3vze TPS install and adjust question
Old May 23, 2012 | 07:04 AM
bomhour's Avatar
Hi All,
I want to make sure I have my new TPS installed correctly. The FSM instruction seem a little vague to me. It says to check the that there is no continuity up to a certain point in the clockwise rotation of the sensor. I tried to do this with the engine off and had no luck getting a continuity signal from my meter.
Does the engine have to be running to set the TPS properly? Here is a link the FSM I am working with... http://personal.utulsa.edu/~nathan-b...34throttle.pdf
thanks for the help.
Old May 23, 2012 | 07:59 AM
YotarTota's Avatar
I have the same problem, when i installed my TPS it wont crank with it on, but if i unplug it it fires up. dosnt run as good. But once i drive around and the engine gets warm i can plug the TPS in and it does fine. Any help?
Old May 23, 2012 | 03:09 PM
bmcghie's Avatar
Engine doesn't need to be running to set the TPS properly. Are you sure your leads are properly connected to the pins in the TPS? You should only be checking stuff between those 4 points, as per the FSM. If certain values are not as spec'd, you can rotate the TPS clockwise or counter on the little screws.
Most people find it easiest to take the whole throttle body off the truck to do this. Then you have much more room to work. If you do, you may want to have a new throttle body/intake plenum gasket for reassembly. It also helps to drain some (2L) coolant before you disconnect things.
Hope that helps.
Old Aug 28, 2012 | 03:38 PM
Toreador's Avatar
I have my throttle body sitting on my table top. How do I apply vacuum?
Old Aug 28, 2012 | 03:42 PM
Team420's Avatar
Thats what ive alsways wondered... dont got the $ for a tool ill rarely use....
Old Aug 28, 2012 | 04:11 PM
Toreador's Avatar
Same.
I'm wanting to adjust my tps. I have my throttle body on the table right now. I just need to know step by step how to do it.
Old Aug 28, 2012 | 04:56 PM
Toreador's Avatar
Where do I put the meter settings to? 2000k or 200k?
I don't even understand this meter.
Old Aug 28, 2012 | 07:02 PM
bomhour's Avatar
Originally Posted by Toreador
Same.
First off, to check vacuum you need to have the throttle body installed and the engine running. Dont get confused with user comments to user questions and FSM manual instructions.
Once you have checked the vacuum with a tachometer (i think you need a tach) then you can just loosen the screws at the TPS with a bent screw driver (engine off) and connect the ohm meter per the FSM to the proper leads with the connector disconnected and the screws loose enough to rotate the TPS. I did this to mine and it runs ok. I was never satisfied with how its positioned and I need to take the TB off the truck and do it right but I just didn't have time. You will be able to tell if its not adjusted properly...you will notice it in the gas pedal and when trying to hold a steady speed.
Old Aug 28, 2012 | 07:04 PM
bomhour's Avatar
Old Aug 29, 2012 | 03:07 PM
Toreador's Avatar
When connecting VTA-E2, I'm allowed between 200-800 ohms with the throttle fully closed.
Would I get the most benefits (better throttle response, etc.) out of setting the tps at 750-800ohms?
And what does that look like on an Ohm meter?
Old Aug 29, 2012 | 03:15 PM
Toreador's Avatar
Now another website does not say to adjust with the throttle fully closed. This one says with VTA-E2 @ 0.50mm I'm allowed 0.47K - 6.1K.
Would I get the best results putting that setting near 0.47K or 6.1K?
and what would that look like on an the meter set at 2000 ohms?
Old Aug 29, 2012 | 03:22 PM
Toreador's Avatar
http://www.lcengineering.com/LCTechP...Adjustment.pdf
Old Aug 29, 2012 | 06:12 PM
Team420's Avatar
Whenever there is a "range" for spec, right smack in the middle is usually the best setting
Old Aug 29, 2012 | 09:00 PM
scope103's Avatar
Don't try to "set" the resistance. What you're adjusting is just a switch. Technically, it is either "on" (zero ohms) or "off" (infinite ohms). But since two pieces of metal (the switch) in gentle contact will still have some resistance, the manual is allowing anything less than 2.3k ohms is "on," otherwise it's "off". And it's supposed to be "on" at .57mm or less, and "off" otherwise.
That's all there is to it. You can't fine tune the resistance, and it has no effect on performance.
smthwsn357
May 1, 2024 07:28 AM
88yodabasket
Jul 13, 2015 01:32 PM
Coreyr384
Jul 10, 2015 11:13 AM
garagespace
Jul 9, 2015 08:37 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
