1992 22re stalls please help
Old May 9, 2010 | 12:44 PM
mrconor44's Avatar
my 1992 2wd 5spd 22re with 114000 miles ran like a top until a couple months ago when my brother took it for a ride. the next time i drove it there was a loud squeal when the clutch was pressed and it felt like the clutch was slipping all the way through every gear. i limped it back and forth to work for a couple weeks, until one day it got bogged down and died, fired right back up and drove for a minute then died again. given my brothers track record i assumed it was a transmission issue so i pulled it, and replaced all the clutch components, bearings, and trans front and rear seals/gaskets,because there appeared to be some leakage. i put everything back together and started it, it spewed gas and died so i replaced a section of the fuel line and the fuel filter and now it runs for about 15 seconds then dies. without my truck ive been stranded for 3 months and this guessing game has cost me all the money i had, any help would be immensely appreciated
thanks,
Old May 9, 2010 | 01:07 PM
GranVille-4crawler's Avatar
Don't let your brother drive your truck lol could be a maf issue
Old May 9, 2010 | 01:18 PM
toyota4x4907's Avatar
Air Flow Meter
Old May 9, 2010 | 01:22 PM
desert-rat660's Avatar
could be a MAF problem, the fuel pump is commanded to run when the MAF sees air flow, when u crank the engine the fuel pump is energized. try this, in the diagnostic port connect a jumper wire between +B and Fp then try and start the engine.
Old May 9, 2010 | 04:50 PM
mrconor44's Avatar
thanks guys im going to go try that out right now, and yea hes never coming near that thing again lol
Old May 9, 2010 | 05:15 PM
mrconor44's Avatar
so it ran without stalling , i guess the maf is the culprit, i took the maf apart and three of the prongs, the ones that make contact with the chip with the thin strips of metal that i think serve to protect the prongs, the metal strips were bent out of shape so i bent them back to the best of my ability, and put everything back together but it think the damage was already done. its throwing a 24 and a 31 code
Old May 9, 2010 | 05:16 PM
soooo was that it?
Old May 10, 2010 | 05:01 AM
mrconor44's Avatar
yea thanks guys now i just have to find a maf somewhere that isnt 300 my buddy is parting out an 87 and im crossing my fingers hoping he still has the maf and is nice enough (or dumb enough) to give it to me
Charecter1
Nov 6, 2023 10:08 AM
Blamalam
Mar 12, 2022 07:34 AM
Sleaker
Aug 26, 2020 06:03 AM
_Nicco_
Aug 28, 2015 07:26 PM
Jnkml
Jul 6, 2015 01:20 PM
