Cv axle broken needs replacing
Old May 21, 2010 | 10:20 AM
93runner223's Avatar
Ok so iv searched and searched and i know i need to replace the cv axle on my 93 runner. Its striped or whatev and just bounces around in its socket. My question that has remained unanswered is where does the shaft connect to and will that be damaged because its been like this for two days now and i have two days left of work before i can get to it. So if i buy two cv axle shaft assemblies one for each side. Will i need anything else other than tools and grease. Anything within the hub etc
Old May 21, 2010 | 10:26 AM
Lumpy's Avatar
won't really know until you get in there...The hub could be damaged.
thook's Avatar
Well, the inside end simply bolts to the axle flange.....so no probs there. The outside end fits through the hub and bearings therein. If that's where it's bouncing around, the bearings may just need grease or they're toast. There is a c-clip on the end of the shaft that keeps it locked into the hub. You'll see that once you have the hub apart. It's possible that could be destroyed and in need of replacing, if that's what's causing the bouncing around. But then, I'm not sure you're referring to by "it's socket".
Old May 21, 2010 | 10:28 AM
thook's Avatar
BTW, I was relegated to driving my wife's '92 around for quite some time with a bad CV axle and didn't incur any damage from doing so. So, you might be just fine, in that regard.
Old May 21, 2010 | 12:00 PM
iamsuperbleeder's Avatar
http://www.ncttora.com/fsm/1990-1995...i/frontdri.pdf
http://www.ncttora.com/fsm/1990-1995...l/frontaxl.pdf
should be all the info you need
Old May 24, 2010 | 07:37 AM
ok the cv axle seperated at the joint within the outer cv boot dont know whats missing i just ordered a new one o well
Old May 26, 2010 | 07:17 PM
thook's Avatar
Most likely means at some point enough grease was gone and enough moisture was in there that the bearings wore out and fell out.
Old May 27, 2010 | 11:10 AM
Fedden's Avatar
Originally Posted by iamsuperbleeder
Can you send me a link to a guide like this for an 87 Runner?
Thanks.
Old May 27, 2010 | 11:23 AM
waskillywabbit's Avatar
Thanks.
A little bit if effort on your part will get you far.
www.ncttora.com/fsm
Old May 27, 2010 | 01:40 PM
YotaFreakTN's Avatar
93runner223: don't be surprised to see some space between the axle and the brass bushing that press into the inner and outer spindle holes, there is suppose to be a little space as they are simply a "buffer" to keep the axle's alignment relatively symmetrical. I just ran into a similar situation over the weekend changing ball joints, removed the hub and the axle just fell out from the inner joint, the cage for the bearings was wrecked and no telling how long it had been like that because in 2wd it was asymptomatic and i never knew/noticed it and it hadn't damaged any other parts. Best of luck. Also, I love Toyota's design on their half shafts so that you do not have to fully remove the spindle assembly to pull the axle, God bless Toyota's engineers.
jerusry
Oct 19, 2015 05:28 PM
jon.r
Jul 11, 2015 03:34 PM
Snort
Jul 9, 2015 03:58 PM
akaphilly
Jul 9, 2015 02:34 PM
ItsJustD
Jul 7, 2015 07:49 AM
