Quick Question: oil pump removal procedure 3VZE
Old Oct 15, 2008 | 03:00 PM
gtfourdreams's Avatar
when removing the oil pump, do i have to remove the oil pan too? (i already have the crank pulley, timing belt, t-belt covers, and water pump all removed.)
this is an 89 4Runner with the V6 5spd. all factory, no mods.
Old Oct 15, 2008 | 03:03 PM
dlbrunner's Avatar
yes, you need to pull the pan
Old Oct 15, 2008 | 04:05 PM
damn! i was hoping i didnt have to. so... whats the easiest way in the garage? drop the front diff i suppose?
Old Oct 15, 2008 | 04:17 PM
jason191918's Avatar
That's what I did...although I have heard you can unbolt motor and jack that up.
What I did was unbolt diff, vacuum lines, and front crossmember (that diff bolts to) and left the axles hooked up.
This worked well for me, but I also had the tranny/flywheel off.
bigjstang
Jun 2, 2025 03:56 PM
Colington
Mar 8, 2020 09:51 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Cplmike
Jul 8, 2015 08:47 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
