PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 [254] 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. torsion bar adjustment...help!
  2. Identifying tranny model
  3. 93 V6 PU starter problems
  4. Idle up diaphragm
  5. Brake Light came on after going over speed bump and wont go off.
  6. stuck in 4 wheel drive
  7. where does the clicking in your 22RE seem to come from?
  8. Air filter n such...what to do
  9. HELP 22re swap in Denver??
  10. Sabotage? I think so!
  11. Radiator and electolysis?
  12. Camshaft cap bolts stripping
  13. 4R passenger door latch
  14. Bad Sensor or Timing?
  15. Cool 2nd Gen Aussie 4Runner (Surf) Pics
  16. Downey 1.5" HD Coils- Ideal Shock Lengths
  17. 22RE Head Gasket and Timing Chain Replacement PICS
  18. IFS Flex Pics
  19. new 02 sensor...and worse mileage?
  20. Can I adjust a 91 clutch?
  21. Need help. IFS axle bearing? How to?
  22. East coast rust
  23. Clutch problem?
  24. Ifs 4wd and rear diff.
  25. urgent tire question--size
  26. Crack in Timing Cover
  27. Pull the head?
  28. Transmission Slipping
  29. Moving from AZ to WI. Tips on prepping for the rust belt?
  30. More power please
  31. 3VZE ECU Pinout
  32. 3.0 3vze overhaul
  33. Second thoughts on 3.4 Swap
  34. lubing the chasiss
  35. New Bug Deflector
  36. New Thermostat Bad or Radiator Blockage
  37. should i buy it? 87 SFA T4R
  38. Click fixed - Now Rear main seal leak
  39. Rebuilt Engine on eBay w/WARRANTY 5/50K
  40. _____R P M ' s_____
  41. spool?
  42. 89-95 pickup/90-95 4runner white face indiglo guage faces
  43. Battery hold-down
  44. LED Bulb question
  45. Post timing belt issues?!
  46. Cure for bent IFS tie rods / idlers?
  47. lower rad hose just warm
  48. Head Stud Sources
  49. I want an Air Fuel Ratio real-time Monitor!
  50. Pics of my HG replacement...sloooow going
  51. Strut/shock replacement 96 4Runner
  52. another emp guage
  53. Half done head gasket
  54. Bilstein Shock question....
  55. first time doing front brakes, pointers?
  56. Crankshafts...
  57. whats a 22rec
  58. need to know everything about engine swap
  59. Faulty Knock Sensor?
  60. cam install 22re
  61. how much oil do you lose after doing top end and timing cover on first change?
  62. Oil warning light on '86 SR5 4runner
  63. Serious oil drip from... A/C compressor?
  64. Fan shroud running warm?
  65. Electric Fan Woes... again
  66. Fuel sending unit question
  67. is u-joint zerk clogged?
  68. Front brake rotor removal with ADD hubs
  69. mpg current average on your 3L V6 (3VZE)
  70. O/D on or off?!?!?
  71. Need advice: Check engine lamp on 22-RE
  72. Gauge install.
  73. Update on my speedo not working issue
  74. steps to removing throttle body, intake, etc
  75. Steel Brake Line ?
  76. shock valving
  77. are 95' pickups take same accessories as 95' 4runner i.e. bumpers
  78. Doomist's Rig
  79. Front end problems
  80. Running 34s
  81. broke a pro comp leaf spring
  82. A/C idle
  83. AFM question
  84. Oil Cooler Leak - Rebuild w/new seals?
  85. got a front-end squeak. suggestions?
  86. 5spd swap
  87. check engine
  88. Sputtery 22RE
  89. Opinions on stripes
  90. 86 rear window switch wiring
  91. 22r sound like diesel
  92. Fuel pump running - engine off??
  93. 1988 4runner problems, i think ive solved it
  94. Engine surging - 95 4Runner
  95. A/C and idle rpm
  96. Little man in the motor brought out his hammer
  97. 3.0 Exhaust: More Torque, Less Noise
  98. Power Steering Vacuum Leak?
  99. RIDDLE ME THIS....(pinging issues with pics on a 3vze)
  100. oil leak on my 86 runner HELP!
  101. Does BJ spacer = brk line extensions?
  102. possible starter problem?
  103. master cyclinder question.. did a search and found nothing
  104. 22 re won't start
  105. 87 2wd with g662 axle code....
  106. Clicking noise while in 4wd
  107. wheel size on an 89 runner
  108. 91 4x4 22re timing chain help
  109. 88 toy pickup fuel line question
  110. going to replace head gasket
  111. diamond plate corner armor for 1st gen 4runner?
  112. something electric wrong?
