- Mud hole disaster
- 86 22r head gasket problems?
- 22R-E oil capacity debate
- Tire clearance question.
- 1989 3.ol v6 pickup
- Another won't go into Overdrive thread..
- v6 to 22re swap
- 92 ext cab 4x4 3vze 5 speed ran hot
- Gas coming out of my exhaust!! HELP
- Broken leaf spring
- Grease fitting thread count?
- Yet another 3vze problem, every bolt hole strips
- Keep your ECUs dry!!!!! A warning for everyone!
- Ac compressor bracket
- 92 Toyota Pickup 2wd upgrades
- Vacuum Line on 3vze
- Low Oil Pressure (maybe?) - 89 4Runner V6
- Wrapped the runner
- 22RE MAF sensor problem, Can ya help?
- Cutting out after warm up, 87 22re Help!
- stuck front axle carrier!!!!!
- Look at Crack Piston while Rebuilding my 3VZE
- 89 ewd needed
- Rear end shake
- 86 4runner exo cage
- 94 4x4 toyota pickup clicking from drivers side wheel when manual hub is locked.
- 22re Code 12 24 and 31
- 3-VZe overheating issue
- 22re swap
- no brake pedal pressure please help!
- Rear tweeters (4Runner)
- Clutch pedal
- g52 transmission?
- 87 pickup gas lines
- Valve covers, any options on anything other than plastic
- 87 pickup fuel problem
- 91 4Runner v6 CEL code 12 and 25
- Will an 04 Tacoma rear bumper fit a 93 pickup?
- (VIDEO) 95 4runner won't time or idle correctly, runs with NO POWER.
- Help! Overdive surging!
- What to check before exposing my 4runner to cold weather?
- dies when i step on the gas
- Need Help With Transmission Problem: Throw Out Bearing?
- Truck Horn / Train Horn Switch
- 1997 T100 ext cab Rocker Panels right side
- 93" yota Body lift Qustions!
- Heater Control Valve/Cable '88 4runner
- heater temp control lever broke
- 86 TOY XTRA 4X4 SR5 Soon To Arrive - Photos / Extra Enhancement Ideas?
- Thinner main seals?
- 93 toyota pickup steering wheel is locking
- what bed is this??
- Oil in intake, pcv is not bad. what to do?
- 3.0 water pump/ timing belt kits ?
- New Guy. Introduction and question
- First post and a question
- Transmission whine
- EGR Deleted, heater core hose??
- Runs The SAME With TPS Unplugged
- Custom 1 inch body lift
- 92 3vze very sluggish at times
- Aftermarket injector question? any good?
- Where can i buy a CSI time switch??
- 22re hard to start when hot
- '96 3.4L High RPM Accel. Issue?
- I'm back! 1990 4Runner 3.0 5 Speed
- My Truck stalls when placed in gear
- Needed Downey Slip joint axle install Manual
- wiper help
- 94 pickup 5 speed 3.0 4wd bucks and jerks at 2000ish rpms???
- '92 3.0 driverside rear cam plug leak
- Stiff shifting
- New 3rd (w/ ARB), any good vendors?
- Alternator troubleshooting help
- camper shell question?
- misfiring
- New 93' Pickup DLX V6 owner
- 22RE exhaust leak, wont tighten up??
- 86 pickup bogs down/dies when push on the gas
- 1989 4runner
- thorley header install help needed 94 3.0 floor board obsticle
- Toyota starts, stalls quickly. But it will run the second time
- Coolant and Oil leak!
- Truck Cap Options - Post Photos - Ideas
- 3vze knocking sensor question
- Broke the ECT sensor off. HELP MEEEE!!!!!
- strange clunking noise coming from front end.
- 1986 4runner FSM or Wiring Diagram
- bad missing problem
- 88 4x4 ebrake / parking brake issue
- New toyota owner
- Om617 mounting question
- front shock mount broke
- Brake caliper and bleeding questions
- nerf bar question
- What is this removable rectangle on the back of my cab
- What does a worn timing belt look like? 3VZE
- 87 Bench Seat
- swapped 3vz wont start. plz help.
- Stick shift question
- '91 Truck clutch problem
- 1988 4Runner project
- Is this the right seal? Rear axle.
- 1988 4runner swap ideas
- New one for me...Oil cap removed idle drops?
- ARB bumper/winch mount question
- Identifying hub type and fixing an intermittent griding noise.
- Alternator Charge Wire
- Rebuild Gone Wrong?
- Snapped a head bolt. Afraid of snapping the bolt extractor also
- Gonna do Head Gasket - Redo Top End for $975
- Best way to remove oil that leaked all over the place?
- Installing a kill switch, very easy and cheap!
- Another water bypass thread
- 91 toyota truck i dont know
- 91 toyota
- Loss of power
- Toya shut off
- Fan blade ?
- 22re idle bounce
- Valve chatter when cold, purring when hot.
- The dreaded "chirping" sound when rolling...
