. Using EFI Relay gound
  3. 1989 Pickup Heater Core Connector Pipe help
  4. Hot start Timing chain rattle
  5. 22r igniter wiring
  6. 3.0 engine rebuild
  7. Snorkels!
  8. Shutdown
  9. '91 4Runner 3VZ basket case
  10. Mystery Leak/Mystery Hose/Exhaust Options!!
  11. 86 4runner Wiring Harness versions??? Having Issues
  12. cold start --weak start
  13. No brakes!
  14. Opening up tailgate with no power, Window up
  15. Short bed to Long bed swap
  16. 1990 3.0 tps stalling engine
  17. 1989 4Runner rear window not working
  18. Leaky thermostat housing - missing gasket?
  19. 1986 22re Distributor Rotor Question OEM Two Part Numbers
  20. 89 3.0 won’t start
  21. 3vze injector power
  22. Proforged idler arm differences
  23. Head gasket or cracked head/block?
  24. Digital dash speedometer calibration help
  25. 3100 rpm squealing
  26. Please post your conclusions.
  27. 22re oil pump bolt leak!?
  28. Tachometer issues
  29. Help with 1990 Truck
  30. Rod bearing caps loose
  31. Help Requested - Unknown Connector @ Intake/Valve Cover
  32. My first 4x4 build (1st gen 4Runner)
  33. Rear diff locked up
  34. Transmission won’t go into first gear
  35. Let's discuss brake fluid in our non-ABS trucks...
  36. 94 V6 Pickup Dies after Valve Cover Gasket Install
  37. 89 pickup wireing question
  38. 89 pickup wireing question
  39. problem with redline stock aircleaner to weber adapter
  40. Water Bypasss hose ???
  41. Rear bumper from the scrap pile ...
  42. 22re fuel pump issue
  43. Door Lock Adjustment. driver's door will not open
  44. Aftermarket FPR ?
  45. Anybody have one of these?
  46. 22RE Stuttering / Bogging under load
  47. Exhaust Replacement Question
  48. 1988 3vze 4x4 heating woes and questions.
  49. Parts Compatibility between 1993 Trucks & 4Runners?
  50. Radio help - very little sound
  51. Tea kettle from hell
  52. Blower resistor
  53. Cooling and Heating fan issue
  54. 1987 4Runner Dash Safety Pad restoration
  55. Sometimes being stupid allows one to find smart solutions.
  56. leaking backwindow
  57. Will a 22re Manual Transmission Bolt Up To A 3.0?
  58. 1986 4runner 22re AC Manifold Service Fittings r12 to r134a
  59. New fuel filter spraying gas
  60. Toyota Pickup - Antenna Assembly Broken & Possible How-To Fix
  61. Rear side Window latch broke
  62. 1991 pickup door hinge-pin: Dorman Tacoma kit compatible?
  63. 22RE Mechanic N/W FL
  64. Who says these trucks don't have headlight relays stock?
  65. Engine quits when put in D or 4L
  66. 95 4runner with 3vze needs help!
  67. Exhaust Placement for Protection from Off-Road Elements
  68. Mass Air Flow Sensor
  69. 1994 pickup tranny line
  70. 92 Pickup Seal Between Transmission And Transfer Case
  71. 1990 Pickup Dash Connector Identification
  72. So, my 1986 Toyota 22re 4x4 Needs a New Engine
  73. Water Pump
  74. Lifter Tick question
  75. 90 runner valve replacement
  76. leak between master cyl and booster?
  77. Rough idle, running rich, black smoke
  78. Rear wheel seal parts needed
  79. Timing chain inspection methods
  80. A340H output shaft seal
  81. Timing Cover Leak fixes
  82. Speedometer drive unit question
  83. Rear Suspension question
  84. 3VZE Hard to turn over Please Help!
