- 88-89 4runner sr5 Radio Tape player pics?
- PLEASE HELP with my 95 4Runner issue - see my video here...
- 22r wont start, just click
- 22re trans oil level
- Reran o2 sensor wire to comp, still coded
- auto trans wont shift
- More Power out of my 22RE?
- Fuel problems
- 94' 22re rough idle, beltching radiator and poor timing...
- how many of you guys are running IFS OME leafs
- Convert CA to Fed specs? 95 4runner
- 22re alternator fuse
- Spuddering Idle, fine after a while
- $12 ElCheapo Budget Boost Installed With Pics And Butt Sag Fixed!!!
- Preparing for a timing chain job
- 3vze problem...any ideas?
- 87 4Runner 22RE troubleshooting help needed
- 22re revving up while in gear
- 22RE Engine Harness
- 92 pickup (22re) Hesitation and jerky acceleration
- 22re rough idle in gear???
- 87' 22r 4x4 5sp brake Q's
- Finished 3.0 HG and now it won't start
- ! Tranny Re-install Tips !
- A/C Recharge 94 4runner
- 87 4x4 regular cab suspension is shot
- code 52 1990 4runner
- Tach Cluster swap, no coolant gauge now?
- 88 4runner coil arc issue
- TBA - Throttle body Differences
- knock in motor
- electrical to mechanical speedometer conversion
- No Power to ANYTHING Fix
- 1/2" tire size difference front/rear
- My 3.0L 1995 rebuild With pictures!
- Help! Purchased 2 days ago.. 3VZE leaking oil into Auto Trans??
- Coil retainers?
- Control Arm bushings- A misadventure
- AT Transfercase coolers, how much pressure are they under?
- ifs bushing questions
- 22r stock carb no fuel in sight glass
- 86 4runner rear window will not roll down - HELP Please
- 15-year old exhaust nuts...
- Oil leaking from catalytic converter?! *pics*
- 88 Toyota new to me
- Throttle Body/IAC Cleaning
- New rear shelf in my pickup.
- Put on the tube doors!!
- Cluster on 92 pickup?
- Knock sensor?
- Rear axle broke
- no more code 71 look !!!
- aftermarket transfer case coolers?
- almost time for a clutch
- Cant get truck into 4 wheel drive
- AAV and check engine light
- Differences in water pumps?
- 22re Timing
- Bad Solenoid(s) ?
- Ball joints & control arm bushings...
- Snorkel for 88 pickup
- 87 22re 1-wire or 4-wire O2?
- '89 3vze rattle tranny flex plate
- signals on my 93 yota dont work.
- 94 4Runner V6 - Runs Rough on WARM Start
- pickup interior pics
- water pump gasket leaking after replacement
- Bloer motor/ Fan switch
- possible blown motor - head gasket?
- Instrument cluster bulbs
- 3.0 Hesitation during acceleration
- 2nd broken brake line
- Seats for taller fellas
- Changing headlight housing?
- AT transfer case question, does it pressureize in 2H?
- Head gasket Hawaii
- 1986 4Runner 22RE rough idle, rich, no power
- '86 REC Rebuild Problems
- Baby moon hub caps?
- Fresh 22re rebuild. Got some questions.
- cleaning egr passages in the plenum?
- 3VZ stutters/stalls when attemping to get going and no idle... Big Problems
- 4runner rear window repair walkthrough
- Unanswered Bucket seat Q's
- Steering after SAS
- 3rd row seat using a bench seat from a Jeep YJ
- 11 in lifted toda with a dual t case question
- Gas Mileage after rebuild (3VZE)
- Dead yoter
- New to toyotas and need help
- 4 Crawler BL installed...(PIC LOADED)
- Valve Ticking
- Rod Bearing Replacement - 3VZE
- Painted the campershell
- Idle air controller?
- (ABS?) Braking Issue
- Panhard Drop Offset
- 22RE blown - how did it happen?
- oil pressure gauge not working properly
- egr ports intake plenum?
- front n/s 1/2 shaft
- Help with 3vze intake chamber connections
- on the fly roof mount light bar.
- Is this a Weber carb?
- Clutch Releases Rough
- leaking oil question.
- Reverse works but only with wheels off the ground
- Show me some flex pics of your ZUK mods
- Bed mat or liner that will not scratch paint?
- Am I missing a step? Cant get rear window to role back up?
- selling my rte engine
- About my 87' Pickup
- 86 4runner Code 7
- easy to replace front passenger window on a 93 pickup
- 1988 4Runner 4wd Rebuild or Replace (22re)
- my $100 3vze long block
- yet another back window problem
- Running rich and poor acceleration - running like crap
- First drive with the DT 3.0 headers installed, first impressions
- 94' 3.0L new engine problems/please help
- '93 Yota P/U, acceleration problem
- hg dont still wont fire
- Crazy Idle after turning off air
- no spark 1993 22re
- Fitting a Warn 8274 on a 2 gen 4runner
- 4wd Fenders
- 4.88 7.5 IFS Diff Swap
- 3vze distributor ground wire?
