Throttle Body, Flap/butterfly/Thing
Old May 5, 2012 | 03:47 PM
kyle9013's Avatar
I think i saw the answer somewhere before but cant seem to locate it.
So sorry if this has been posted before.
Is the Butterfly(or whatever its called) in the throttle body supposed to have any gaps? On mine when i hold up up to the light i can see through it a tiny bit. or is it supposed to be completely closed?
Old May 5, 2012 | 05:47 PM
Rob510's Avatar
Yes that is normal. The throttle plate doesn't seal up the opening entirely in the throttle body.
Old May 5, 2012 | 05:54 PM
Kiroshu's Avatar
^--- x2
If the throttle plate was fully sealed shut the engine would not run.
Old May 5, 2012 | 06:29 PM
MudHippy's Avatar
That is not not true.
You might have to open up the idle air by-pass circuit(back the idle speed adjusting screw out) a little to compensate for it though, if it were fully sealed when closed. Which it isn't. But the engine would definitely still be able to run.
Old May 5, 2012 | 07:01 PM
Kiroshu's Avatar
This was in theory of course... >_<
I do remember one time as an experiment in school we had a vehicle just for school use only and we were being shown the difference with a car with a normal throttle body and one with the throttle plate fully sealed off and when the fully sealed one was on the vehicle it would bearly run at all. Guess i went slightly over board with "will not run" but still it is theoretically trueish.. Either way its never supose to be sealed shut 100% ^_^
Old May 5, 2012 | 08:26 PM
kyle9013's Avatar
So, if its open a little bit its good then?
Thanks for your guys replys
Blamalam
Mar 12, 2022 07:34 AM
Blamalam
Aug 16, 2015 12:29 PM
mtc1105
Aug 4, 2015 08:06 PM
bighaydn
Aug 4, 2015 07:17 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
