PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 [184] 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266
  1. how to rebuild automatic hubs
  2. New to the forum, need advice
  3. steering center link recall
  4. New Ride (new to me)
  5. Crazy Electrical Problem
  6. Lets see your 1st gen 4runner Cargo Storage/Sleeping builds..
  7. My truck is about to get expensive...
  8. Exhaust System Issue...
  9. warm starts, Oil light is on
  10. Cold start injector operation- '86 22RE
  11. New feet for the 4Runner today
  12. soft to hard steering after 2 inch body lit
  13. Help with finding lift parts
  14. Other rides
  15. 4runner gears
  16. Dana 44
  17. 22r oil pump
  18. 22re engine swap
  19. photos!
  20. body roll after coils, 86 pickup
  21. 4.70 gaers for transfer case
  22. Aussie Locker or Lock Right rear locker
  23. back window swap
  24. New Tires
  25. So Depressing
  26. Transmission Troubles, I think...
  27. crossthreaded lugnut
  28. radiator options?
  29. Where does this go?
  30. Need input on a craigslist ad!
  31. My 22R-E burning oil..help!!!
  32. Treadwright Tires
  33. Quick Parts Fitting Question From A Noob
  34. 3.0 v6 head machining
  35. Transmission mount / vibration questions
  36. No power
  37. Is it true?
  38. For abe, and everyone !!
  39. where do I buy a roof rack?
  40. Gas mileage question
  41. Transmission & Transfer Case Identification Help
  42. I need HELP! RIGHT NOW!!!
  43. Brake's and Brand's
  44. Mounting for aftermarket rear bumper
  45. Great deal on a 4runner in NY
  46. Auto to Manual?
  47. Intermittent power failure?
  48. mid-high speed vibrations...please help
  49. Idle problems 95 4runner
  50. 22re turbo project
  51. Need a welder in Phoenix
  52. engine stand bolts
  53. Map Light Prewire for '90 Runner SR5?
  54. 4 runner runs hot, need help
  55. Tundra v.s chevy??
  56. Another Gear Question
  57. Look what finally came in.....
  58. What should i do
  59. My truck (not really a build up)
  60. 4runner MC rear bumper on pickup
  61. 22re air box questions
  62. 22re max power
  63. Speedo head compatability
  64. Trans swap ??
  65. 4runner vibration
  66. help weird noise from front pass. tire
  67. What Dif???
  68. greasable shackle pins
  69. replacing Fuel Line?
  70. rear window switch problem...weird
  71. Spare tire lock
  72. crankshaft seal question
  73. 4cyl to 6cyl transmission swap
  74. Adding Tilt?
  75. Jeep vs Toyota vs IH vs........
  76. fuel release lever/mechanism removal questions
  77. Electric Fan Mod
  78. thorwing a few codes
  79. 02 sensor help
  80. is it the starter?
  81. hard to start
  82. are the fj80 coils higher than the superlift 4 inch?
  83. 4Runner Grille & Headlights Onto A '90 Pickup?
  84. Need help with tires and math....
  85. I hate electrical problems
  86. 88 4x4 Can I swap drivetrain into my 94 4x2?
  87. rear brake help!
  88. 2nd battery location on a 4Runner
  89. insurance or on the side??
  90. So I need a new(er) OE idler arm...
  91. whare are my options? (engine swap/repair)
  92. Weird Scraping/Squeaking Sound in Reverse
  93. Tie rod ends and pitman arm, 1989 4runner
  94. 94 pickup with 22re
  95. Which clutch? S.A.S. 22re 93 4runner
  96. Swaybar Links
  97. Solid axles on craigslist D.C. area
  98. Idle surge, engine bogging
  99. 87 toyota on craigs list .
  100. A few mods....
  101. Towing with 88 4Runner
  102. newb questions
  103. idle problem?
  104. check it out not sure if its in the right spot
  105. my buddys 84 toyo
  106. 93' 22re Overheating
  107. Deal in the Central Florida area
  108. Need some help guys
  109. Dash board!
  110. Red and white wires off distributor
  111. OME springs issues?
  112. 3vze - 22r swap????
  113. is the catalytic converter the problem ?
  114. Anyone Got Pics Of Rear Wheel bearings???
  115. Whats it worth
  116. my 22re is chugging under load, but you cannot feel it. bad fuel pump?
  117. power streering went poof.
