- what is this?!!
- Question about Tire Size
- shift boot
- dashboard is craked
- CEL codes 21/41
- 22re timing chain question
- First 22re, very high idle.
- Mysterious engine squeal
- Coolant leak detectors
- Pic Request - interior
- help-too much pressure
- I wana swap for a 22r
- Idle problems
- TRD posi
- 3VZE Problem Supries Suprise......HELP
- Tow Ratings for an 89 4runner
- Anyone need some body parts I found this for ya
- Chirping sound under hood
- Another Tire size question........
- I Think I Got A Bearing Goin Bad!
- anyone order wheels from national tire and wheel
- depressed, so posting about problems w/ my truck
- How much exhaust crackle is normal?
- 3.slow Strange Idle
- Getting closer
- Exhaust manifold leak?
- tail lights for 87 pickup
- Wierd clutch problem...
- Some 33x10.5 questions....and more
- I replaced my wrecked 86
- Weight of 3VZ??
- Q-Forms Kick Panel Enclosures
- Code 52 even after KS replacement
- Turbo bog/stumble
- Winter Tranny Question
- Head gasket - 22RE
- Doing front brake bob (Wrong rotors?)
- need to find random parts for 4runner
- New Meats
- My runner is dieing 22RE
- in a huge hurry, please help fast !!!!!!!!!
- NEED Rear bumper pics- 2nd GEN 4 runner
- Spark Plugs on a 3.0
- New Shop In Souhern Maryland
- THIS is a stupid question....cooalnt for radiator?
- Just saying HI and a few questions.
- downey idler arm gusset
- ignition problem (I think)
- What are these worth? aisin hubs
- Blown out OME shock!!
- Front frame repair?
- Radiator cap wonders
- Valve Adjustment Question
- burned up 85 pu with sold axle what do you think
- Third Brake Light
- clearance lights...90/91 only
- Clutch pedal soft then hard, wha?
- Black ebay headlights?
- MY Tune Up ?
- Which shocks?
- Help w/ exhaust
- rear window on X-cab wont stay shut! rattles
- Found SR5 seats...
- allen head bolt on intake
- To ALL who have a body lift and aftermarket bumpers/sliders
- Odd Noise.. May be from engine...
- Rebuilding VF1A T-case....
- What gears do I have in my hilux surf?
- Front seat
- 86 with factory SA?
- 91 22re questions
- Double Pump Brakes
- Killer Vacuum Leaks
- well i painted
- need help 86 4Runner auto does not shift
- have a project for school about 2nd gen yotas!
- On the way to work the other day...
- Looking for opinions 22r Head/head gasket swap what bottom end?
- PLEASE show me hella500s on a lightbar/rollbar
- Rough idle when i press the brakes?!
- after market intake?
- Exo-Skeleton
- good paint jobs for 2nd gen
- little trouble no start well read n let me know what u think
- 4Runner parts in Oceanside, CA
- 4cyl to V6 tranny swap
- Photo editing assistance needed
- I have $2000 for a engine swap.
- what is this?
- How's your rear-wiper doin these days?
- e-brake handle pulled out...
- Hawk Brake Pads: HPS or LTW
- Am I setting the wheel bearing preload correctly?
- Rattling sound from the tranny
- Aftermarket replacement Radiator, where?
- Starter bolt?
- Why did my clutch go out?
- new Gauge HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- 87 - Stubborn Tie Rod End
- 87 2wd Frame and 86 4wd Frame (rear only)
- AFM needed
- tacoma rear end in a 1990 4rnner
- Soft brake pedal
- How can I get some rear flex??
- Auxillary trans cooler
- Help! This cable is loose and I don't know what it goes to
- Torque specs.
- Where can coolant leak from rear of engine?
- Thread sealant
- Roll Bar
- Tonka
- Fan Clutch?
- Obnoxious valvetrain
- lowering my cranked torsion bars
- what is this?
- Quick oil question
- 4wheelDrive
- Sugestions Please
- sub install
- '894Run bucket seats fit '91p/u?
- help on a off road bumper
- 1st Gen Rear Window
- Need a second opinion on a Tranny Swap...
- Low-Profile Bumpstops -ES part number?
