PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 [94] 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. 7 4runner, how much AC oil with condensor replacement?
  2. 22rte master cylinder help
  3. 2 problems. water in EGR (normal?)..PS fluid in intake
  4. 3zve Head Gasket Problem
  5. Ecu relocation
  6. 87 pickup intermittent wipers wont work. help please
  7. Replace Timing Chain 1989 4Runner
  8. 94 runner didn't pass emissions need help
  9. Changing Aluminum housing key cylinder? Help!
  10. Locked up engine
  11. '94' 4WD Pickup 22RE - Blown Head Gasket
  12. 22RE wont stay running
  13. Power window electrical question
  14. A340f Rebuild
  15. 1986 22re
  16. So tired of ppl telling me tha the 3vze is a bad motor
  17. Circle Track 22RE Engine Build
  18. Need Help! What's wrong with my 92 4cyl??
  19. just finished 3.4 swap with new wheels and tires too
  20. Fuel line part number.
  21. Custom Camo Shift Boot Cover!
  22. 3VZ-E custom exhaust
  23. 91 4x4 fan for heat/ac not blowing anymore
  24. Have to replace false fan pulley bracket, is this what I need?
  25. what ecu code is this?
  26. Bed liner fitting ??? Tacoma liner into a 3rd Gen truck
  27. 3 Inch Body Lift Automatic
  28. 3VZE - Scraping sound when accelerating
  29. 3vze TPS install and adjust question
  30. Changed brake shoes, now wheel cylinder leaking
  31. Vacuum Hose
  32. Lost Transmission, Clutch Questions
  33. 89 Yota Code 51 & 52 Issue
  34. 1994 starts and dies
  35. Seat Fixings
  36. 3.0 hesitates and runs weak in the rain
  37. What soft top is this?
  38. truck still shaking
  39. A/c installment for 1988 pickup
  40. weird lights flashing at me after wash
  41. Crooked pulley help!
  42. Should I just pull the motor? timing chain / head gasket
  43. new truck owner with some ?s
  44. Fuel Problem 1990 22re extra cab
  45. which Weber to use on my 87 yota 22r
  46. 86 truck interior exploded view (under dash)
  47. Power steering line question
  48. shifter boot
  49. 87 22re bogs down past half throttle
  50. 3vze carnage
  51. 86 toyota what motor? whats missing?
  52. 05 Taco front clip on 2nd gen 4Runner... Anybody done it??
  53. Truck bucks to a standstill going up steep hills
  54. Clutch Swap
  55. Fuel pump sender outlet fittings
  56. Ignition Nightmare please help
  57. Scored!
  58. So I Bought an '86 for $1000...
  59. 3vze fuel pump question
  60. Speedometer/Odometer not working
  61. 3zve fuel injectors and code 14 question?
  62. 1987 4runner
  63. Overheated now is hard starting and won't idle
  64. HEad light not working.
  65. 3VZE Guru's - - Where does this go ?
  66. Loud pop after gasket repair
  67. O2 Sensor
  68. Trailer wiring?
  69. Turbo 4runner putters from exhaust
  70. 3vze rebuild HELP!!!!
  71. PICTURES I finally got the 1986 long bed after two years
  72. 90 4WD 22RE cuts out at Highway cruise speed
  73. Auto tranny lines from radiator-routing
  74. Check engine light code 71
  75. Trail Gear rear bumper install
  76. Auto to Manual wiring help
  77. Agh! o2 sensor help
  78. 3VZE - Need help identifying connector
  79. 5vze swap w/ 3.0 tranny slip?
  80. Too much slip yoke play? (Video)
  81. Installing Old Man Emu rear springs!!
  82. 3.0 v6 problem
  83. Lets talk about carbs
  84. Need opinions - Tire size and safety
  85. Shock Mount disappeared
  86. Starts up and misses pretty bad for a few minutes
  87. 3VZ-E Headers
  88. Trans Pan
  89. 92 2wd Vacuum diagram 4cyl
  90. Power steering pump puking
  91. Transfer case brake
  92. My last problem...A/C hose too short
  93. 120amp Jaguar Alternator Upgrade **HOW TOO**
  94. troubles with engine! code 4 and 6
  95. idles funny
  96. Quick ISR Mod Question
  97. A/C Install help 1st gen 4runner
  98. supercharged 3.4 in 3rd gen
  99. 22R timing issues
  100. Is my rear pinion seal leaking?
  101. Fuel leak at driver side fuel rail
  102. No Power to Fuel Pump - How to Bypass EFI Relay??
  103. 94 4R v6 Camshaft Aligning Advice
  104. help coolant starts foaming after driving
  105. help with front turn signals
  106. bucket seats
  107. 86 22re in a 93 body
  108. Whole Dash Swap Questions
  109. 94 AC help, inlet adapter for r134a
  110. 4Runner Clutch Replacement, Clutch not engaging
  111. 5" lift rear coils?
  112. CT Emissions issues
  113. ADD to manual hubs, 4wd no workie
  114. fuel pressure
  115. 2rz taco motor in a 91 yota w/ 22re
  116. Mpg's
  117. Fisher price: My First Tranny flush
  118. 22re mas and wire testing
  119. 94 trans pops out of gear clutch
  120. new intake and exhaust and gettting code 25
  121. PCV valve on only 1 valve cover (3vze)??
  122. 3vze Ground wire...where to connect
  123. 2nd Gen 4runner rack differances
  124. Brake light upgrade to 3rd gen style?
  125. 94' 22re flywheel question
  126. 22re and SAS?
