4 Crawler BL installed...(PIC LOADED)
Old Jun 1, 2010 | 02:29 PM
wii_tarded's Avatar
Courtesy of WabFab (telling me to go to 4 Crawler) I was able to pick up a 2" body lift with new poly bushings and shipped cross-country for less than $275.
I am continually impressed by the willingness to help one another on this site. So here are the pics, some before and some after.
put the kids to work...
Removed front bumper to get to front mounts easier...
he will never get to drive it.
first block in
full tilt
lowering the radiator.
DONE!!!
Now I have only one problem, the lift messed up my shift boot. When I tried to go somewhere, I couldn't shift into 2nd, 4th, or R untill I removed the entire boot. Now I have a hole in the floor. Any remedies for this?
Old Jun 1, 2010 | 03:36 PM
DethYota's Avatar
You may be able to either relocate your base plate (The piece that holds the boot) by cutting in the cab, or your shifter seat bushing may be worn. Does it still not go in gear with the boot off? If it does go in gear after the boot is removed it is probably the binding of the boot like you thought and you just need to relocate it an in or 2 back.
Old Jun 1, 2010 | 03:41 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
You can also buy some bumper relocator plates from 4 Crawler that will lift the bumper up 2" to match the lift.....
Old Jun 1, 2010 | 05:04 PM
Brian Pearson's Avatar
take the metal plare off. just run with the boot only. thats what im doing right now. until i can figure somethingbetter out
Old Jun 1, 2010 | 08:31 PM
wii_tarded's Avatar
yeah, it still goes into gear with the boot off. It was the rubber boot that had it bound up, not just in stretching it, but between the body and the shifter. I am looking at the idea of inverting the boot onto the shifters. Dunno if that will work, tore mine up trying to shift. also looking into custom shifters.... that may get expensive though.
As far as the bumper, there is a little damage to the front I want to have fixed before doing any of that. May even build my own bumper by that time.
Old Jun 2, 2010 | 02:17 PM
mfwimg82's Avatar
nice looking truck good luck with it
Old Jun 25, 2012 | 01:17 AM
digitaldisciple's Avatar
Originally Posted by wii_tarded
Before:
After
Considering a body lift for my truck aswell. Dont dig the bumper gap but atleast they sell brackets to fix it. Overall looks good and could be helpful for some clearance.
I just wanted to see before and afters without scrolling a page and a half
Old Jun 25, 2012 | 03:25 PM
yoder519's Avatar
I had the same problem after puttin my 2in 4Crawler BL on with shifting. I just took the metal plate off. I reckon you could probably trim it out. But I just took it off and left the boot like mentioned before.
Old Jun 25, 2012 | 10:43 PM
abecedarian's Avatar
Looks pretty good.
But now that you're done, what are you going to do with the kids?
Jun 1, 2021 01:51 PM
JNapolitano
Nov 14, 2019 07:46 PM
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
82yodahickman
34
May 16, 2017 01:00 PM
ctheiss
9
Sep 15, 2015 01:44 PM
