- A43D automatic.
- how many miles you got
- turn signals not working
- 91 toyoto want idle right when it warms up?
- my return to forum/3VZE problems and project
- Proof of concept in checking for o2 shorts
- Replacing TPS
- Oil pressure on the 22RE
- Brake line length - 88 longbed?
- Snapped sensor (?) under oil filter.
- rear window key swich not working
- really bad idle problems and surging with lil power going down the road
- Driveline vibrations? Here's how you fix them. (video)
- 3.0 idleing problem
- '86 22RE 4Runner alternator fire
- CB location
- Looking for mods on 1995 4runners
- 88 4runner tail and dash lights not working
- Loose headlight
- Upgrade on lights?
- 89 toyota wont start
- looking for a 91 or 92 FSM factory service manual, my ECU is a 91
- confused in reading FSM ECM ECU connectors
- need help my brakes failed!
- 91 2WD - 4x4 conversion? long travel?
- Tailights, Parking lights and dashlights 1993 Toyota Pickup
- Loss of fuel while driving, now truck wont stay running
- 87 4 runner turbo conversion
- detroit locker or truetrac
- Whos truck is this!?
- Rear driveline not sitting flush on flange.
- looking for diff info 90 4runner
- 94 toyota pickup 22re ticking noise
- Left key on, now won't start
- 91 4x4 pickup is up and running. Timing???
- rear differential pinion nut torque?
- interpreting AFM resistance readings
- new member old yota
- Air shocks/springs
- 86 auto erratic shifting
- Clutch problems, 1993 2wd truck . . . .
- Anyone use ITM or DNJ stuff?
- noob doing SAS
- Lack of power, poor mpg, then catastrophic failure.
- 1st gen grille swap
- Need Injector help For 3vze
- Stupid question: where do you hook up a 2-wire dwell/tach?
- Starting up 88 EFI fuel system 'prerequisites' ?
- CSF Radiator Drain Plug
- 1994 Specific Truck Issues to Look for
- SAS vs OEM SFA
- What gears did I just buy?
- Difficult to turn engine by hand - spark plugs removed
- Diagnostics for EGR/Head Gasket/Intake Gasket
- ARP head studs wont clear the valve cover.
- Front Diff Seal Question
- need help quick! filling transfer case
- 3vze powerloss/hesitant/bad mpg
- 94 22re 4x4 Bad gas mileage
- starting problem
- frame holes
- Injector Insulator
- 88 ifs problems(lifted)
- 89 4Runner AT oil temp, parking break light and battery light all came on today
- Wheels that fit my 1990 4Runner
- sunroof= no map light switch?
- If You Run Flamethrower Injectors In Your 3VZE
- Soon to be acquired 89 single cab 4x4 ?s
- 93' pick up BOTTOM END?
- T-case leaking after dealer flushed transmission
- Replacing front cv shaft
- 95 4runner v6 3.0 cold air intake
- calipers locking up on my 87 yota
- 3vze coolant leak
- 22re idle drop when I stop?
- Stuck fuel check valve
- Cleaning Idle-Up actuator/diaphragm
- Knock Sensor Issue.
- can't stop power steering pump leak
- 87 22r tbi or efi conversion kit?
- Front skid plate tips and recomendations
- 1991 Toyota Pickup Payload
- build, bitching and advice for first timers like me
- 1987 Pickup DIY Headache Rack
- fuel filter hell
- 1st Gen 4Runner ripoff
- o2 sensor choice
- Problems with my Truck...and Now Burning Oil Too?!
- NEW truck help please!!!!!!!!!!!!!!
- Body piece identification? 88 pick up
- 1988 4runner 22re severe hard start issue
- Need someone who knows codes!
- 95 4-runner intake issues
- Best traction tires for on-road driving
- 1995 4runner lift
- Toyota SSX3.0L Surf Turbo Diesel Snorkel advice
- Priming oil pump?
- Crank shaft front seal numbers
- Gear color?
- Injector timing switch help !!!
- 86 starter ?
- failing sensor don't know where to start
- 94 3vze ecm swap
- starter replacement help please ;(
- steering wheel axle/nut stripped
- 89 2wd 22re
- 94 Runner Wouldnt Start - Battery is fine
- 5MGE Swap on IFS First Gen?
- Tacoma conversion on 88 pick up
- Frame Swap: Yes or No
- Anyone owned both 4 Runner and Pickup? Prefer which?
- Mysterious leak...ideas?
- Gas cap question ?
- Idle surging after cleaning throttle body
- snapped new timing chain
- mid rpm knock - diesel also at gear change
- Problems after Flamethrower injector install
- Has Anyone Ever put A 2RZ-FE In A 2nd Gen Runner
- How Tension Alternator Belt
- Rebuilt 22re runs rough SOMETIMES (sounds like a diesel)
- starter brands
- need help with engine
- new
- Manuals
- Head Gasket Prep Pre-Job
- help on 1 ton axle swap
- 86 toyota pick up needs help!
- Oil leak question.
