truck shuts off while driving?
Old May 11, 2010 | 12:32 PM
WayneR's Avatar
i have an 88 pickup 22re and while driving yesterday my truck shut off completely and came right back on like i just flipped the ignition switch and turned it right back on. i would like to know why it would do that?
Old May 11, 2010 | 12:38 PM
WayneR's Avatar
could it possibly be a bad ground somewhere or something?
Old May 11, 2010 | 12:48 PM
iamsuperbleeder's Avatar
very low on gas?
could be a bad ground
check for moisture and/or loose wires and plugs-ins at or around the AFM, ignition coil and ignitor, and the distributor
Old May 11, 2010 | 12:58 PM
Yotapowa's Avatar
Did it suddenly stop, or did it sputter a bit before stopping?
Old May 11, 2010 | 01:09 PM
yayfortrees's Avatar
I would check all the grounds, as well as battery terminals (loose, dirty or corroded), and fuse box supply wire, and fuses.
Old May 11, 2010 | 01:17 PM
Benjaminbvi4RUNNER's Avatar
Check the ignition switch itself. When it "shuts off" is it as if you turned the key to the off position or just to ACC, I.E. (stereo working and lights without alert buzzer)??sometimes the contacts in the igntion switch can become worn and have an intermittant open circuit. ( Just in case-The ignition switch sits behind the keytumbler that you turn when you start the truck)
Old May 12, 2010 | 08:09 AM
WayneR's Avatar
thanks
yea i think it may had been moisture it hasn't done it any more but it is getting new engine this weekend hopefully will have some pics!
Old May 12, 2010 | 10:53 AM
While you're replacing the engine, keep an eye out for any problems that may have caused this. The only place I know of that could have caused this due to moisture and then be ok afterwards, is the distributor.
Old May 12, 2010 | 06:55 PM
WayneR's Avatar
yea
i found out hat it was it was the wire going to the starter relay off of the battery i have fixed it for now but the truck has 400,000 miles on it so nothing really surprises me!
bigblue82
10
Jul 6, 2015 08:27 AM
ibayne
Jun 26, 2015 06:30 AM
kctopher
Jun 25, 2002 07:07 AM
