06 taco locking rear diff
Old Dec 6, 2007 | 09:01 AM
ohioyotaguy's Avatar
Should I be able to lock my rear diff on my 06 trd tacoma 4x4 in 2wd? I can and was just wondering if this was normal. Also, on the wife's 08 4runner, what is the benefit of the locking center diff? Sound like an all wheel drive option to me. Why not just lock in 4wd when needed? Thanks.
Old Dec 7, 2007 | 05:35 AM
juddemt's Avatar
You shouldn't be able to lock the rear lock diff in 2wd, only 4wd Lo. The light will be solid on, not blinking. If you get a solid light for your locker in 2wd without a mod thats pretty cool.
Old Dec 7, 2007 | 05:52 AM
X-AWDriver's Avatar
True 4wd and part time 4wd aren't the same and AWD is preferred when driving on hard packed slick surfaces and pavement.
Old Dec 7, 2007 | 05:57 AM
AppleJack's Avatar
I would like to say that if you can lock your rear diff in 2wd drive, you got a cool factory defect. As for the center diff on your wifes 4runner, the purpose is to split the torque front to rear 50/50. Typically the torque split would be something like 70/30 R/F, to compensate for uneven terrain. Much like locking the rear diff, locking the center diff is for the more serious terrain your likely to encounter, and should be used at slower speeds.
Old Dec 7, 2007 | 08:37 AM
ok, so my truck is defective from the factory. Good and bad I guess. Applejack, nice ride. What lift and tires?? Looks awesome. I'm about to lift mine.
Old Dec 14, 2007 | 01:39 PM
AppleJack's Avatar
Thanks! I have a 2in. spacer lift. Not the way to go, but I bought it that way. I am going to go with an OME kit a little later. As for tires, I am running 265/75 Toyo M/T's.
Old Dec 16, 2007 | 07:33 PM
dropzone's Avatar
Fossilized
probably the "Grey Wire Mod"
Did you buy your truck used? There is something called like the 'grey wire mod' (not exactly sure if it is a gray one on the '05+) that allows you to override the 4WD Low requirement for using the rear E-locker. It is possible a previous owner may have done this to your truck. I doubt it was done from the factory.
Stole this post from ttora.com:
Originally Posted by tacosupreme
I'll help you out a little- The numbers/pins for RadioShack Relay# 275-218.
Remember the wires on the ECU side of the cut should be dangling, except for the violet wire that just gets tapped. The violet wire is the power wire for the 4WD ECU, so juice still needs to flow through it.
‘Lt Blue’ = 6
‘Lt Green’ = 5
‘Pink’ = 4
‘Lt GN/Black’ = 1
‘Violet’ (a.k.a purple) = 2 & 3
‘Red/Black’ = 7
‘Wht/Blk’ = 8 (ground wire)
**Disclaimer: This would allow you to use the locker in 2WD at any speed...use at your own risk...
you might want to check out this folder on ttora.com
good place for some more info on the '05+ taco's
http://www.ttora.com/forum/forumdisplay.php?f=157
Old Dec 19, 2007 | 06:16 PM
dropzone's Avatar
Fossilized
Also take a look at the sticky on the '05+ lockers at the top of this forum folder...
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
Daneums
Aug 20, 2015 05:36 AM
deepmarsh
Aug 6, 2015 03:44 AM
icentropy
Jul 14, 2015 10:23 AM