- Trouble removing front driveshaft
- flatbed ideas
- 4wd problem
- Check Engine Code #3 & #11
- Possible swap from auto hubs to manual?
- No brakes
- Coolant streaming out of cylinder head
- 3VZE. 3 CYL Misfire. Recall Issue. Experts needed.
- randomly stuttering , missing 22-re
- 4runner rear window problem
- transmisson & 4*4 trans axle oil
- Source for 88 rear bumper caps
- I know it has to be around here somewhere...missing horn wire.
- Misfire, glowing header, on fresh rebuild.
- '91 4runner engine performance issue (v6)
- 5speed swap link?
- Removing power steering pulley bolt
- Does the VAFM always sound terrible?
- need help 88 yota
- 22RE No hot start - gremlins!
- 3VZE Tachometer not reading properly
- Best Oil and Filter Combination, 22-RE
- Is dynomax the only "off the shelf" catback exhaust available?
- My exhaust smells like firecrackers
- 95 4 runner: clutch goes to the floor
- 3vze to 5mge
- fuel pump fuse trips when I check error codes.
- AC compressor clutch and coil
- 1993 pickup U bolt flip kit
- Randomly won't start this morning (VIDEO)
- Cal-Cat
- 1994 4X4 Truck extra Cab Seatbelt Swap
- Loud "POP" and it died!
- Toyota v6 3.0 oil leak?!
- Where is the 4th ground ?
- stock brakes advice....
- 4runner console with rear heat in pickup
- Quick axle question !!
- 86 flywheel help
- clunk noise when suspension compresses?
- Tacoma E-locker in toyota 4cyl rear end?
- Who can help me find the correct radiator?
- Big power loss!!
- remanufactured 22RE break in
- 22re blown head gasket options
- braided stainless steel lines - where do you buy em ?
- 1988 2wd 22re into 1988 4x4
- Real or Myth? Solid Rear Window for a 1994 Toyota Pickup DXL?
- 1988 22re 4Runner SR5 - No Vacuum
- Replacement antenna assembly
- Mystery oil loss. '89 22re
- Emblem clips, B-Pillar
- 1991 Pickup - Noises in 4x4 mode
- Coolant boiling in reservoir, and no hot air in cabin
- 3VZE 3rd Blown HG Questions
- 1991 4x4 3.0 error code 43
- Can I swap my 22R for 22RE by swapping heads?
- how do I adjust my valaves? 3.0 SV-E
- Bad Oil Pressure Gauge
- Transmission swap gone wrong (maybe), need help!
- Starter/Electrical Problem
- New member with a '94 reg-cab 2wd pickup.
- headlights cutting out/ need parts info
- Transmission Problem (...Overheating??)
- 3vze newbie help needed
- My 87 Build up thread
- 1990 Toyota Pickup Plow truck build....need suggestions
- 1994 4runner Manual Transmission stuck in 5th Gear
- 89 pickup 4x4 suspension help
- 86 4Runner Roof Rack
- PCV causes a smoking tailpipe.
- 85 22re help!
- So I got these clear 4Runner headlights..
- misfiring only when warm and only when idling?!
- 93 4runner 3VZE bogging down, slow/hesitant acceleration, poor mileage
- 93 4x4 22re slightly overheating
- Went out for fenders... came home w/a 4Runner
- Lextreme's 94 V6 Pickup Resto/DD
- 88 22RE Will not stay running.
- Pre fabbed rear tire swing out for 2nd Gen 4Runner.
- 1st gen 4runner (how to be seen on the road)
- oil leak fom the wheel. check it out
- Favorite 'Yota memes
- Low Compression After Rebuild
- Front Parking Brake Cable Assembly
- 1986 pickup crank-no-start
- No Idea of Worth
- 95 'runner 3vze Heads stuck?
- what's this noise? (video attached)
- check lamp wont blink
- 1987 throttle position assembly issue
- pulling a 6x12 enclosed trailer
- weird engine breaking sound when let off gas on highway
- New seats.
- light bar questions
- My ISR and Cold Intake, yeah another one...
- Cheapo clutch set for mostly daily '88?
- Help needed, remote engine starter
- Greasable points?
- 91 pickup 3vze 5 speed, lost my vss signal, do i need it?
- sway bar/stablizer bar bushings?
- 1992 Pickup Wont pass SMOG
- G2 solid pinion spacer, does not fit on Yukon pinion
- ID of rear frame.
- Finding Parts for a 1994 Toyota Pickup
- E-Locker Donors
- Lifting, need tips and thoughts
- Please give me some help 22r sputtering bad under load
- Wiring issues
- 22re acting up please help
- Re-Route Evap Vent Line
- Replacing side view mirror on 93 pickup
- Post video clips of your YOTA
- 22re runs at half temp all the time, fan stays on
- 22R Hot Restart Issues
- still no timing advance
- Problems with tie rod ends and Pro Comp lift
- Downey headers question...
- Hood is hot, engine is not...?
- 529 gear install
- **95 4runner questions**
