PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 [132] 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. ignition or fuel issue? 89 hilux pickup
  2. Coolant leaking from rear of block Need Help
  3. Transmission Swap tips/suggestions?
  4. Problem: Hard to shift gears.
  5. misfire/rough running 22re
  6. '90 4runner starter solenoid switch
  7. Low speed vibration when turning
  8. Problems with the w-56
  9. installed OME 900's
  10. 3vz-e people what is this plug for?
  11. Name that engine sound
  12. how to replace clutch with headers installed?
  13. New MaxBore TB
  14. Transmission: What is this for?
  15. heads n headers 3.0
  16. 85 EFI onto a 93?
  17. Can you clean a catalytic converter with any type of spray cleaner while its off?
  18. Bad gas milage
  19. starter relay left me? 88 ex-cab
  20. 22RE throttle problems!
  21. Question On Using A Compression Tester
  22. Space ship sound coming from W56 90 4x4
  23. 3.0 maybe not so bad?
  24. better way to seal front end?
  25. 1993 toyota pickup 22re 5 speed What is this?
  26. No Spark, No way to work.
  27. Installing 3.0 headers and hit a snag with the trans case cooler!
  28. o2 sensor wiring help
  29. Whats this plug for on W56?
  30. 2 buck shifter seat (tighten shifter)
  31. name that symptom: 91 22re, 5spd 215K
  32. 92 4Runner 3.0 VZE Hose Question
  33. help help overheating still
  34. Bad EGR Valve: What Symptoms (3vze)?
  35. 92 3.0 leaking.
  36. 1987 Pickup Question and Value?
  37. Show me your cut fenders...
  38. 93 pickup timing jumper wire??
  39. I need a hitch
  40. Hi Lift Jack finally mounted
  41. My old Girl is running again!
  42. 4wd indicator wire hook up
  43. Gaskets?
  44. How safe are 2nd and 3rd gen Trucks?
  45. Rear ABS
  46. 22RET tune up specifications
  47. Cv axle broken needs replacing
  48. Needing 1990 Pickup wiring diagram
  49. Where's the Fuel Filter? '89 4runner V6
  50. Rear cat gasket help, PN needed.
  51. Oil leaks, Too much crankcase pressure???
  52. master cylinder issues
  53. 91 4runner rear window HELP PLEASE
  54. 3VZe to 1GR-FE
  55. automatic transmission / Transfer case help
  56. Seized torsion bar adjuster bolt
  57. Should I re-ring? 22RE
  58. Lets Play..... NAME THAT SENSOR!!!!
  59. 92 Toyota Pickup 4x4 - Head Gasket gone wrong?
  60. Trouble Choosing Between Thorley Headers
  61. 22RE Miss.....Sometimes
  62. Ticking noise
  63. Neighbor hit my truck. Repair questions.
  64. 90 4Runner radio problem: No signal
  65. This is the transmission I just swapped in. It doesn't sound quite right. [Video]
  66. Water sloshing/inside rocker panels?
  67. Truck Stalls when Hot... What gives?
  68. Weird Exhuast noise (maybe quiet backfire)
  69. Hissing/leaking sound when engine under load
  70. Brakes broke again !
  71. 94 4Runner Badlands flat-top tube bumper.
  72. Anyone with an Aussie Locker... Opinions
  73. Transmission Problems
  74. Pulsing brakes & steering in park.
  75. timing belt issues
  76. L.E.D. blinker & tail light bulbs available?
  77. 2nd gen 4runner tail lights
  78. 95 4Runner - Installing new radio trouble
  79. Tach Help
  80. 94 4runner lifted
  81. Vibrations at slow speeds, shifting into 1st & 2nd
  82. Cam Exhaust/Intake Questions
  83. What color to paint the 4Runner?
  84. Random Engine Stall
  85. 86 turbo wiring diagram
  86. Toyota 22re code 24 & 31
  87. How do you set the throttle stop screw? 94 22re
  88. Tranny Problems: 94 4Runner Automatic
  89. new radio problem........
  90. Radio No Worky
  91. Brake master cylinder question
  92. Kickdown Cable
  93. AFM swap question #2
  94. Thinking about removing bump stops
  95. Replacing an Automatic Window Regulator with Manual Crank
  96. cold start problem
  97. Lspv???
  98. rtec question?
  99. Original plug wires
  100. 87 22r GM module conversion
  101. 3vz-e timing probs!! pullin my hair out here
  102. trans application
  103. Wiring Diagram for 1989 pickup
  104. Clutch Kit, 87 4runner 22re
  105. Bout to give up on my 94 toyota
  106. What PAint to use for control arms etc?
  107. rhino lining the cargo area
  108. New to me 88 xtracab
  109. 90 4runner 22re rering now OD light blinking
  110. users of BJ spacers...
  111. Fuel mileage and a questions about it?
  112. electrical problem?? input appreciated!
  113. transmission conversion
  114. Serious Problems Here! 22re Will not idle
  115. Driveline Slop - Squeaky Driveshaft
  116. Can i swap a 91 4runner v6 into a 93 4x4 ??
  117. Vacum lines to power steering pump
  118. CV Joint Boot torn, how difficult to fix?
  119. I think my transmission is screwed.
  120. 1990 3VZE 4Runner A/C retrofit?
  121. 1st gen 4run rear OEM sway bar Question
  122. Which sides do windshield wiper arms go on?
  123. Removed some stuff from the engine bay. Couple questions
  124. 88 turns over wont start. no codes
  125. What else should I change while takig the head off
  126. '86 Yota 4x4 exhaust manifold leak...AGAIN
  127. 3rd gen pickup 3 spoke steering wheel controls
  128. Code 71 after throttle body cleaning
  129. Rust in Gas Tank...
  130. whats the clickin sound?