- Back Pressure
- Help needed on bumper install
- wiring harness
- 4runner Fuel Filler neck Compatibility
- SOS 4th plug thread stripped!
- Brake question!
- Where can I get new shifter boots?
- The Wookie's SAS/build
- Isr Mod Kit
- PCV Hose Location for 3.0L '95 4Runner?
- my 3.0L gas mileage experiment
- weekend build
- Will 22re Knock sensor work in a 3vze?
- Diagnose Me!
- Interior Cleaning Solution?
- Indiglo gauges question
- Can you put a '96 engine in a '95 4Runner?
- What is this valve?
- What caused this piston to look like this?
- shifter lever
- help with lift set-up
- Rough idle upon startup....?
- Snorkel For 88 4runner
- No drive to front drive shaft
- Howdy from God's Country...
- Weird bogging while engaging clutch
- New guy here from Colorado
- Lebra fender flares
- Camo Poll(final)
- Leaf spring bushings for steering idler arm repair.
- Runner Saga Cont'd
- Head light troubles
- Torsion Bar adjustment?
- What do you guys think?
- New 91runner here!
- what gears do i have??
- diesel in a '92?
- any one have pics
- Blower motor inop?
- CV Swap ?'s
- marlin crawler shifter seat...
- 91' grille on a 92' truck
- 87 skid plate different than 89??
- What did i do or am i just paranoid coolint issue
- looking for advice on 22RTE Repairs
- molding fiberglass into steel. custom cowl hood every1 help
- suspension .. cantilever
- Steering Wheel mis-aligned
- hey 4crawler
- Has Your Head Gasket Blown On The Side
- where to add seafoam
- What mods to do with ~$1000?
- Pulled off the head
- winter camo ppaint job, need help
- Installing 1991 model 3VZ into '95??
- 22RTE to intercool or not?
- 90-95 Hoods W/ Scoops
- k&n fipk kit?
- Power Steering leak
- New toys!
- new shocks
- Rob the jewelery store and tell 'em make me a grill...lol
- 22rte engine idle/throttle question
- new rear bar bumper
- Diagnostic jump won't retard timing
- Gear shifter thread size?
- Peformance Kit for '92 Pickup
- 1988 3.0 the same as 1994 3.0?
- '91 p/u parts interchangeable with '92Runner?
- SAS vs. Gears/Lockers when IFS needs a lot of help?
- doa or lce???
- Opinions On this ol'Runner?
- 94 runner $3500 to much???
- New Cam
- Fuel Pump Leak
- 89-95 xtra cab pics
- idleing way high??
- Tranny
- Is anyone running a 285/75/16 on a 1st Gen?
- Tool Box Lights
- Big 3 problem at fuse box
- will this lift work
- 3.0 to 22re 'downgrade'?
- transmission woes... making a very strange 'SCI-FI' noise
- oil pressure sensor cable connector
- Rebuilding manual hubs - what's involved?
- OHHHH what a day!!
- Time for paint with a brush and roller
- Where can i find custom build bull bar rear bumper for a 1990 4runner
- Felpro head gasket
- ah..cant decide what wheels to put on!
- 87 4runner fuel pump only receiving 2.5V help please
- New radiator what's this
- Arb Bull Bar Mounting
- So what if they look kinda ricer? They look bass a$$
- Help finding drain cock??
- Cold piston slap
- What gear ratio With 38's
- wiring fog light HELP
- Front End
- '95 4Runner Chaos
- 87 2wd pickup blown hg
- 87 4runner Pics
- Shift lag
- Which Clutch do I need to use?
- in to the shop
- AC swap from 22RE to 6cyl 3VZE can it be done?
- 94 xtra cab 4x4 suspension lift
- Transfer case shift knob thread
- rebuilt 22re wont start!
- What tire should I buy?
- third member swap
- 2nd gen 2WD 4Runner
- Clutch issues
- o2 sensor, necessary?
- Cold air intake???
- cam question
- Shifter issues.
- disabling 4 runner daytime running lights?
- Truck still won't run!
- for those of you with lights on the LIGHTbar in the bed....
- Output shaft play confusion
- Bored..so I painted my KCs.
- Engine removal help (without fishing out tranny)
- no gauge lights
- emissions!!!!
