What caused this piston to look like this?
Old 10-27-2007, 03:47 AM
TORTIS's Avatar
replacing my head gasket, and noticed number 4 piston. i have a miss that comes and goes and was wondering if the the injector could be clogged or going bad. what do you guys think?
number 4 is on the left
this is number 1
this is number 4 notice the color and the black wet build up
number 4 spark plug looked just like the rest good and gray, but a little black residue around the top of the plug.. could this be an injector problem?
Old 10-27-2007, 04:30 AM
SEAIRESCUE's Avatar
Looks like Earl to me. Perhaps #4 intake valve seal is leaking. While head is off, good time to touch up those valves and put on new seals. I would say if it was the injector, you would be running really rich all the time with poor mileage and a heavy smell of unburned fuel. All this assumes the cylinder wall has no scratches or worse. If your rings are starting to stick from sludge, I suggest you switch to synthetic motor oil or add a pint of kerosene at the next oil change. Either one will eventually clean the sludge from the rings by the next oil change. My "dirty" little secret.
Old 10-27-2007, 04:53 AM
TORTIS's Avatar
i do have the unburned fuel smell. these injectors have 354,000 miles on them. why would the plug not look bad if it is burning oil?
Old 10-27-2007, 12:39 PM
n4ynu1010's Avatar
Head Gasket
Could be you have a leaking injector
Could be low compression too , bad burn and plug depending on how hot could still be clean , a worn or stuck set of rings would be a real good reason as well but then again lower compression
If it hasn't been done prevoiusly then yes - guides,seals and valve job
How many miles on those rings by the way ? The cyl wall looks good in pic and little if no ridge I see so I am guessing they are fairly fresh
Old 10-27-2007, 05:41 PM
TORTIS's Avatar
110.000miles on this build.
Old 10-27-2007, 06:11 PM
n4ynu1010's Avatar
Thats good , I would guess your rings should be in decent shape by the looks of the cyl wall , maybe you have a worn out injector or a leaky valve seal/bad guide , stay tuned for more . How does #4 cyl wall look ?
Old 10-28-2007, 10:43 AM
FredTJ's Avatar
Actually, to me, the other piston looks like the problem child, not #4.
I assume that you're doing the head gasket because you blew it (that gasket).
You would not see a totally clean piston top and cylinder in an engine with over 100,000 miles.
You would, however, see a totally clean cylinder (and piston) with a blown head gasket that was allowing coolant (water) to enter the cylinder.
Saw that all the time when we did head gaskets. You couple always tell which cylinder(s) the gasket was bad around, allowing coolant in, as they would be completely spotless.
BTW, this points out one of the best and most effective ways to clean buildup from an engine and that is to [b]SLOWLY[/b/ drip water into the intake while it's running, adding enough throttle to keep the revs up.
Fred
Old 10-28-2007, 12:08 PM
n4ynu1010's Avatar
Head Gasket
Fred
Very True - Built in steam cleaning but not the kind you want hehe , alot of peeps use water injection for better mileage and that is one of the perks - Steam Cleaning
#4 could be dark from low compression ( could have been leaking into crankcase) so HG may solve all your problems , I would check the injectors like you said you were just for GP(General Purpose).
Thats one thing nice about the 4 banger is it is much easier to work on
calderp
11-16-2015 02:49 AM
LotOMiles
09-14-2015 11:45 PM
Streetrod19772000
09-10-2015 06:22 PM
old87yota
09-09-2015 12:39 PM
moparbay
09-03-2015 12:48 PM
Quick Reply: What caused this piston to look like this?