- High pitched whine coming from drive shaft
- 1990 22RE AFM to MAF Conversion specs
- 87 Carbed 22r Stumbling
- ngk gp platinums spark plugs and code 71
- 5 speed and efi conversion
- swapping a 95 4runner center console-
- V6 Rear Rebuild
- 1993 22re tps adjustment??
- TIMING 3.0 3vze probs still!
- Need The Best Yota Minds to Diagnose My 3VZE Problems
- DIRTY intake
- 22re ngk gp platinums spark plugs beware!
- Driveshaft decided to fall out on motorway this am
- Starting Woes
- transmission adapters? Toyota Engine-->GM transmission
- What is this? 3.0 VZE leaking-parts ID
- CRAIGSLIST is GREAT! traded 91 4runner for a 92 Truck
- Help!! Steering wheel locked & key wont work
- Shift Lever Retainer: Replacement Needed?
- Starter problem
- 8" interchangeability or rebuild?
- How to hack a MT harness to work with an AT?
- runs good when cold
- BEGINNER'S 22re Timing Chain Failure / replacement / head gasket replacement
- 4runner doors with wing window
- 22re New Motor.. Low compression
- 3VZE Throttle Boby Adjustment Question
- mystery oil leak
- code 71 egr temp sensor
- please help wierd engine problem
- help with the belt
- Quick Question: drive shaft and lift
- installing A/C unit
- Hood mat
- Idler Arm Already? Some Qs
- ignition or fuel issue? 89 hilux pickup
- Coolant leaking from rear of block Need Help
- Transmission Swap tips/suggestions?
- Problem: Hard to shift gears.
- misfire/rough running 22re
- '90 4runner starter solenoid switch
- Low speed vibration when turning
- Problems with the w-56
- installed OME 900's
- 3vz-e people what is this plug for?
- Name that engine sound
- how to replace clutch with headers installed?
- New MaxBore TB
- Transmission: What is this for?
- heads n headers 3.0
- 85 EFI onto a 93?
- Can you clean a catalytic converter with any type of spray cleaner while its off?
- Bad gas milage
- starter relay left me? 88 ex-cab
- 22RE throttle problems!
- Question On Using A Compression Tester
- Space ship sound coming from W56 90 4x4
- 3.0 maybe not so bad?
- better way to seal front end?
- 1993 toyota pickup 22re 5 speed What is this?
- No Spark, No way to work.
- Installing 3.0 headers and hit a snag with the trans case cooler!
- o2 sensor wiring help
- Whats this plug for on W56?
- 2 buck shifter seat (tighten shifter)
- name that symptom: 91 22re, 5spd 215K
- 92 4Runner 3.0 VZE Hose Question
- help help overheating still
- Bad EGR Valve: What Symptoms (3vze)?
- 92 3.0 leaking.
- 1987 Pickup Question and Value?
- Show me your cut fenders...
- 93 pickup timing jumper wire??
- I need a hitch
- Hi Lift Jack finally mounted
- My old Girl is running again!
- 4wd indicator wire hook up
- Gaskets?
- How safe are 2nd and 3rd gen Trucks?
- Rear ABS
- 22RET tune up specifications
- Cv axle broken needs replacing
- Needing 1990 Pickup wiring diagram
- Where's the Fuel Filter? '89 4runner V6
- Rear cat gasket help, PN needed.
- Oil leaks, Too much crankcase pressure???
- master cylinder issues
- 91 4runner rear window HELP PLEASE
- 3VZe to 1GR-FE
- automatic transmission / Transfer case help
- Seized torsion bar adjuster bolt
- Should I re-ring? 22RE
- Lets Play..... NAME THAT SENSOR!!!!
- 92 Toyota Pickup 4x4 - Head Gasket gone wrong?
- Trouble Choosing Between Thorley Headers
- 22RE Miss.....Sometimes
- Ticking noise
- Neighbor hit my truck. Repair questions.
- 90 4Runner radio problem: No signal
- This is the transmission I just swapped in. It doesn't sound quite right. [Video]
- Water sloshing/inside rocker panels?
- Truck Stalls when Hot... What gives?
- Weird Exhuast noise (maybe quiet backfire)
- Hissing/leaking sound when engine under load
- Brakes broke again !
- 94 4Runner Badlands flat-top tube bumper.
- Anyone with an Aussie Locker... Opinions
- Transmission Problems
- Pulsing brakes & steering in park.
- timing belt issues
- L.E.D. blinker & tail light bulbs available?
- 2nd gen 4runner tail lights
- 95 4Runner - Installing new radio trouble
- Tach Help
- 94 4runner lifted
- Vibrations at slow speeds, shifting into 1st & 2nd
- Cam Exhaust/Intake Questions
- What color to paint the 4Runner?
- Random Engine Stall
- 86 turbo wiring diagram
- Toyota 22re code 24 & 31
- How do you set the throttle stop screw? 94 22re
