Are gaskets needed for 22re front cover?
Old Nov 9, 2020 | 10:05 AM
BobJ's Avatar
Thoughts on whether gaskets must be used on the front timing cover? It's two machined surfaces so I used silicone, now starting to second guess myself. If it was solid axle truck I wouldn't have a problem with silicone, but IFS is a real pain in the **** if it leaks after putting motor back in.
Thanks.
Old Nov 9, 2020 | 11:08 AM
snippits's Avatar
I don't think it's absolutely necessary just as long as you used some high quality gasket maker. When I did cylinder head gasket and timing chain on my 92 22RE 3.5 years ago, I did use the timing cover gaskets coated with Permatex High Tack on both sides. No leaks so far.
Old Nov 9, 2020 | 11:55 AM
2ToyGuy's Avatar
As I understand the set up, the "gasket" for the front cover is just a thin piece of paper. I would personally use a good RTV type gasket materiel.
That's just my opinion, though.
Pat☺
Old Nov 9, 2020 | 01:42 PM
slacker's Avatar
I've seen silicone used many times with out problems
Old Nov 9, 2020 | 02:50 PM
dzldust's Avatar
Same here ,used thin coat of Rtv,tighten top bolt down through head first ,then the rest
Old Nov 9, 2020 | 06:21 PM
Co_94_PU's Avatar
Technic is important when using rtv for gaskets
Old Nov 10, 2020 | 07:34 AM
Jimkola's Avatar
YT Community Team
5 Year Member
I like using the factory paper gaskets with GasketCinch, But that's just my preference.
I think sealant should work fine as long as the surface is properly cleaned.
Old Nov 10, 2020 | 09:17 AM
keycw's Avatar
5 Year Member
i just did the timing chain on my 20r and used the paper gasket with toyota fipg on either side.
Old Nov 10, 2020 | 09:47 AM
BobJ's Avatar
That's reassuring, thanks for replies. Never had an issue with silicone but thought I would ask.
Learning
Jun 11, 2019 09:26 PM
irv
Oct 23, 2018 02:46 PM
andrewmaciag
Jun 17, 2018 05:24 AM
tyzzz321
Jun 17, 2009 08:05 PM
4x4Lamm
Aug 30, 2004 02:11 PM