  85. Cruise Control
  86. 89 Pickup, 3VZE starting issues
  87. What gasket is needed to fix this leak?
  88. 22R vacuum advance smog delete
  89. Need help on leak-down test results
  90. Backup Lights & Blower - Wiring - 89 Pickup
  91. '89 pickup 2wd 22RE manual steering gear
  92. brake/tail/reverse lights off ecu or switch?
  93. Sunroof switch
  94. Dented / crooked fuel filter, harmless?
  95. Truck/4Runner Updates
  96. Successful tranny swap... almost
  97. 1990 throttle body
  98. Are these numbers REAL???
  99. 22re & 22r-e oil separator/ catch can
  100. School me on lighting upgrades for interior and exterior
  101. 91 4Runner engine service
  102. H4 LED headlight wiring harness
  103. ISO: Rear Glass
  104. Well, what day. FIRE!
  105. Great Assets
  106. '95 4runner 3.0 sounds like rough running lawnmower
  107. Another 22re engine rebuilder question. Need suggestions and feedback/reviews
  108. 1988 Toyota Pickup Horn
  109. 1993 4 runner 4x4 low idle at traffic light
  110. 3vze head gasket job - block inspection help
  111. Rear lift on my 93 runner
  112. Rebuilt 22re Head gasket leak???
  113. Spun Bearing damaged caps advice request
  114. New timing chain
  115. Headlight Wiring Harness - Feedback Requested
  116. ‘95 Tacoma no power
  117. 1987 22r-te tps
  118. 1986 pickup auto trans shifts higher than selected gear
  119. 1988 Toyota Pickup: Blown Headgasket?
  120. Power Steering hose info - 93 2wd 4Runner
  121. Dust covers for front brakes
  122. 95' 3.4 swapped with a 93' 3.0?
  123. 4Runner Downshift issue
  124. Fuel Pump Flow Through
  125. 1988 Toyota Pickup Tail/Dash lights intermittent
  126. 88 Toyota Pickup cab swap onto a 92 Toyota Pickup 4x4
  127. 92 3.0 5-speed. Electrical issue?
  128. Leak behind the transfer case, need some advice from the experts.
  129. 1998 4WD Pickup Steering Box Rebuild Problem
  130. wiring question future winch
  131. 2nd gen 4runner custom front and rear bumper plans
  132. Power Steering - ATF Aerated and Coming Out of Cap
  133. 22R-TE Radiator
  134. '92 Pickup Parking and Dash Lights Out
  135. 1993 truck 22re 4x4 automatic
  136. 22RE owners - how many miles for your oil changes?
  137. Properly installing Ferrule Cable Stops on E Brake line
  138. Massive oil leak from above bellhousing
  139. Cleaning Intake and Other Parts for Rebuild
  140. '86 4runner rear window issues
  141. 3vze evap can longevity?
  142. Transmission oil change?
  143. Fuel Gauge Trouble Shooting 1987 Pickup
  144. Fix for rusty rear fenders -88 4runner
  145. Help identify parts 94 4 runner 3vze 5 speed
  146. 1st Gen 4Runner Hardtop Dirt Streaks on body
  147. Temperature Gauge faulty - 22R Gas
  148. 1992 Toyota Pickup Keyless Entry Install
  149. Power Steering: 22R-E
  150. Inner cv axle nuts seized
  151. Rear transfer case seal and bearing replacement
  152. Don’t do what I did removing plenum
  153. Squealing Belt 1987 Toyota P/U 22R
  154. 14 inch tires are getting hard to find for 2WD pickups. Found something decent.
  155. Head Gasket Failure at 299k Miles
  156. 87 4Runner Turbo
  157. Removing Oil Cooler Line Help
  158. Occasional scary grinding noise - 1988 4wd P/U
  159. 3vze wont start after headgasket job
  160. 1991 Pickup, no lights or power.....
  161. Manual transmission making “ice maker” noise.
  162. 😂 carbon canister clogged with mud
  163. oem hardware kits
  164. 1987 toyota pick up 2wd rear axle question
  165. Rear Diff Leak
  166. idle surge when warmed up?
