where to add seafoam
Old Oct 25, 2007 | 01:55 PM
ks_yota's Avatar
this will be my first time doing it and dont want to fxxx up.
i just want to know where i pour the stuff into and does gas tank need to be empty when doing the fuel system
Old Oct 25, 2007 | 02:00 PM
eightnine's Avatar
if you add it to the break booster line it will clean out carbon build up and give you a smoother ride
Old Oct 25, 2007 | 02:17 PM
ks_yota's Avatar
i read pcv was better?
Old Oct 25, 2007 | 02:26 PM
frodin1's Avatar
Here's a movie! http://video.google.com/videoplay?do...=seafoam&hl=en
Old Oct 25, 2007 | 03:24 PM
89macrunner's Avatar
it doesnt matter where you put the seafoam..if its going into a vaccum line its going to end up in the same place...
Old Oct 25, 2007 | 03:28 PM
Jay351's Avatar
The brake booster does a better job of distributing it evenly to all cylinders.
Its the black hose comming off the brake booster. Pull the end off, the engine should idle down a little, and you should be able to feel a vacuum from that line.
SLOWLY pour 1/2-2/3 of the can into the hose ( I put my thumb over the bottle to regulate the flow into the engine), turn the engine off, wait 10 mins then fire her up!
Old Oct 26, 2007 | 09:11 PM
just a 22re's Avatar
or do what i do find a hole and stick it in!!!!
Old Oct 27, 2007 | 07:27 AM
thook's Avatar
The easiest way, I think, is the brake booster line. I tried going through the PCV line and couldn't keep the engine from dying. The bb line makes it a lot easier to control the engine while pouring. Just have to pinch the line a bit. And it did do a good job of cleaning. I've been battling blow by (leaky oil rings) in the intake, and after a couple of treatments things greatly improved. Nay to the naysayers!
Old Oct 27, 2007 | 08:55 AM
anthony1's Avatar
I found a nipple on top of the TB that's not being used for anything. attached a hose to it...start the engine...use the throttle lever to keep the engine from dying......put the other end of host in to the bottle. The vacume will sucks the liquid into the engine by itself. I used about 1/2 bottle ..then wait about 10 min. then start the engine and watch the smoke....
Don't do it in the garage.....even with the door open.
Old Oct 27, 2007 | 09:05 AM
n4ynu1010's Avatar
Seafoam
Use the whole bottle
Follow the directions
I use the PCV line , made a little adapter with a smaller hose(you can get a 3/8" to 1/8" fitting) so it doesn't suck it all up instantly and motor won't stall as bad , chose the PCV on mine because it feeds right at the front of the throttle body so it would definately clean throttle plate and throttle body well , removed air intake hose after whole bottle sucked up through PCV and Throttle Plate and Body were spotless
Old Oct 27, 2007 | 09:12 AM
anthony1's Avatar
I didn't mention that I did it twice in a row.....
Old Oct 27, 2007 | 09:49 AM
n4ynu1010's Avatar
Seafoam
Also when I put a bottle in my tank I added it when empty at the gas station and put 10 gallons of Premium in tank with whole bottle , it worked well , seemed to give it a bit of power and smoother operation by the time I had run it all out
urabus
Nov 10, 2015 07:38 PM
Obmi
Oct 4, 2015 11:30 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
Cycles
Sep 29, 2015 06:37 AM
oldblue
Sep 28, 2015 04:07 PM
