1992 22re oli pump not priming
Old May 12, 2010 | 04:32 PM
MIKE_1991_MILLER's Avatar
ok so ive put assembly lube in the pump, took out the spark plugs, sat there and cranked her for idk 10-20 minitues and nothing so...... is there a way to prime these things a different way and get to finally prime?? or did i F something up.. and yes it has oil in it..
Old May 12, 2010 | 05:31 PM
SoCal4Running's Avatar
Sounds like the drive gear might of been left off. Are you sure the oil pressure gauge works?
Welcome to YT by the way.
Old May 12, 2010 | 06:41 PM
the gear is installed idk if the gauge works.. it should its brand fing new so idk...
Old May 12, 2010 | 07:19 PM
camo31_10.50's Avatar
on top of the oil pump...there is a brass plug...remove said plug..and pour some oil into the hole...this is called manually priming your oil pump. put said plug back into the hole...then see what happens. lol
Old May 12, 2010 | 07:32 PM
tried it. still nothing..
Old May 12, 2010 | 08:56 PM
What else was done to the motor? Is the pickup installed properly (tight) and the screen unblocked.
Almost be temped to pull the filter off and crank.
Old May 12, 2010 | 09:51 PM
i rebuilt the whole engine top to bottom and yes the pickup tube was installed properly
Old May 13, 2010 | 10:16 AM
Thumbs up
well after using a hand held oil pump (tubelike w/a plunger and hose on end) pumped oil thgough the oil filter hole cranked it for idk a minute then the pressure gauge sprang up to 20+ so thanks but i got it!..
Doug4320
Mar 24, 2018 10:11 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Fundy Rider
Jul 16, 2015 01:35 AM
jon.r
Jul 11, 2015 03:34 PM