- Stock g144 gears (4.88)
- 1988 4runner speedometer cable replacement trouble
- Opinions on a 1990 4runner
- Fuel Inejctor seals massive fuel leak after install
- Any ideas on repairing the hole from a timing chain?
- Pwr Sterng pmp connection can u tell if this is broken
- The Greatest Minds Part Deux
- New here! Just got my truck!
- Spark but no fuel...
- 95 3.0 jumpy ignition timing
- slave cylinder
- Urgent: Need help with timing chain have pictures
- 93 4cy Truck TIming Chain advice
- Digital Cluster
- Looking to buy a 4Runner
- First 4runner - couple problems.
- BJ Spacers with Rancho 5000's
- 4Runner grey to black interior
- About to lift my truck. Advice please
- What is this sensor? What is its function?
- 1992 toyota 4x4 pickup EWD needed
- New member
- "Vintage Air" Air Conditioning Question
- 95 4 runner 3.0 loseing power
- 93 22re Head Gasket Replacement/No Power!
- 1994 4runner tranny issues :(
- engine light and a/t temp light flickered and engine stumbled
- gasket or sealer? Thermostat housing neck
- Home made cam sprockets holder
- break-in after timing chain?
- Any Ideas?
- No Power Until 15 MPH
- neutral safety bypass
- No power to A/C Cpmpressor
- Weird issue: Gas smell in cab ONLY when low (foot) vent is blowing...
- After 22re Rebuild... What part is this??? (ENGINE TIN?)
- What happened to my sr5 wheels!?!?!
- Engine chugs and dies
- Strykersd's auto to manual swap
- Dome Lights won't come on for Driver's side door, missing part/relay?
- 89 pickup gave me the day from hell
- 93 4runner will not start!! Ideas....
- Help 89 xcab 4x4!!!
- 93 Pickup suddenly died, jumpstart wont work
- bad idle missing (not tps?)
- Check engine light came on after tune up
- Has anyone ever got lucky on a very slight rear axle seal leak...?
- 3vze questions for my 94 runner
- Throw out Bearing?
- 3rd gen cluster into 1st gen T4R...
- Can't get my 22re started! Help.
- 3.4 Swap Needed - Lower Alabama
- light bars....
- DTC terminal location
- 1990 3.0l rebuild
- 1990 3.0
- Frame Thichkness
- 87' yota front axle
- 1988 toyota 22re won't start/ no spark
- barely idles. will not accel, bogs real bad.
- 86 4runner Starts with Slow Key Turn?
- Painting the 4Runner Top - Couple Quick ???'s
- Hesitation in the gas pedal and occasional hard to start
- 1993 Pickup "mushy" clutch
- Help for 4WD sensor P/N
- Losing power
- 4th Gear Doesn't Work
- need help chosen suspension!
- Gearing opinions / tire size opinions.
- Fuel System Issue
- Rear Diff fill & drain plug part number#?
- Does your truck have clogged arteries?
- Noisey Lifters? Top End Tapping? Adjust
- Momentary loss of power to wheels
- Denso spark plug wire set does not include coil to cap wire
- 3vze blown head gasket - options?
- Intermittent low rpm at idle?
- 32x11.5r15 on stock Sr5 hilux
- trans CG
- 1st Gen 4runner rough running
- A few questions on light reostat and blower resistor
- 92 bad idle and hesitation
- 2500 rpm at 55 mph?
- 1st gen 4runner reman3.0L won't start
- Remanufactured engine 30 degrees off - says the smog guy
- TPS on 95 4runner v6
- HELP knocking ?
- longer seat tracks?
- wet floor mat
- 94 22RE Swap
- New rear coils? sag?
- Yn67 front end clicking from driveshaft area under load
- The Possible Routes to Going Single-Key
- spindle bushing grease job
- Transmission Help!!!!
- White Smoke when going around corners
- 86 22ret no injector pulse. HELP!!
- 95 4runner hesitating and major loss of power
- 94 22RE Engine Swap
- Cheapskate Ring Job?
- HELP! #2 Cylinder shows Low/No Compression
- Pull up to the scene with my ceiling missin'
- jumped timing chain poor running/damage?
- What is this thing?
- Air Gap on distributor 3vze
- Parasitic draw?
- rough idle after valve cover gasket change
- Transfer case weight?
- rear end clicks when throttle on or off
- truck won't start
- A good day... Auto to manual swap
- 7.5A Charge Fuse
- What doors can i use on my 88 pickup sr5?
- Half shaft ripped out.. again. Need spacers.
- Coolant Sensor Connector
- Engine won't turn over
- dim headlight & carburetor/emission issue
- "Click", like a switch and the valve tapping disappears...
- Just scored a 87 22re 5spd but what is this?
- New engine for only $895 installed? Cylinder 6 Misfiring
- What parts should I replace when I pull my injectors
- Headlights cause idle drop...
- Suspension and doors on my 90 4x4
- 95 4runner (help with hoses) 3vz-e
- Mysterious spout on bottom of radiator?
- Shifter problem
- Replacing bench seat, whats ur opinion on best looking buckets?
- not rear main seal
