87 22re bogs down past half throttle
Old May 21, 2012 | 05:53 PM
bsmall505's Avatar
I just got done putting a rebuilt head on my 22re. It was milled and had new valves put in. I also replaces the timing chain while I was there. I got it running and adjusted the valves after it warmed up. There is still a ticking noise that sounds similar to loose valves. When I drive it runs fine until half throttle, then it starts to bog down. After driving it a while it started to get hot. Does this sound like an injector issue? Any help would be greatly appreciated.
Old May 22, 2012 | 12:45 AM
wyoming9's Avatar
Wink
Sounds like a timing issue.
Have you changed the fuel filter as of late.:jessica:
Old May 22, 2012 | 05:36 AM
bsmall505's Avatar
I will check the timing again. I replaced the fuel filter less than 200 miles ago. thanks for the help
Colington
Mar 8, 2020 09:51 AM
montanatruck
Feb 26, 2017 07:07 AM
coleypull15
Nov 3, 2015 07:41 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
colinmil
Jul 6, 2015 04:03 PM