  118. Hard to get out of 4wd HI/Low and into 2H
  119. Coils done with pictures, thanks ZUK.
  120. Way confused about gearing
  121. new instrument cluster question
  122. Celica turbo on a 22re
  123. engine light on
  124. Runs like crap after heavy rain
  125. idle drops after reving the motor
  126. OME rear leafs 1988 4runner questions
  127. Heated Mirrors
  128. Engine Question
  129. You got to see this
  130. 3vze cam gear
  131. Yes, another speedometer question
  132. question about heater not getting hot
  133. 91 toyota ex cab brake problem
  134. weird problem
  135. Tune up question(s)
  136. Check out this little jewel...
  137. 22re build up
  138. Idle problem please help
  139. Front Brake Upgrade
  140. 22RE Trouble
  141. Fuel Filter Location
  142. Where does this hose go???
  143. moog ball joint spacers
  144. Rust problems
  145. funny things are happening.
  146. Who makes the best CV axle assembly??
  147. Air shocks
  148. switching out engines
  149. Any idea what this connector is?
  150. SAS - Axles that will work?
  151. chevy 63's on stock truck
  152. 3VZE repair help question
  153. Can I adjust my own camber?
  154. 91 3.0 o2 sensor wires
  155. Quick TPS adjustment question
  156. A few questions on 86' 4runner
  157. 86 4runner idle issues
  158. Rebuild update
  159. for fun
  160. I am a little confused...
  161. wont start
  162. find a little something new every day...
  163. engnbldr
  164. need help!!!!
  165. 5.29 and 37-13.00LT15
  166. throttle cable?
  167. new guy, tackling HG job on 22RE
  168. questions about fuel pump.
  169. Body Lift Bolt Sizes?
  170. 94 toyota's hoses
  171. Tire Help!!
  172. cleaning throttle body
  173. FJ80 cruisr coil info: Here! Not all short sides are the same!!!
  174. tire coverage 95 4 runner
  175. 3.0 v6 headgasket help
  176. Rough Idle + Can't Pass Aircare
  177. Toasted Clutch & Muddin!
  178. removal of harmonic balancer
  179. ? for you guys! fj80 coils, forced articulation, BJ spacers
  180. Steel cooling lines
  181. 94 Pickup ECM Problem
  182. epn 268 cam
  183. Weird brake lockup
  184. Fixin a couple things... steering noise/shake, cruise, and gas pedal
  185. It's a sad day.....
  186. Upper rad hose connection
  187. Transmission driving me crazy
  188. whats it worth???
  189. quick question: size of tail light screws?
  190. Quick Question: oil pump removal procedure 3VZE
  191. 1st Gen 4Runner Removable Top Seal
  192. Hard Ride!
  193. Rough Idle Questions
  194. Need a blueprint
  195. Lift rear
  196. Peeved @ SAS project
  197. Senior project ideas?
  198. removing spare tire from rig
  199. Santa stopped by today
  200. flowmaster 40
  201. 95 4runner runs lean help.
  202. 3.0 cranks, does not start
  203. Find me an A/C discharge hose!!! Discontinued!
  204. new clutch
  205. has anyone ever redone their stock alloys?
  206. Gas Lines
  207. low, ruff Idle at warm start up
  208. Score!!! But I need help with a year to year question!
  209. Body Swaps
  210. Gears And Tires ?.
  211. Lexus SUV commercial, did you notice the...
  212. knock sensor wire
  213. procomp shock question (help)
  214. axle movment?
  215. Timing Chain
  216. Receiver Bolts.. What size?
  217. Transfer Case Mounted Parking Brake Problems
  218. Instrument Cluster Help...
  219. Question for you 1stGen 4runner/2nd gen pick up owners.
  220. turbo?
  221. Timing chain?????????
  222. Body lift question for p/u bed
  223. Mod gone wrong!
  224. getting ready to do my font wheel bearings...
  225. Holy Crap!!!!
  226. kill switch not working?
  227. Brake Pad Change Help
  228. 92 Grille on an 87 4X4 Turbo Pickup
  229. bore 60 over
  230. Heater blower motor....
  231. head bolt thread pitch
  232. POISON OAK!! Happy to see my truck!!
  233. Which spring?
  234. Help with my 22re engine please?? details inside.
  235. does a sas ride bad?
  236. cb radio power
  237. Noisy Tranny, 5 spd 4x4
  238. Interesting finding about knock sensor
  239. Check engine light
  240. wire trouble...EFI fuse blowing
  241. well though i had it but it still broke!!
  242. vacuum sound
  243. 91 4runner: does steering intermediate shaft slide back?
  244. axleshafts/Birfs/etc
  245. Hard starting when warm
  246. LPSV Load Sensor Shackle Help Needed
  247. What did I break now?
  248. Stupid emissions crap
  249. 94 4x4 not engaging...please help...
  250. need hep to find shifter
