cold start problem
Old May 17, 2010 | 07:19 AM
littlechris 22's Avatar
cold start problem
I have a 91 pickup 4x4 22re with a cold start problem and when driving along when I get it started it feel's like it's lagging power untill wide open trottle postion also has a rough low idle when it warms up. Any where I can begin looking.
Old May 17, 2010 | 07:51 AM
yayfortrees's Avatar
Welcome to YT!
I have a thread about general diagnosis, search 'general running problem diagnosis'. I cover quite a bit in that thread, and it should give you some ideas.
If you plan to diagnose this yourself, you're going to want some diagnostic tools and a factory service manual (FSM). You used to be able to download a FSM from ncttora.com, but that site has recently changed, so I don't know where it is. With a little searching you should be able to find it. If not, let me know and I can try emailing you at least some relative sections.
Unless you have unlimited money, don't start replacing parts hoping to fix the problem that way.
A little more specifically, I would start by checking the gap and condition of all spark plugs, the resistances and connections on sensors such as TPS, air flow meter sensor, etc. Ignition timing could be off, which could cause this symptom as well. Don't forget the basics of checking compression in each cylinder, valve adjustment, etc.
Good luck, and post any updates or specific questions you might have.
Old May 17, 2010 | 10:13 AM
I unplugged the tps sensor and it runs right now?
Old May 17, 2010 | 12:02 PM
Try adjusting it per FSM. If you still get resistance readings that are out of spec, or it won't adjust properly, than you may have a faulty TPS.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
Jnkml
Jul 6, 2015 01:20 PM
