Pulled off the head
Old Oct 25, 2007 | 11:43 AM
Mister Willie's Avatar
Pulled off the head
I pulled the head on my 84 pickup, it's got an 85 22R in it. I know this is the 86-95 forum but, its a 22R question and this section elicits more responses usually.
Ok.. So I pulled the head and I wanted to know what you guys think I should do with it. The head gasket was leaking around the front of the timing chain cover, which is why I pulled it. I know I should take it to a local machine shop to have it resurfaced in the event of any small amount of warpage. Can you guys tell me anything else I might ask the machine shop to do? Anything else you can recommend while I got it all broken down?
As far as putting the intake manifold back on, should I do that with the head on a bench, or should I do it in the vehicle? I'm leaning towards the bench idea since it was such a pain..
Old Oct 25, 2007 | 12:05 PM
youngyota88's Avatar
i am fine tuning my head job i just put back togather a few days ago. you should check the chain and the driver side of the head where the chain goes, if you see 2 grooves you might want to check into a new timing set.
Old Oct 25, 2007 | 12:23 PM
I already replaced the timing chain just a few weeks ago, got a new set from EngnBldr
Old Oct 25, 2007 | 04:15 PM
slacker's Avatar
have them regrind the valves and seats .. and check the valve guides . also have them surface the TOPS of the valves .
then call toyota , and get some NEW adjustment screws .
Old Oct 25, 2007 | 06:27 PM
langzaiguy's Avatar
I'm going to invest in a new cam and a fuel filter. If I remember right, yours is by the gas tank (lucky). Yeah, definitely take a look at your chain. I'm going to play mine by ear and see if I need to replace it. Most of the guys on here will tell you to just go ahead and replace it.
Old Oct 25, 2007 | 06:45 PM
I did the chain a few weeks ago.
Old Oct 25, 2007 | 06:52 PM
fillsrunner4's Avatar
just get the head resurfaced and ask him while your there how the head looks? although just by eye at the time he may notice somthing you may not see then off that decide if you would like him to rebuild the head. i asked my machinest if he could just do the head and he said no because he cant waranty just the head if i installed the rest. he would have to build my entire motor to do so
Old Oct 25, 2007 | 07:07 PM
nmtoy's Avatar
Go see Eric at Santa Fe Auto Machine, he knows alot about 22R motors.
Robb
Old Oct 25, 2007 | 08:31 PM
toyotatom93's Avatar
I would maybe get a new chain lol
Water pump?
Old Oct 27, 2007 | 11:02 AM
NmToy,
Thanks for the advice! I had heard about SF Auto Machine having experience with Yota engines but now I have a name, so that helps too.
Tom: I did the chain a few weeks ago And the Water pump too!
Oh and thanks everyone for the input. I just didn't want to walk into a machine shop and let them take me and my money for a ride because I've never dealt with this kind of engine maintenance.
Old Oct 27, 2007 | 11:57 AM
n4ynu1010's Avatar
Head Gasket
Have them do a valve job/guides/seals/seats , at least check them and polish the seats a bit if they are in good shape .
bigjstang
Jun 2, 2025 03:56 PM
cars-guy
Aug 16, 2020 06:59 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
smiley52
Jul 11, 2015 05:16 AM
