Swapping Low impedence injectors for High impedence
Old May 9, 2012 | 03:37 PM
Outsane's Avatar
I am getting a set of High impedence injectors to swap into my 84 celica, same as the 85 22re and other years wiring harness's that uses a resistor solenoid..
So I plan on bypassing the resistor box
Old May 9, 2012 | 03:38 PM
Outsane's Avatar
the new injectors
Old Dec 4, 2013 | 11:19 AM
redtacoma31's Avatar
So you can run high impedance injectors in place of the low impedance, if you take the resistor block out? I have a good set of high impedance, and would like to run them. I was just unsure what I needed to do if I could run them.
Old Dec 4, 2013 | 02:34 PM
RustBucket's Avatar
Do those injectors give you the additional 2.5 ohms that the resistor box gives?
Old Dec 4, 2013 | 04:13 PM
scope103's Avatar
Originally Posted by Outsane
... So I plan on bypassing the resistor box
Will that work? According to Toyota, the ECU for high impedance (no resistor box) injectors has a longer pulse time to compensate for the slower speed of the injector. http://www.autoshop101.com/forms/h22.pdf Will the ECU adjust the pulse time for you? Or do you have to modify the ECU?
kazuya2416
Apr 5, 2024 02:17 AM
icentropy
Sep 16, 2020 02:47 PM
Doug4320
Mar 24, 2018 10:11 PM
steve miller
Oct 10, 2015 01:40 AM
Coreyr384
Jul 10, 2015 11:13 AM