  127. 88 22re injectors wont work
  128. 88 pick up Clutch Issues V6 stand
  129. 1988 Steering Knuckle bushing repair
  130. Help Knock Sensor wire location at ECM on 90 3.0
  131. Air conditioner
  132. 22RE random over heating issue.
  133. 22r head to 22re head.
  134. Fuel problem
  135. Lets talk about carbs
  136. Hella part numbers
  137. 2nd gen 4runner gearing question.
  138. 1995 4WD Pickup Suspension Maintenance
  139. '86 4runner underbody oil leak
  140. photo 1988 4runner vacuum line routing
  141. Lower A arms need replaced.
  142. Pickup swing-out spare tire carrier
  143. New truck intro. 2dr 2nd gen content inside.
  144. A Different ATF in PS question.
  145. knock / backfire in Exhaust
  146. my 93 yota. what do ya think?
  147. Still can't set timing, 3vze
  148. timing chain cover
  149. Terrible Gas Mileage?
  150. Timing on an 86' 4Runner???
  151. Rear 3rd, getting loud!
  152. hate the crankshaft pulley
  153. misfire
  154. 3.0 AFM adjustment
  155. What is this and where does it go?
  156. Timing cover gasket
  157. cv axles are there any good ones other than factory cv axles
  158. after offroad steering issues
  159. 93 pickup head gasket problems
  160. front rubbing in 4wd (not tires)
  161. Penetrol
  162. repair manuals?
  163. 87' 22RE Horrible idle surge, throttle useless.
  164. LCE Headers, Magnaflow exhaust installed...
  165. The surging / Missing 22re
  166. Cooling issues after plate bumper install
  167. Dead Gauges, No Alternator charge, Blown fuse
  168. what is the vmaf mod?
  169. Timing set at 10*BTDC is best??
  170. Help with cluth release bearing!
  171. Engine Management Systems
  172. 22re, No Start, No Time. Too Much Fuel?
  173. Error code #4 Temp Sensor
  174. 3VZE Crank pulley won't come off
  175. 89 SR5 doors won't stay locked
  176. Bearing/Seal ID List
  177. Got an alignment done... good news to me
  178. Clutch ticking
  179. Tape Deck doesnt work 88 4runner
  180. '94 Rear Hatch Problems
  181. Companion Flange Question
  182. Swapping Low impedence injectors for High impedence
  183. Difficult CV removal and front diff swap, 92 4Runner.
  184. Failed smog in CA :(
  185. Temp Overshoot?
  186. Did the Delete The ADD System mod. Have a ?
  187. Lower Coolant Pipe
  188. Header install and exhaust welding costs...
  189. Bouncy Truck
  190. Sensor identification, broken nipples
  191. My ac conversion going south?
  192. 1st gen 4runner: Upgrading to later year wiper arms
  193. Brake Light coming on randomly??
  194. Need help with check engine light...
  195. Moog ball joint ???
  196. Antenna, i dont need no stinkin fender antenna hole
  197. came over to the dark, foreign side yall!!
  198. dead cylinder?
  199. A Note On Low/Erratic Idle 3VZE
  200. 22re vs 22rec exhaust?
  201. 87 yotie shifter plate
  202. What hose is this?
  203. total window failure?
  204. Check engine light after head gasket repl.
  205. 3.0 Clicking.
  206. '88 4runner 3.0 fuel filter replacement
  207. Find rear bumper in 'yard?
  208. No engine check light
  209. Leafspring swap, RUSTT!
  210. new vehicle new questions
  211. Some b@st@ard stole my exhaust supports!
  212. Head Gasket Job That Truned Into a Check Engine NIGHTMARE!!!!!!!!!
  213. Supra AFM swap or Stock AFM gear adjustment??
  214. 88 4runner won't start. Not getting fuel thru the injectors. HELP plz!
  215. 22-RE Overheated. Whats wrong?
  216. O2 sensor fun and games
  217. Opinions on bedlined sides?
  218. Help tranny problem!
  219. Thrush and lce header
  220. Brake line diagram
  221. Throttle Cable Adjustment
  222. 89 toyota p/u exhaust manifold leak
  223. Aussie Torque Specs VS toyota FSM? Which to believe?
  224. FJ Cruiser Wheel fitment??
  225. eratic idle when a/c on
  226. 87 pickup transmission boot
  227. Wrong Lower Control Arm Bushings?
  228. Steering wheeling not returning to center
  229. another 22re starting problem
  230. R15x Tcase on r154
  231. 3vz-e Losing all power between 3000-4000 rpm?
  232. 22re squeels only when driving, help!
  233. 95 4Runner rear window problem
  234. Throttle Body, Flap/butterfly/Thing
  235. popup sunroof cover
  236. Transmission Swap Done
  237. How do I bypass the BVSV on 92 toyota pickup
  238. Weber carb issue
  239. Remove tranny shifter while tranny is still installed?
  240. Timing issue
  241. 3VZE - Two clutch sizes?
  242. 1991 4runner exhaust help
  243. Idle question
  244. scored a 22r
  245. Harmonic balancer installer for a 3VZE?
  246. 22rec Stalls when push in clutch
  247. 3.0 bogs/stalls
  248. 88 p/u 4X4 fuel filter issues.
  249. Steering wheel Play
  250. Tilt steering fiasco
