Rear diff locked up
Old Jan 17, 2021 | 04:51 PM
2door2ndgen's Avatar
Rear diff locked up
Hey all,
First time poster here. I’ve got a 2 door 2nd gen 4runner that got handed down to me through family. It was pretty neglected in term of maintenance so I gave it a full service replacing oils, filters, grease etc. Recently my dad took it out for a drive and smacked the front underside pretty hard (I wasn’t there) and since then it’s been stuck in 4WD and the LSD rear binds up around corners. Wondering if any of you have any ideas on how to fix?
Cheers heaps
Old Jan 17, 2021 | 05:25 PM
Blueman's Avatar
What year is the truck? Which transmission does it have? Best to add that to your signature.
Was the LSD from the factory or aftermarket?
Old Jan 17, 2021 | 05:38 PM
Manual and to my knowledge it’s factory. Pretty sure it’s only been lifted in terms of mods. 1989 is the year
Old Jan 18, 2021 | 09:43 AM
scope103's Avatar
Are you sure the differential is locked? A vehicle in 4wd will "bind up" noticeably on corners. (Vehicles with "AWD" have a center differential, or something like that, to allow the front and back axles to rotate at different speeds. You don't have that.)
Jack up both rear wheels, and spin one. If the differential is working (and the vehicle is in gear) the other wheel will rotate freely in the opposite direction.
My first guess is that you have a bent linkage holding the transfer case in 4wd. Have your Dad climb underneath while you try to shift the transfer case.
Old Jan 18, 2021 | 02:22 PM
swampedout's Avatar
5 Year Member
Manual hubs?
Old Jan 18, 2021 | 03:32 PM
Robert m's Avatar
I remember reading that none of these trucks and 4runners came with any kind of limited slip or locker until the tacoma and 3rd gen 4runner came out
Old Jan 19, 2021 | 03:09 AM
arlindsay1992's Avatar
There was no factory limited slip in a first or second gen 4Runner. Who knows what's been added since it was new? A limited slip can't really bind by it's nature. Even if it somehow became fully locked, it would just scrub the tires going around turns.
I think you need to investigate the fact it's stuck in 4x4. Even with open diffs front and rear, if you have it in 4x4 on pavement it will bind up and eventually feel like it doesn't want to move at all.
JWaldz
33
Nov 20, 2009 10:08 PM
ohioyotaguy
7
Dec 19, 2007 06:16 PM
snafu560
Dec 2, 2006 05:50 PM
Extremesolo
Feb 10, 2005 05:05 PM
