sensor next to coolant temp sensor on 90 22re,what is it??
Old Jan 28, 2012 | 03:31 PM
brino1's Avatar
i cant figure out what the sensor is that is to the left of the coolant temp sensor on my 90 22re.any ideas??
Old Jan 28, 2012 | 04:41 PM
mldave's Avatar
Size:  70.3 KB if it's the one on the left it's the cold start injector time switch.
Old Jan 28, 2012 | 05:19 PM
brino1's Avatar
that figures,its the one thats $150!!
Old Jan 28, 2012 | 05:44 PM
mldave's Avatar
brino1,mines an 86 truck....probably different part # you can get them from a junkyard for $ 10-$ 25.
Old Jan 28, 2012 | 05:59 PM
brino1's Avatar
ill prolly go hunt for one tomorrow
Old Jan 28, 2012 | 06:38 PM
mldave's Avatar
You might have to have the same part number...think it's located on one of the flat surfaces.
Old Jan 29, 2012 | 10:39 AM
abecedarian's Avatar
Why are you wondering about it?
Does the truck start up when cold?
Old Jan 29, 2012 | 11:26 AM
brino1's Avatar
it starts,but only after cranking for about a min.starts fine when its warmed up or warm outside.the connector for that sensor is actually broke off.
Old Jun 25, 2012 | 04:26 PM
stock93's Avatar
Sorry to dig up an old thread but I broke that black sensor off the other day. I pulled it out and it looked like a probe so I figured a coolant temp sensor. I was just wondering if you could tell me what you ended up replacing?
Old Jun 25, 2012 | 10:47 PM
That sensor is called "Cold Start Injector Time Switch".
It's purpose is to complete the circuit that causes the cold start injector to squirt fuel while you're cranking the engine... IF the engine is cold, as in below around 65F degrees.
the1998sr5
15
Jul 14, 2020 08:35 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
Poncho0206
Jul 10, 2015 06:21 PM
bryan34w
Jul 6, 2015 05:53 PM
