Knock Sensor ????
Old Feb 27, 2010 | 10:51 AM
22repower's Avatar
Knock Sensor ????
Ok 2 years ago we swapped the 22re in my truck for another used one from a junkyard....
We got everything put on and running, but since then the truck has been running rich with a cel, and I finally checked it recently to find a 52...knock sensor
Checked it out, and discovered the hole where the sensor should have been had nothing, and have no idea where the knock sensor wire is located...
Anyone know if this wire could be the correct one...really the only possibility I can find
Old Feb 27, 2010 | 12:23 PM
22repower's Avatar
anyone?
Old Feb 27, 2010 | 12:44 PM
laskt9's Avatar
you gotta give people more than two hours man
Old Feb 28, 2010 | 12:42 PM
22repower's Avatar
Any Ideas?
Old Feb 28, 2010 | 02:45 PM
laskt9's Avatar
did you get a knock sensor? install it and hook that wire up to it and see if it fixes your problem
Old Feb 28, 2010 | 03:37 PM
22repower's Avatar
Another thing... Someone on Pirate said that some 22re's from 2wd trucks did not come with knock sensors.
Is this true, because this motor came out of a 94 2wd and seems to have never had one..
thanks for helpin
Old May 12, 2010 | 07:29 PM
1993YotaRunner's Avatar
I have a 91 22re and i dont believe it has a KS, Hopefully someone will awnser that.
jb451
7
Oct 7, 2022 06:58 AM
1uzRunner
63
Nov 10, 2018 03:58 PM
Kreedy1
Sep 8, 2015 06:33 PM
moparbay
Sep 3, 2015 12:48 PM
northwalker
Sep 3, 2015 12:21 PM
