Problems with the w-56
Old May 24, 2010 | 07:54 PM
dasrunner's Avatar
Alrighty finally got my 4runner up and goin. efi fuse was blowin thanks to a faulty air valve. Anyways now im havin some trouble with the w-56. it wont go into 1st or 2nd at all and reverse is a total bastard to go into..... Im guessing the 1st, 2nd synchro is out totally but where do i even find parts? Am i just better off finding another tranny or can i do this?
Old May 24, 2010 | 09:57 PM
Itoyota's Avatar
Is your transmission making any noise?
Have you tried engaging the gears while your transfer case is in nuetral?
Like gnarly said: It may just be your clutch. Change the fluid in the lines and bleed the slave before you make any conclusions.
Old May 24, 2010 | 10:11 PM
Brian Pearson's Avatar
check your clutch pedal bracket as well. those break easy on these
Old May 25, 2010 | 09:26 AM
dasrunner's Avatar
the whole clutch assy is new, same as the clutch master cylinder and the slave cylinder. the only thing i can think of is i had a loud pop while in 4lo but didnt have any real issues after. It does whine while its in neutral and when you let out on the clutch it creeps forward even on a level surface
Old May 25, 2010 | 09:47 AM
Itoyota's Avatar
it whines while in nuetral and it creeps forward when the clutch is depressed on a level surface?
So sorta like an automatic with it in drive and your foot off the brake? That's not normal.
Checked the level of gear oil in the transmission and the differential?
Old May 25, 2010 | 09:50 AM
PismoJoe's Avatar
Sounds done to me! My buddy keeps going through those, we can't seem to put one in that is working lol. Whining is a good indication shes done for, sounds like your syncros are gone also.
Old May 25, 2010 | 04:44 PM
dasrunner's Avatar
well after talkin to my dad we established that it was stuck in between 1st and 2nd. I finally got it unstuck though, used a long jackhandle and buzzed it a couple times and it pops right in and out like brand new now lol. now i can move on to my rear tire carrier/tailgate.
SubiKing
Aug 21, 2021 03:57 AM
theking11863
Mar 19, 2016 09:36 PM
Logz808
Jul 26, 2015 07:09 AM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