  113. 3vze timing question
  114. Radiator with 4 coolant ports? (pics inside)
  115. Turbo Supra Powered Trucks!
  116. New Speakers
  117. Upper Idler noise..on 3.0 v6....
  118. '88 3vze firing order/cylinder layout
  119. 1st gen. tailgate problems
  120. Stock front skidplate bolts
  121. Leaking Window
  122. Electrical issues
  123. What surface finish on a newly machined head?
  124. 3.4 Swap Questions
  125. 4runner dying problems
  126. Continuing 22R problems
  127. New so be gentle... 93 vs 94 service manual
  128. Who else is in the midst of a blown HG? (copper anyone?)
  129. Spring Packs???
  130. help!!! 4runner wont start
  131. No cranky..lacking juice? 88 4x4
  132. Head Gasket Help?
  133. G or W series tranny?
  134. fuse / relay block location
  135. Oil filter change only - doable?
  136. 22re e85??
  137. rear differential trouble
  138. cheap mods for 89 22re more HP
  139. how to convert AC from R12 to R134
  140. axles
  141. Wont go into 3rd gear?!?
  142. 89 yota 3vze blown motor
  143. head gasket replacement
  144. Bad motor mount (I think) easy/hard to replace?
  145. a/c compressor
  146. Now my A/C works fine
  147. speedometer just stopped working, any ideas?
  148. 95 22re Starting Problem
  149. what gears are in this yr truck
  150. sway bar? keep it or ditch it
  151. Expansion Valve Recall - To do or not to do?
  152. catalytic converter questions
  153. Early versus Late 3vze Heads
  154. 1994 4runner wire diagram
  155. Water pump questions for a 3.0
  156. Ac stoped working
  157. 22RE oil sending unit pipe plug
  158. air intake
  159. Storage, 22RE
  160. Low Top Speed, After SAS.
  161. 22re: repair, rebuild, or replace?
  162. ecm terminals
  163. 1st gen interior
  164. Aisin Hub Problems
  165. 92' keeps dying
  166. I need a favor please- cab measurement
  167. I smell gas!
  168. More Lift!! (pics)
  169. 22re Issues, Need some help!
  170. Rear Wiper
  171. 22re redline
  172. Completely lost with clutch/tranny problems..
  173. 22re Issues
  174. I want more MPG.
  175. short head bolts
  176. 90 4runner 3.0 - valve job or new engine?
  177. Put seals in steering gear how much play in steering wheel
  178. Check engine light is on!!!
  179. 89 runner 22re noise
  180. How to recharge A/C?
  181. Gas tank relocation
  182. 3.0 teardown
  183. AAL install help
  184. windshield wiper and spray linear
  185. SR5 gauge cluster ?
  186. need vacuum line help.
  187. I heard a pop and now my 22RE runs Bad??
  188. Replace A/C cost
  189. Got the 32's on
  190. Slave cylinder piston!!!
  191. A/C Hose Burst
  192. What Will ethanol Do To My 91 Runner
  193. 1993 4x4 Pickup CORNER LIGHTS?
  194. Last minute advice/input on the new 3VZE exhaust
  195. 22-RE Ticks after warm up, but not at all when cold
  196. 91 4R 3.0 rough idle but revs good
  197. Water leak in the runner
  198. wiring harness compatability...
  199. Separate pulling engine motor from tranny transmission -any ideas?
  200. Towing a buggy?
  201. Which master brake cylinder?
  202. '87 22R (carb) rough idle
  203. Still overheating... going to replace the fan-clutch
  204. Idle hunting (bouncing) and then it dies.
  205. 86 4runner hubs
  206. 95 4runner OD
  207. windshield washer pump(s)
  208. project snowball: batt and break light on
  209. 1993 4x4 Ext Cab P/U sagging rear end
  210. wiring diagram
  211. 31's on a 4x2???
  212. can you rebuild brake calipers?
  213. Lower Ball Joint ???
  214. TVV (DVSV) Removal
  215. Where to get white face gauges?
  216. 3.0 ammonia smell
  217. nooB question: where's my thermostat?
  218. Rims and Tires on Truck
  219. Cylinder head removal questions. Fastest way to do it?
  220. Preference for O2 Sensor Brand?
  221. Just replaced timing set, head, and every gasket in the motor and have oil in water..
  222. front end noise?
  223. Sorry, another problem with 4WD not engaging
  224. A/C blows ~40 Degrees...good/bad/avg?
  225. Cig lighter not working
  226. 22r oil pump..... again
  227. 3.4 5vz-fe crossover pipe ORS
  228. o2 sensor
  229. AFM retarded
  230. Black Lugs
  231. 1990 4Runner V6 Plenum Hoses
  232. side mirrors
  233. rear window blues
  234. Timing belt change time
  235. Do you change oil after Sea Foam???
  236. boiling coolant problem
  237. 22re cooling problems
  238. Truck not going out of gear?
  239. 22RE Timing Issues!
  240. Pro Comp Shock question...
  241. Question about OMEs, didnt find anything by searching
  242. Speaker ideas for regular cabs???
  243. Great Toyota Commercial!
  244. lurking..now i post.22re exhaust question.
  245. Minor coolant leak on 89 3.0...
  246. Very poor drivability
  247. clutch is gone?
  248. 91 2door with Limited Flares & Rockguarded - pics
  249. A/C Electrical Problem? A/C Relay??
  250. Transfer case leak on '88 Pickup