  167. Replace power antenna
  168. Found the original invoice on my 1992 Pickup. MSRP $8,998!
  169. Going to the Pick-a-part! What are some must-grab items?
  170. normal exhaust temperature
  171. New Front Wheel Bearing Won't fit on Spindle
  172. Hard to start when my 93 4 runner after an errand run
  173. Ditch light for 93 4 runner
  174. Replace headlight socket
  175. Intake Manifold Replacement Results in massive exhaust noise
  176. 87 4Runner - How are RH and LH ball joints different?
  177. Tail lights dead/wiring madness
  178. Larger battery for 1993 pickup with 22RE?
  179. BMW E92 seat install
  180. 22RE cold idle
  181. Idle surge issue with 22re?
  182. Help with pulling driver side master lock switch apart
  183. 22r to 20r swap
  184. using stock air cleaner with weber 32/36 carb
  185. Normal for a 320,000+ 22RE to not burn any oil?
  186. Possible idle up solution for weber carb, or bad idea.
  187. 22RE fuel pump/cold start injector Bosch 4 hole spray
  188. Rear Sliding Window Seal Clip?
  189. 1995 4runner auto to manual swap
  190. Grinding after new brakes.
  191. No dash lights PITA
  192. How to fill transfer case?
  193. Which gears do i need?
  194. Need help tracking down a grille
  195. 89 22re bucking/hesitation surging idle
  196. ISO 86 22re ECM
  197. The FAQ being asked again - 1988 Toyota Pickup
  198. Spindle wear diagnosis. Resurface or replace?
  199. Cold exhaust on cylinder 3
  200. Dual-Battery System With Voltage Sensitive Relay
  201. Rear Passenger Cubby
  202. center console dividers
  203. 1991 toyota surf alternator help
  204. Power Steering Woes
  205. What's a Reasonable Price?
  206. 3vze surge while driving only
  207. 86 4runner Steering column cover
  208. 92 grill on an 87??
  209. Piecemeal Axle hub gaskets?
  210. Binding manual driver's door window
  211. Starter jump solution?
  212. Transmission
  213. 1994 Hiace Super Custom
  214. 4 Speed Auto A340H service manual
  215. Speedometer Update
  216. Here's a cheaper alternative to OEM 22RE dual stage thermostat
  217. help witha 1991 toyota surf alternator issue
  218. Does Anyone Recognize This ?
  219. a FNG..please help locate parts
  220. Help identifying exact year and drivetrain of my truck
  221. o2 sensor, ox1 and vf1 readings
  222. Control arm mount replacement - anyone done this?
  223. 89 Toyota picup cluster
  224. Clutch issue
  225. Off idle stalling issue 94' 22re
  226. 22RE Starts Then Dies After A Second
  227. Mystery wire coming from auto trans
  228. 1988 supra seat swap in 1988 4runner. ( Need help wiring up )
  229. 91 4runner 4x4 not working
  230. 91 4runner 4x4 not working
  231. 1990 needs new legs. Tie rods? Shocks?
  232. G54 to W56 Transfer case Help
  233. Bypass Hose Leak 22RE
  234. 3vze oily smell in Recirc mode
  235. My 92 yota keeps stalling
  236. The check engine light is missing
  237. 1986 4runner back glass
  238. Cold start injector sprays, but still no start
  239. Are gaskets needed for 22re front cover?
  240. 3VZE really loud until 3k RPM
  241. Anyone help identify my side mirrors?
  242. intermediate miss
  243. Mystery sensor
  244. Trouble shooting
  245. Spark plugs rich, exploded muffler. Help!
  246. Fuel problem???
  247. 22RTE turbo overboost / advice
  248. New to me truck
  249. New to me truck
  250. 87 4Runner IFS - Upper Arm Shaft position question
