epn 268 cam
Old Oct 15, 2008 | 06:09 PM
91lowyota's Avatar
epn 268 cam
like the title says, i bought this cam off of engbldr and also purchased the full gasket set, head bolts, o/v valves, timming chain kit off of the same website. well last weekend i yanked the motor out and installed all of these parts with no problems, but after everything was said and done, started and ran the truck for 2 minutes the first time, then fuel leeks, then i started the trick the second time with more fuel leeks, but the third time i went to turn the engine back on it sounded like it had no compression, and after alot of trouble shooting i figured out that the dowl pin on the epn cam had broke, cuasing the cam to turn 90 degrees from tdc causing the valves to open and close at the wrong time, but should i send the cam back in and get another one, or take it to my work and press it back in and hope it stays in? any thoughts would be great!!
Old Oct 15, 2008 | 06:15 PM
kev's Avatar
kev
If the cam is under a warranty, you should send it back. Just to be safe on the warranty.
Old Oct 15, 2008 | 06:26 PM
91lowyota's Avatar
they say so but i have to ship it back to portland, OR but im thinking they will some how say its my fault lol
Old Oct 15, 2008 | 06:38 PM
muddpigg's Avatar
Call EB, I've mostly spoken to Ted but Tod runs the shop. You can E-mail, too good response times.
Old Oct 15, 2008 | 06:46 PM
91lowyota's Avatar
alright i will have to do that,i really hope they will exchange it
Old Oct 15, 2008 | 06:48 PM
88T4R's Avatar
I have no doubt he will exchange it for you!
Old Oct 15, 2008 | 06:54 PM
91lowyota's Avatar
alright well i just emailed him, thanks guys for your input
Old Oct 16, 2008 | 08:48 AM
AZ89LONGBED's Avatar
Well???
Old Oct 16, 2008 | 10:38 AM
abecedarian's Avatar
make sure to check for bent valves...
LittleUgly
15
Jan 2, 2020 01:30 PM
moparbay
Oct 6, 2015 09:24 AM
tylermx71
Sep 29, 2015 08:49 PM
whiteyota93
Sep 29, 2015 02:31 PM
voiddweller
Sep 28, 2015 11:21 PM