  131. Crooked driver seat... 4runner bucket swap.
  132. Morgans Corner mud bog
  133. Getting ready to repair frame w/pics
  134. Replaced Rotors- dust shield needed ?
  135. 22re sensor question
  136. Did 2nd gen 4runners have a 16" wheel option?
  137. dashpot?
  138. HELP! 94 4runner SAS project
  139. Broken exhaust pipe.
  140. Round gray plug
  141. 3.4 5VZFE Block w/3.0 3VZE Heads Possible?
  142. Clutch fork ?
  143. cold start idle up
  144. Intermitent Charge/Brake warning light
  145. re-torque head bolts?
  146. Another newb question on a 2wd lift...
  147. idle air control valve o ring?
  148. Did You Ever Have a 3VZE (3.0 V6) That You Couldn't Get Rid Of?
  149. Need help with v6 idle with ac on.
  150. 3.0 3vze Temp Switch Location 2-Speed Fan
  151. slight vibration and humming
  152. Random Rear Window Freeze
  153. oxygen sensor & headers
  154. Compression Test - Starter won't turn
  155. leaky front diff
  156. 94 runner driver door lock issues
  157. heating/idle issue: 95 22RE
  158. Remflex gasket smoking
  159. Cargo rack and cup holders first gen
  160. Newbie Needs Help 87 22r Yota with 325k with no spark
  161. Bushings for IFS differential-to-frame mounts
  162. 89 22RE timing cover/water pump/ mess-o-trouble
  163. 1992 22re oli pump not priming
  164. Still no spark
  165. troubleshooting?
  166. SwampThing3.0
  167. 1990 3.0 air problem.
  168. rear axel housing
  169. My 3VZ-E Super Stock "Upgrade" Thread
  170. static drop for a newbie
  171. 22R fuel out the top of the carb
  172. is this Con Ferr roof rack too wide?
  173. 3vze valve shims?
  174. What transfer case goes behind the A340H
  175. Timing chain snapped
  176. motor stalling issue: 1995 4runner with the 3vze v6
  177. 22re maf sensor problem....
  178. 88 p/u 3vze 4WD.. 5spd -random stalling issues
  179. my actuator
  180. Clinometer found today
  181. timing chain too short
  182. Removing cover from slip yoke splines
  183. 4runner Starter help. (3vze)
  184. Transmission pops out and grinds in 2nd gear.
  185. 1991 3.0 will not STOP running
  186. truck shuts off while driving?
  187. 22re start up problems.
  188. high performance fuel pressure regulator?
  189. Tachometer on a 22 RE
  190. yet another 22re idle problem
  191. I need a few pictures of how your corner lights screw into the fenders
  192. 1987 with the rod knockin at the door
  193. Could anybody identify this plug?
  194. 3vze Advanced Timing?
  195. Idle Surging 900-1100 rpm
  196. transfer rear case output q's + VIDs
  197. how do I adjust the Idle on my 3vze Motor
  198. Bleeder letting air into brake system under vacuum
  199. Bad Vacuum Reading on a 3.0 V6
  200. Load sensor
  201. Front CV question and leaky front diff
  202. Help a Granny decide what to do? 87 4x4 SR5 22RE
  203. water is disappearing!! 87 4x4 22r
  204. Backwards Swap 4wd to 2wd?
  205. 22re exhaust
  206. Spark Plugs for the 3vze
  207. Advice please - 3.0 fix, swap or bail?
  208. No power to new fuel pump!!! HELP
  209. 92 22re trouble
  210. Knock Sensor ECU Pin ?
  211. 1992 22re stalls please help
  212. The oil pressure gauge and thicker oil
  213. No spark from Distributor
  214. Weird idle issue on my 4runner
  215. 94 runner 3vze one time overheat????
  216. Rebuilding my Hydrolocked engine...
  217. Lifting 1993 Pickup Deluxe 2WD
  218. Coolant in Exhaust
  219. new door speakers installed
  220. Optima YT and 120a GRI alt installed today... problem
  221. my 4x4
  222. Another Question about the 3.0
  223. Question about the 3.0 head bolts
  224. Failed smog. Any tips or suggestions please?
  225. Trans. leaking
  226. engnbldr 261 cam questions
  227. Truck completely died after a (ill-advised) jump, where to start?
  228. 92 toyota 4runner sr5 wont shift out of first until redline
  229. My 86' 4Runner!
  230. 89 4runner IFS ADD or not
  231. Please help get my truck running properly...
  232. Thick Brown oily Sludge in my Radiator
  233. v6 tps sensor problem diagnosed and solved
  234. my toyota, finally going
  235. Any difference in Lower Control Arms between Pickup & 4Runner?
  236. Code 52 Tech Thread
  237. secondary air and egr delete
  238. Rear end sound
  239. fiberglass box sides: any tips on install?
  240. No Speedo?
  241. 3vze misfire, rough idle, low compression in cylinder 3
  242. '90 4runner 4dr Lockdown/dead
  243. W58 fifth gear into a W56?
  244. Need Help with 22RE
  245. Torsion Socket?
  246. Dead on the highway, now no spark
  247. 22re rocker arm assembly
  248. head light problem with 93 pickup
  249. 3vze front cam seal replace - pull cams?
  250. Change oil pan gasket and find broken metal and plastic and coolant inside
